Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Loose Handle Handle on the refrigerator side of my Stainless Steel GE Fridge is loose. Both the top and the bottom of the handle are substantially loose. I can't see that a screwdriver or allen wrench can tighten them up. Please help
  • Omahamatt Jun 29, 2008
    There are holes (no trim covering them). But there is no head for a screw or place to put an allen wrench in. Perhaps the screws fell out???
  • 481 Answers
The screws are sometimes hidden by a metal or plastic trim. you can take the trim off with a butter knife (usually).
Posted on Jun 29, 2008
  • Mike Durland
    Mike Durland Jun 29, 2008
    you can try to put 1/2"-3/4" sheet metal screws in to hold it.
    it is hard tell without looking at it. there is so many different styles of handles.
Bosch refrigerator door handle is loose
there is only one screw on the handles from what i found out from fixing my loose handle. the bottom of the door handle has one screw. once you loosen that one up then you lift it and it comes out at the top enough to slide the handle out and tighten it.
Aug 03, 2014 | Bosch Evolution 800 B20CS80SNS Stainless...
GE GFSL6KEXLS Stainless Steel (2585 cu ft) Bottom Freezer French Door Refrigerator Problem: Freezer handle is all stainless steel is loose. How can I tighten it? I looks like I would have to go through...
look for a small hole on one side of the handle. There should be a set screw there you can tighten. (the handle attaches to a ball shaped peg under the handle, and does not attach from the inside of the door)
Nov 28, 2010 | GE GFSL6KEXLS Stainless Steel (2585 cu ft)...
GE Energy Star French Door Bottom Freezer handle popped off
You cant find a hole to insert screw from outside. It is true, and you can't fix it yourself to what it looked like earlier. The company first screws in through the handle and then covers the hole made by it with the material of the handle. If you have to fix it yourself, you can only pierce those screws through the handle leaving the mark behind. If you don't want that, contact your company or dealer.
Apr 22, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
Freezer door handle loose
Can you give me the model number? Ther are alot of variation of handles.
Nov 14, 2008 | GE Profile PSW26P Stainless Steel Side by...
Use a 3/32 Allen wrench to tighten the screw on the side of the door handle
Jul 16, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Loose handle on door
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Ge profile refrigerator door handle is loose
I had this problem on this model and just repaired it.... and I am no mechanic. The bottom of the handle was loose. You'll see there is a cap on the top and bottom of the handle. You need to pop the cover off of the end that is loose. For the bottom part of the handle, I used a flat head screwdriver under the most southern portion of the handle, lifted the handle of the screwdriver towards me. The cover popped with minimal effort. Tighten the screw and replace cover. Pretty, pretty, pretty easy!
Dec 22, 2007 | Refrigerators
LOOSE DOOR HANDLE ON GE PROFILE ARCTICA STAINLESS STEEL REFRIDGERATOR
I may need to know your model # from the sticker inside the fridge to view a diagram but usually there is are small set screws (usually 2) on the handle which are allen head that can be tightened.  Look for this first and let me know if there are no set screws.  If this is your setup then I would appreciate a solved rating.
Oct 18, 2007 | Maytag MBF2556HEW / MBF2556HEB /...
How do I fix loose handle?
havnt worked on that but... most times theres a cap or piece that will come off hiding the screw not sure what yours is cant find anything on it .. hope that may help some
Sep 02, 2007 | GE Monogram ZDWC240NBS Stainless Steel...
Door Handle repair
The fastner must be loose. Remove both set screws remove your handel. Then tighten the fastner. reinstall the handel and tighten your set screws. let me kniow if this helps
Aug 18, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
192 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
