Question about Nintendo Wii Console
Wii Remote Sensor bar is intact and unchanged. Any other ideas?
  • Anonymous Jul 01, 2008
    my wii remotes will not connect to the console, and I cannot figure out why. I believe it is in the sensor bar but i'm not sure.
  • atomickred Sep 29, 2008
    same here the lights start flashing but the remote doesn't sync
    President:
  • 4,402 Answers
Resync the remote
Posted on Jul 01, 2008
How do you re-align a Wii remote?
To Adjust the Wii Remote Pointer Sensitivity, follow these steps..
Wii
  1. Access System Settings.
  2. Select "Sensor Bar."
  3. Select "Sensitivity."
  4. Aim the Wii Remote at the television.
  5. Use the + and - buttons on the Wii Remote to adjust sensitivity until only two blinking lights appear.
  6. Press the A button when done.
Wii U
  1. From the Wii U Menu, select "System Settings."
  2. Using the Left Stick, scroll to the "Wii Remote and Sensor Bar" icon and press the A Button.
  3. Select "Adjust Wii Remote Pointer Sensitivity."
  4. Tap "Next."
  5. Point the Wii Remote at the sensor bar and press the A Button.
  6. With the Wii Remote pointed at the sensor bar, press the - and + Buttons to adjust the sensitivity so that only two white dots are visible in the black window.
  7. When you are finished, press the A Button.
  8. On the Wii U GamePad screen tap "OK."
Please
Dec 14, 2017 | Nintendo Wii Console
My wii isn't showing the wii hand on the menu screen or anywhere else so i can't get to anything, so can you please help me.
Make sure the Wii Sensor Bar is correctly plugged into the Wii, and that the Wii Remote has an unobstructed path to the Sensor Bar. Move the Wii Remote around, as the positioning of the Sensor Bar may not be exact. If you've done all of this and the problem persists, it may be that your Wii Sensor Bar is damaged. You may have to buy a new one.
Aug 19, 2011 | Nintendo Wii Console
Wii controller is not working, no lights at all coming on
Try this following steps: 1. Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen. 2. Make sure you are using fresh batteries in the Wii Remote. 3. The Wii Remote Controller should be used between 3 to 10 feet from the TV. 4. Make sure no objects are blocking the signals between the Sensor Bar, the Wii console, and the Wii Remote. 5. Check for interference from infra-red light sources, such as candles, sunlight, fireplaces, and stoves. 6. Radio frequency interference may cause the Wii Remote to work erratically.
Mar 30, 2011 | Nintendo Wii Remote Controller
Cannot get curser to show on screen
This could very possibly be an issue with the sensor bar. Try these steps:
  1. First, ensure your sensor bar is plugged into the console and oriented properly! Take a look at this picture to see how it's supposed to be facing (NOTE: you will NOT see the purple lights even if your sensor bar is working!! These are ultraviolet lights and are not detectable to the human eye!) Click here for the picture.
  2. Make sure your Wii remote is on and has new batteries! Older batteries decrease the strength of the light that the Wii remote gives off that it uses to communicate with your sensor bar.
  3. Assuming these things work, consider increasing the sensitivity of your sensor bar. Directions for how to do this have been posted online by Nintendo here.
If none of this works, chances are there's something wrong with your sensor bar, Wii remote, or a combination of both. Replace the sensor bar before replacing anything else. If that doesn't work, get a new Wii remote. Good luck!
Mar 12, 2011 | Nintendo Wii Console
Console not responding. have changed remote and sensor bar
This information comes directly from Nintendo's website. Hope this can be of help:
First, follow these guidelines to ensure you have set up the system properly to have the optimal environment in which to use the Wii Remote:
  • Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen (more info).
  • Make sure you are using fresh batteries in the Wii Remote.
  • The Wii Remote Controller should be used between 3 to 10 feet from the TV.
  • Make sure no objects are blocking the signals between the Sensor Bar, the Wii console, and the Wii Remote.
  • Check for interference from infra-red light sources, such as candles, sunlight, fireplaces, and stoves.
  • Radio frequency interference may cause the Wii Remote to work erratically. Check for wireless devices such as cordless phones, wireless computer keyboards or mice, or other similar devices, and move or turn them off.
Verify Sensitivity Setting dots:
Go to the Sensor Bar's sensitivity setting in the Wii menu.
  • If only one or no dots appear on the sensitivity screen, there is likely a problem with the Sensor Bar.
  • If there are more than two dots, then it appears there is an additional light or infrared heat source being picked up by the Wii Remote. Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
Jan 02, 2011 | Nintendo Wii Console
Wii remote cursor not showing on screen
My only idea is to check the batteries in the sensor bar. Placement of the bar (above or below the TV) never had an impact on the cursor in my experience.
Jan 03, 2010 | Nintendo Wii Console
Sensor bar inactivity on the wii videogame system
First you Should test with another sensor bar...try to take it from a friend to test it in your system...could be cracked wires from the sensor bar....try to test the wires with a multimeter and resolder the wires from the cable...or you can take your sensor bar and test it in another wii...you need to known if its really bad ,or if there is something wrong with your wii system...
Sep 09, 2009 | Nintendo Mini Wireless Sensor Bar for Wii
Wii Remote Turning Funtion Doesn't Work on Mario Kart
Your wii sensor bar probably went out, replace it. They sell wireless ones at wal-mart for $20. If you want to make absolute sure that the bar is broken, take a video camera and take a quick video of the wii bar while it's connected and the wii is on. If you see four little blue lights on each side then you're wii bar is ok, if any are gone it should be replaced. The fact that all the buttons are still working means that your wii is still communicating with remote using bluetooth, but since it's not sensing any motion, it probably means that the problem is sensor bar related.
Aug 25, 2009 | Nintendo Wii Console
Wii
(1)
Verify that the cable bar sensor is plugged into the back of the Wii console and that the sensor bar is properly aligned with the centre of your TV screen.
(2)
Check that the Wii remote is synchronized with the console using the POWER button on the remote control to turn on the Wii console. (The POWER button is the white button with the red symbol which is located in the upper left corner on the Wii remote.) If it does not work, try to synchronize the remote control, then turn the console and controls that respond correctly to commands.
(3)
Verify that the distance between the Wii remote and the TV display to be between 1 and 3 meters, that there are sources of intense light that can interfere with the proper functioning of the remote (read Guidelines game for Wii for more information ) And that the sensor bar is placed correctly (see Setting up the sensor bar). Avoid the presence of sources of infrared light as electric stoves, gas propane or kerosene, candles, fireplaces, stoves or other heat sources close to the console.
If the steps described above do not solve the problem, the sensor bar could have a problem. Read the following instructions:
On each side of the sensor bar are five infrared lights that located the position of the Wii remote. If these lights do not work, the cursor on the remote will not appear on the screen and you can not step through screens of settings. To see these lights, you must look on the LCD screen of a digital camera or a mobile phone. Verify that the sensor bar is connected and that the Wii console is turned on, and then framing the bar sensor so that it appears on LCD camera or cellphone. If you see five infrared lights on each side, the sensor bar works. Maybe you'll need to slightly adjust the position / tilt the camera or the telephone, but is rather easy to see these lights on the LCD screen
Jun 22, 2008 | Nintendo Wii Console
Sensor bar / remote issues with Golf games
Has the sensor bar perhaps been moved? Is it becoming obstructed by furniture or something else?
Sep 09, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
109 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
