THE FREEZER SIDE IS FINE BUT THE FRIDGE TEMP. IS AT 16 DEGREE CELCIUS FOR AT LEAST 1 DAY NOW. I HAVE MOVED EVERYTHING THAT WAS NEAR THE VENT BUT STILL DON'T FEEL ANY AIR MOVEMENT THROUGH TO THE FRIDGE SIDE. I HAVE CLEANED ALL DUST BEHIND AND BELOW THE FRIDGE. I HAVE TURNED IT OFF THEN ON BUT STILL NOT WORK.
SHOULD I TURN IT OFF COMPLETELY FOR A DAY TO DEFROST ANYTHING THAT MAY HAVE PLUG THE AIR FLOW BETWEEN THE FREEZER AND THE FRIDGE.?
Sounds like a defrost problem. Check to see if
there is any frost buildup in the back wall of the freezer. If so, it is not
defrosting as it should.
If
you don’t know what these are then unplug the machine and let the ice melt in
the freezer overnight with the door open. Then try it the next day, if is
cooling fine then you need to have a service person replace one of the above
items. If it still has a problem then it might be the compressor and you should
probably replace the machine.
