Question about Ovens
F1 error Dacor Oven
I have a Dacor double convection oven and F1 appeared continuously so I had the control board replaced per recommendation from the website---it is still happening. It beeps and flashed F1 every 10-15 mins . . all night long unless I set the oven to the lowest temp and just leave it there.
  • 413 Answers
I'm sorry but I am not familiar with Dacor ovens, the research I performed indicated that the ERC (clock module) has failed. You could try the oven sensor probe if it is a temperature related issue.
I truly wish I could help you further with your dilemma but am unable to provide any further information except search the web. Good luck....
Regards;
reg501
Posted on Jul 02, 2008
Keep the cancel button on the keypad pressed for 15 - 20 seconds before releasing it .
Posted on Apr 14, 2013
I'm getting a f24 code on my lower wall oven...what to do?
Hi. Error code F24 indicates that the controller has failed to communicate with the lower convection fan and oven lights control board. If the error code persists, I would recommend connecting with an expert repair tech to assist further and the display board may need replacing.
Sep 26, 2014 | Electrolux ICON 30 in. Double Wall Oven
F1 code GE profile convection self clean wall oven (95?) oven beeps F1 code oven works when it is on bake etc. when touch key are pressed it goes off but starts to beep again
Hi
F1 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Sep 19, 2011 | Ovens
What does a beeping sound with F1 symbol mean?
Error F1 means that your Dacor Oven indicates element relay circuit failure. To resolve this issue the control board should be replaced as it has gone bad.
Good luck.
May 13, 2011 | Dacor ECD230 Epicure Electric Double Oven
We have a dacor double oven that is not running and keeps giving us error message of F1.. Neither of the ovens will work.. Any idea what is wrong and how to fix it?
Hello & Welcome to FixYa
Error code F1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Please get back to me if you have any other questions.
Kevin
Feb 03, 2011 | Dacor Ovens
What does the F1 mean
Hi, the F1 error code means a problem with the System Watchdog Circuit..
Press "Cancel", if beeping continues after 30 seconds, replace the main control board (also called clock or ERC).
Nov 16, 2010 | Dacor ECS127 Epicure Electric Single Oven
F1 error
Failed control board(micro-processor) replace board.
Known Dacor oven problem-
Nov 21, 2009 | Dacor MCS130 Millennia Electric Single...
Dacor error codes
HI. the F-1 code is a System Watchdog Circuit failure code.
Concerning the F-5 code. This is an oven temp sensor failure code. have it replaced asap. ((Check the wiring leading to and from the control and sensor for cracks and fouled structure. if the wiring is bad, replace the harness as well)),
Apr 25, 2008 | Dacor ECS127 Epicure Electric Single Oven
Aogd2750e gas double oven
F1=Electronic range control failure
It is telling you may have a faulty control...need to replace control or EOC
Thanks
Dec 07, 2007 | Amana AOGD2750 Gas Double Oven
Ovens Logo
836 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
