First you have not indicated the brand or model but that aside the issue appears to be a bad micro switch or the keyboard with the controls on this set, I would suspect the source or TV video button first, not the plastic button itself but the tiny switch it activates, that is bad---have someone get at that and disable or remove that and the set should again function in a normal way.
The micro switches are momentary and should only operate when pressed, the problem is they fail, and with no one pressing the switch activates on its own.
I would suggest using a Power Scan to program the remote to this TV, if this doesn't work there is a compatibility issue. Power Scan 1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #) 2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once. 3.) Press the channel up button once per second until the TV turns off then press pound (#).
Roll the window down first, you will need 2 hands. Pull the small cover off that is at the top front of the door pannel. You will then disconnect the wire connector and remove the three 11mm nuts that are holding the mirror in place. Pull mirror out and replace.
If you dont have just that little pannel you will have to remove the door pannel. If you dont have power windows pull the cover out on the window crank and move it to the side, there will be a screw holding the crank in place. Remove it. If you do have power windows remove the window control switch plate (it will just pop up using a small screwdriver) and disconnect the wires. If equipped, remove the front door trim panel reflector or the courtesy lamp lens. Then remove the screws. DO NOT pull directly outward on the door pannel, something will brake. Remove the front door trim panel by pulling it straight upward.Lift and remove the front door trim panel. Then the nuts holding the mirror will be visible, remove and replace the mirror.
check connection at connection box under dishwasher behind lower pannel was ther power to the switch some dishwashers have a thermal fuse in the console white plastic whith two wires going to it
check your cables and your source IE the Cable box, if they are ok, then you need to plug in your source into where you are plugging your D.V.D, and your good to go!
if you dont have a cable box, get a Coaxil to digital splitter at "the Source be circit city!"
hi , To check wether the remote is outputting a infra red signal when a button is pressed try viewing the little LED at the top of the remote through your mobile phones camera , these little cameras pick up a fuller spectrum of light and you should see if flickering. IF you dont then check the batterys/. then the connectors for acid errosion from previous leaking batterys./pull the remote apart and with a pencil rubber clean the contacts on the surface of the circuit board/.The rubber membrain that has the buttons on wash it with warm soapy water , dry thouroughly.last test --go to mapplins and buy a replacement infra red led and change that? , see haow you go whith these tips and report back
The front pannel,on and off channels and vol. switches are going bad,if you dont use the front pannel, unplug the set and remove the back cover,just below the top screws you can look under and see the top of the picture tubes,in front of the middle tube is a little board about two inches wide and four inches long,unplug the right plug it has one black and five or so white wires,this is the top cable,then just use your remote.
