Question about Maytag Neptune MAH5500B Front Load Washer
Rubber on inside has a three inch cut
Rubber on the inside of my washer has a 3 to four inch cut. I just noticed this and don't know if this will be a problem.
  • 481 Answers
Yes it is a problem, it will leak water if not replaced. it is a common problem and should not cost too much.
Posted on Jun 29, 2008
Kenmore Oasis HE 110.27082601. While in spin cycle washer is shaking and rocking to point it shuts its self down. Checked level - Good. Opened up, looks like the suspension rods are good. Anything deeper...
Buy a rubber pad at Tractor supply that they use for horses - cut it about 3" wider on all 4 sides and put under it - that should solve it. Not easy to cut, ask for the best way - it is hard rubber about 3/4 on an inch thick.
Nov 04, 2013 | Washing Machines
I have a kenmore series 80 washering machine. The washer begins the wash cycle mormal. About half-way through the wish cycle the washer begins to fill with water again. It will fill with water until to...
the water level control has gone bad,its located in the top of the washer control panel,four philips head screws gets you in there,make sure you unplug the machine,it has a rubber hose,and four clip on wires,one 1/4 inch screw holds it in place,its job is,it works off of air pressure from the rubber hose that comes from the washer drum,if it don"t read the back pressure from the drum being filled it will over flow.good luck
Nov 19, 2012 | Kenmore 24032\24036 Top Load Washer
How do you change the oil in the rear axile of a 4wheel drive 2007 tahoe
Hi, the axle has a drain plug at the bottom, removing this plug allows all old fluid to empty, put the plug back in, and tighten. fill back up with 2-3 qts of 75 synthetic weigt oil. Good luck...Coop
Dec 12, 2010 | 2007 Chevrolet Tahoe
Kenmore washer (110.92389200) drains, but will not agitate or spin; also, cannot turn the basket by hand. Where is the access for service?
check the motor coupling,take out the two screws that hold down the top console,flip up the console,unplug the lid switch harness in the middle or a little to the right from the middle and with a screw driver pop the two metal clips,tilt the frame to you and remove the whole frame of the washer.with a screw driver pop the two clips holding the pump on and slide the pump forward off the motor.take out the two screws and pop the motor clips and pull the motor forward,you'll see the motor coupling,there should be three arms coming off the coupling and three arms on the other part of coupling and a piece of rubber that they slide into,if it's cracked or worn in the middle replace the coupling and cut down on the size of the loads you put into washer.when putting the motor back on look at the four corners of the motor,if any of the rubber spacers are missing look where the motor goes and take the rubber spacers off the frame and stick them in the four corners of the motor and then line the motor up and install it,it's to hard to get the motor back if you don't do this.good luck and let me know what you find,if you need any more help let me know
Jul 31, 2010 | Kenmore Washing Machines
My main rubber seal ripped and i need to replace it how is the best way to get into it to change it out
1. Disconnect power from washer then remove the trim on top of the washer at the front (it is held on by three screws).
2. Remove the top by removing the three screws on the back.
3. Remove the soap dispenser.
4. Remove the control panel by removing the four screws on the top and one behind the soap dispenser. There are two clips on the inside right-hand corner of the case holding the control panel on you must press by reaching over the top to the inside.
5. Remove the bottom panel.
6. Open the door and remove the door latch by removing the three screws (don’t have to disconnect wires).
7. Using a screwdriver remove the wire clamp that holds the boot on in the front. This clamp is in the grove on the front of the boot.
8. Remove the front (door and all) by removing the four screws (one on each corner).
9. At the top of the boot there should be two hoses, slip the boot out from around the hoses.
10. Remove the bottom balance weight off the front of the tub. Note that this step is not necessary but will make the next step easier.
11. Loosen the screw clamp that holds the boot on at the back.
12. Once the clamp is loose, the boot should pull off.
13. Then resemble with new boot.
When reinstalling the new gasket there is a notch in the gasket that should line up with a arrow on the tub.
When reinstalling the gasket, be sure to properly install the hose .
It's a little tricky getting the wire ring back on your first time but stick with it you will get it.
Mar 31, 2010 | Whirlpool GHW9100L Front Load Washer
Do i need plumbers putty with the white and rubber large 31/2 inch washers with the 1135 strainer and where do each fit
yes you do. you put the putty under the chrome ring. the rubber and white gaskets go under the sink. i've tried without putty and it always leaked
Oct 29, 2009 | Kindred 1135 Standard 3 1/2 inch Basket...
Frigidaire front load Gallerry series washer model GLTF2070DS0
HI thanks for your question. repair clinic on line . part# or model # and they ship in 3 days good you can fix your self. thanks
Oct 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Whirlpool duet washer leaks from detergent drawer when filling with water
We just had the same problem. We took off the three screw on the back to remove the top panel on washer. From there we took the screws off the electric face plate on the front. Be careful, there is a screw located inside the door. You must open the door to get to the screw. Next we removed the bottom panel door and then the four screws to the mail metal panel on the front. Hold that panel because the rubber gasket is still connected. Then you will see a rubber hose directly under the drawer. Take the rubber hose off at the bottom nearest the drum. We found a sock that had wedged itself up and was causing a back up. After I cleared it, the washer works just fine.
Aug 08, 2008 | Whirlpool Washing Machines
Water Leaking from pre-wash and main wash cold water solenoid
We had the small leak problem. It was a cut in the bellows at the door. Lower side. We could see it if we just spread the gasket just inside the door.
Jul 14, 2008 | LG WM-2277HW Front Load Washer
Rubber circular tube inside front has hole
just get a new door seal for it.
On line they will not be to expensive
Jun 05, 2008 | Malber WD1000 Front Load Washer/Dryer
Maytag Neptune MAH5500B Front Load Washer Logo
47 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
