Question about Canon Cameras
I want to set the timer on my canon d40 so I can put it on a tripod and take pictures that I am actually in
  • 39 Answers
You are referring to the self-timer feature (looks like a circle with a line like the hand on a clock). Just press it and you will get a few options of the number of seconds you want before the shutter snaps. Check your manual for more detailed instructions. Hope this helps!
Posted on Jun 29, 2008
Shutting off flash
Yes, but not in the Auto mode, where the camera decides whether or not it needs the flash. Switch to the P mode, which works like Auto except you have control over the flash, exposure, and other factors. See pages 26 and 42 of this manual.
Apr 12, 2013 | Canon EOS Rebel 2000 35mm SLR Camera
I have a Powershot A85 and am trying to shot silver jewelry and am having a problem getting a clear picture. I have lost my manual - can you tell me how do I get a clean clear picture to put on a website?...
Recommend a room with good ambient, non-direct, lighting. Also place the camera in "Portrait" mode (the dial selection with the lady's profile). Also turn off the flash by pressing the lightning bolt button repeatedly until you get the icon with the slash through the lightning. Next put it in close-up macro mode by pressing the little flower button. Next use the timer to take the shot, by pressing Func Set, then scrolling down to the mode selection, and then scrolling right to select the 2 second option.
The camera is now set for such a closeup. Recommend using a tripod to keep the camera extra steady during the shot. If no tripod is available, recommend bracing the camera against another object, such as a chair to help keep it steady. Aim and zoom at the piece of jewelry, push the shutter halfway down to focus on the jewelry (should see a green box). Once you get the green box indicating focus, press the shutter all the way down to start the timer. Hold the camera extra steady until about a second after the shot.
Good Luck!
Feb 04, 2010 | Canon PowerShot A85 Digital Camera
How do you take a picture a night of christmas lights
Shots like this are tough to get with a point and shoot camera.
The best way is to set the exposure around 1/15 or lower, if you can adjust ISO use the highest ISO setting the camera will allow. You will need to hold the camera very still, so a tripod or other solid object to steady the camera with will help lots. Sometimes pushing the shutter moves the camera, so try using the self timer. A tripod with the self timer is the best way to go, and experiment with different shutter speeds. Start with the longest the camera has and go up.
You can also try the flash, but the flash modes that really work aren't available unless you get an SLR.
Oct 12, 2009 | Canon PowerShot A95 Digital Camera
I have a canon A1000is and it is takin horrid pictures at close range. I'm taking photos of buttons and 90% of the time they are a blurry mess. I use Auto set and I'm taking dozens of images to get one...
Use the close-up setting and hold the camera steady against a solid object or use a tripod. Use the self timer with the camera on a tripod or solid base. The button to set close-up and the menu icon look like a tulip. See page 64 of the manual: http://gdlp01.c-wss.com/gds/0300001222/PSA1000IS_CUG_EN_02.pdf Try also with flash turned off.
Sep 21, 2009 | Cameras
Nikon D40 vertical focus problem
Make sure the camera is using the appropriate focus sensor.
Does the problem occur when you focus manually?
Are you handholding the camera? Many people don't hold the camera as steady when holding it vertically. Try putting the camera on a tripod or other steady surface and see what happens.
Jun 11, 2009 | Nikon D40x Digital Camera
Canon EOS rebel s
This command dial setting, which looks like a clock, is the self-timer mode. Turn the dial to this setting and press the shutter release. The camera will start beeping or playing a tune and will take a photo about 10 seconds later. You can cancel the timer by switching the camera to another mode (or turning it off) before the picture is shot.
Note that the timer mode is the same as P mode with the 10 second timer. There’s no way to operate the camera in, say, Av mode with a timer - something of a limitation. There’s also no way to change the time value.
Self-timer mode is commonly used for two things. First, it lets you take self-portraits - or group shots including you - if you put the camera onto a tripod. And second, it’s useful for slow shutter speed shots where camera blur might be a problem - you can put the camera onto a tripod and take the photo without risking camera shake caused by your finger pressing the shutter release. In either case it’s best to focus on the subject first and then switch the lens to manual focus mode once you’re satisfied. This avoids the problem of the camera autofocussing on the wrong thing when it takes a photo unattended.
Note one detail. Normally when you take a photo you’re looking through the viewfinder and your face is therefore covering it. However, in self-timer mode the viewfinder is left uncovered and stray light can enter the camera, possibly throwing off the internal light meter. So when using the timer it’s wise to cover the viewfinder with something. Some camera straps include a plastic cover on one end that can be used to cover the viewfinder. Or you could put a grey or black plastic film canister cap over it if you have one around - they fit nicely. The one time this isn’t necessary is M mode since you’re setting both aperture and shutter speed manually
Dec 02, 2008 | Photography
Automatic shooting (for group pictures)
Hi - You can download the manual from the link underlined in blue below:
PowerShot A710
The feature you need is the "self timer" on page 14:
When you press the shutter you will have up to 30 seconds to get yourself in the picture before the camera automatically takes the picture. For best results put the camera on a tripod.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 27, 2008 | Canon PowerShot A710 IS Digital Camera
Power Shot A75
Of course it does, it has full manual control (M), but may I suggest first trying "shutter priority" (Tv). This mode lets you set shutter speed up to 15 seconds, but it automatically sets the aperture to match the shutter speed that you set. Merely turn the mode dial to Tv, then use the right/left buttons to select the shutter speed.
Now before pressing the shutter button, may I also suggest that you use the camera's shutter delay timer to take the picture (this will eliminate any shake from you pressing the button). Just press the function button to bring up the menu. then find the timer setting (try 2 seconds).
Here's where you can download your camera's user manual if you want to read more on what your camera can do:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=221&modelid=9828#DownloadDetailAct
Jul 19, 2008 | Canon PowerShot A75 Digital Camera
Timer Help
I was just playing with this myself...
Hit the "FUNC" button and scroll (if necessary) to "Drive Mode"
Scroll right/left to select 10-second, 2-second, or custom timer setting. If custom, hit the "Set" button then select the timer delay and number of shots to take.
Leave the FUNC display on the screen when you hit the shutter release. It begins counting down when you hit the shutter button, so make sure you've got it pointed where you want it (preferably on a tripod, though any stable surface will do in a pinch).
Nov 22, 2007 | Canon PowerShot A510 Digital Camera
Cameras Logo
47 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
