Question about Bissell 6594 PowerForce Bagless Upright Vacuum
Belt motor pulley on a bissell powerforce bagless vacuum
Does the belt go directly over the metal motor shaft, or is there supposed to be a plastic pulley there?
  • Anonymous May 11, 2009
    is this shaft suppose to have a pulley on it or not
    President:
  • 1,673 Answers
Yes, the motor shaft is also the pulley.
Posted on Jun 29, 2008
  • sancudo74 Oct 01, 2010
    Thank you.I almost threw my vacuum away looking for a pulley.
Brush roller not spinning. belt, spindle okay. roller taken out and cleaned, no thread. replaced but no dice. ???
Use only BISSELL Style 10 Replacement Belts (#32074) in your BISSELL PowerForce Bagless.
  1. Unplug cleaner from electrical outlet.
  2. With Rotating Floor Brush removed from vacuum cleaner, grasp old Drive Belt and remove from Motor Pulley. Discard old Drive Belt.
  3. Place new Drive Belt over Motor Pulley and stretch other end over Rotating Floor Brush in the space between the bristles.
  4. Place ends of Rotating Floor Brush down into slots on sides as shown.
  5. Turn Rotating Floor Brush by hand several times in the direction of Motor Pulley. If properly installed, Drive Belt will center itself on Rotating Brush.
  6. Reposition Brush Cover and snap back into place. Check to be sure all three latches are secured.
  7. When you turn on the vacuum, do you see the motor that spins the belt spinning at the bottom? If not, it sounds like you may have a burned out motor.
If suggested solutions do not correct the problem, call:
BISSELL Consumer Services 1-800-237-7691
Monday - Friday 8 a.m. - 10 p.m. ET
Saturday 9 a.m. - 8 p.m. ET
Jun 01, 2011 | Bissell 6594 PowerForce Bagless Upright...
How to change drive belt on bissell vacuum cleaner
Hello, you will need to take the bottom plate off, remove the screws on the plate, then pull up and out the brush roller, clean off any hair on the roller, make sure it spins freely, then put a new belt around the metal motor shaft, then around the roller and pull in down into the housing, spin the roller to make sure it moves freely, so you don't burn up the new belt, put the bottom plate back on and your ready to vacuum. Any questions feel free to call @ 1561-848-3387 I'll be gflad to help, Thank you, Teresa. Clean Sweep Vacuums
Aug 10, 2010 | Bissell 6594 PowerForce Bagless Upright...
Bissle vacume can not fit belt around motor
It sounds like you got a belt that was too small, if it is the right belt it will be hard to get on. But once its on you will be all set.
Jan 17, 2010 | Bissell 6594 PowerForce Bagless Upright...
Vacuum sounds like an airplane after 1 year of use.
the motor bearings are starting to fail most likely. You can diagnose the source of the noise by removing the brushroll and belt, could possibly be the brushroll bearings but if you still get the noise when the belt is off its the motor.
Jan 07, 2010 | Bissell 6594 PowerForce Bagless Upright...
Loud motor
It could be caused by a worn drive belt. Here is a link to the belts you need and the manual which has instructions.
Bissell PowerForce Belts and Manual
Dec 20, 2009 | Bissell 6594 PowerForce Bagless Upright...
I have a bissell powerforce bagless vacuum. My
Its probably is the roller brush causing the noise.
Nov 28, 2009 | Bissell 6594 PowerForce Bagless Upright...
Bissell powerforce bagless extremely loud.
It could be that the belt is worn. You can get replacement belts and the manual here:
Bissell PowerFrorce Belts and Manual
Nov 21, 2009 | Bissell 6594 PowerForce Bagless Upright...
Belt on this vacuum
Take off the bottom plate covering the brush roll, take out the brush roll, check it to make sure the ends turn freely, the belt goes around the end of the brush roll, then stretch it to go over the motor shaft.
Mar 22, 2008 | Bissell 6594 PowerForce Bagless Upright...
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
1,149 people viewed this question
Top Bissell Vacuums Experts
Roger Potts
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
