Question about Maytag 24 in. MDB3700 Built-in Dishwasher
Maytag mdb6000awb built-in leaking problem
My dishwasher is leaking from below the door on the right side (corner). Otherwise, it work fine. It just pours water out onto the floor when the machine is in operation.
I have found that by pushing a rug secured by my trash can against the panel locatd just below the door and on the right side, I can use the machine without any water escaping.
I can't visibly see anything wrong.
Do you know what I must do to fix the problem?
  • 487 Answers
It can be 3 problems. Most likely one is the seal from the acces apnel is leaking.
Or hinge of door is too lose or door seal.
My bet is on the seal for the acces panel.
HERE is drawing. However seal (#12E) is not drawn in.
You can also order the parts here and have them within about 3 days
Posted on Jun 29, 2008
Dishwasher is leaking water from underneath and collecting on the floor on the right hand side.
Posted on Jul 07, 2010
Maytag jetqueen door leak
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
dfg
Jul 06, 2010 | Maytag MDB9600A Jetclean II Built-in...
Leakage at the left side corner of the front door
Check the door gasket for proper seating. Try a new gasket.
May 25, 2010 | Maytag 24 in. MDBH970AW Built-in...
Water leaking out from right side of door
Leaking Dishwasher
heatman101
saggfhgs
Apr 28, 2010 | Maytag 24 in. MDB7000 Built-in Dishwasher
I have a Magtag dishwaher that is leaking out of the bottom right hand corner somewhere. It is at least 10 years old, works great otherwise. What should I do ? Is it an easy fix? Is it worth it to fix it...
I will assume the leak is at the front on one of the corners of the door. We had this problem and it appeared to be caused by someone mistakenly placing too much weigh on the door when it was open. Our solution was to bend the door back in the opposite direction to get it "re-aligned". Hope it works for you too.
Regretfully ours just died after 10 years of service. Hoping to find a repair manual online.
Dec 29, 2009 | Maytag MDB7100AWB Dishwasher
Dishwasher door leak
Hi
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Also,The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
A Fixya rating would be appreciated if you have found this solution Helpful.
Thanks
Rylee
Feb 10, 2009 | Maytag 24 in. MDB6100A Built-in Dishwasher
GE DISHWASHER LEAKS AT LEFT CORNER
Have the same dishwasher and happens sometimes to mine when the door doesn't close properly because it is hitting the cabinet front. Try pulling up and forward from the bottom of the door when it is closed. if the bottom comes forward this could make the difference and stop the leak.
Jan 25, 2009 | GE Nautilus 24" Built-in Dishwasher
Maytag quiet series 300 leaks from front
check the float switch on the righthand side on the bottom in the corner it should click and move freely
Dec 16, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Maytag 24 in. MDB3700 Built-in Dishwasher Logo
764 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
