Question about Daewoo DVDS151 DVD Player
Dawoo DVD Player
The DVD will not play any dvd's, hook up is good but will not play on TV.
  • Anonymous Mar 18, 2014
    my little girl wants to see her dvds but i hook up the wires to the tv and nothings playing.
  • 4 Answers
Change mode on tv to vidio. the input jacks are dead otherwise
Posted on Sep 02, 2008
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
How do you get dvd player to play? put dvd in and
there is a wire comming off the back of the radio that should be wired to an emergency brake put the emergency brake on and play movie or remove wire from emergency brake and just hook it to a good ground basically all it is is a ground wire that when the ebrake is not engaged it does not make a connection to keep you from using the tv while you are driving because it is ilegal to have the tv playing while ur driving all you need to do to bypass it is find the wire and just ground it to a solid ground if you had an install shop install the radio by law they have to hook it up properly or you can ask them to leave it and you can hook it up they can not hook it up so that the player plays all the time hope it helped
Feb 27, 2010 | Dual XDVD8181 Car Video Player
Connecting a Dvd dawoo Model DV6T844B to the TV
Easiest way is to use a SCART connector from AV1 to the TV
Jan 30, 2010 | Daewoo DV-6T955B DVD Player/VCR
How to hook up my dvd
I'm assuming you have your video 1 hooked up for your cable. I would use video 2 for you dvd player. Use the rca connections, yellow, red, white. plug it into the video 2 slot on your tv and hook the other end on your dvd player. you will have to change your input on your tv to video 2 to have your dvd player work.
Apr 05, 2009 | Samsung LN40A550 LCD TV
Playing movies from external hard drive
Hi rox09
Well you can rip your DVD to any external drive using and third party DVD ripping software ,once you do that you will get a AVI,MPEG and any common fomats your DVD player supports
Inorder to play those files in your DVD player ,you need the check whether your DVD has a USB input port or else if you laptop or computer has a S-video out put and your TV has S-Video input ;you can play directly from your laptop/computer to the TV using a S-video Cable which is available in any Computer shop.
I hope this helps
VJ
Mar 15, 2009 | ASUS Eee PC 900 Notebook
Can't get new DVD player to play
On some sets there is a button on your remote marked "TV/VIDEO" or some such text. With your tv and player hooked up and working, pushing that button will switch from TV to video and back.
On other sets, if you keep changing channels, you will eventually come to one that turns off the video broadcast and plays the DV.
Good Luck
Mar 13, 2009 | Sanyo Televison & Video
Technically challenged...need DVD to show on TV screen
hey 1st of all you gotta make sure that your son made tha right connections with the av cable (this is the cable with three different coloured pins) from your DVD to your tv. if this doesnt solve your problem then make sure you are using the correct av channel on your tv set that will allow you 2 play your DVD player because sometimes you cant play your DVD on thhe same av cannel you watch normal tv
Jan 01, 2009 | Pioneer DVR-520H DVD Recorder
Tv/digital converter box & vcr-dvd hook-up
I have a vhs and dvd player all in one
I have a converter box hooked up to my tv and vcr , dvd player combined
I can play my movies on the tv. ok.
you have to have your tv and vcr set on channel 3. if that is what your main tv is set up with. Or 4 if you have your tv set up with that.
Mine plays ok. My settings are for channel 3
My suggestion would be to check your hook ups. maybe they are not hooked up correctly
I had to go to www.google.com and did searches to help with hook up.
I can also record station I am watching with vcr on vsh tapes. I do not have a dvd recorder.
I found out that you have to have 2 converter boxes hooked to one tv., in order to record on on station while watching another. I have not tried that, as I don't have 2 converter boxes for one tv. I found that by doing google search also. Good Luck
Dec 04, 2008 | Televison & Video
Daewoo DVDS151 DVD Player Logo
178 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
