Motherboard I have a 17" HP DV9005US and was told I need a new motherboard. What are the costs associated with such a repair if the machine is 6 months after factory warranty
    Sergeant:
  • 284 Answers
If you did not get the extended warranty Im afraid you have to replace the Motherboard, but there some companies Like HP that will honor a YEAR warranty, you have to check with them email them or call them, they would let you know, usually around 200-300 dollars depends if the same motherboard is found.
most of the repair will be labor, mother usually runs from 80-150 USD.
Repair can run up to 40 to 140 an hour depending on the compamy you go to.
Good luck
Posted on Jun 30, 2008
Dv9005us mother board.
Laptop do not have the capability of a desktop computers that allow you to install various motherboards inside the PC case.
You can improve the performance by installing more RAM and replacing the hard disk with a solid state hard disk.
Dec 14, 2012 | HP Pavilion dv9005us Notebook
I have a HP Pavilion DV9418 17" laptop with AMD Turion 64 X2 Dual-Core TL-58 1.9GHz I am told by Staples it has a short in the motherboard where would I buy a new motherboard, hirst9@sympatico.ca
the best place to buy any laptop motherboard is Ebay. Most computer stores or repair shops they don't carry motherboards due to the vast option of brands/models and remember each laptop has an especific size, number of ports, etc.
Just keep in mind when looking for your motherboard make sure is for the CPU you have.
If you search DV9418 on Ebay you might get one for Intel CPUs and others for AMDs. If you have the motherboard's part number would be the best.
I hope this helps.
May 06, 2010 | HP (D7580-60003) Motherboard
HP Pavillion dv9005us screen stays dark
Lets start with the power, make sure it is charging by looking at the ring on the side that lights up when the power cable is plugged in. If this is on, then make sure the light on the front of the laptop is on. If it is charging and it is detecing power(2 lights will be lit) then you are okay with power. If the lights are not turning on, then it might be your charger. This is rare, but its worth a try. Get your hands on another identical one. Make sure the Watts line up or else you might blow something out. If it is not your charger, then it is probably an internal part such as the power plug or the motherboard. In either case, unless you really know what you are doing, then you would simply need to replace these. Before you order a new one online, keep reading.
[skip this part if your power is not working]
Pull out one stick of RAM, then try to start up. If this doesnt work, then try the other stick(put the first one back in). If that doesnt work, then try the hard drive. If this doesnt work, then try the wireless card an any other attachable devices(that connect directly to the motherboard). If this does not work, then the problem is in your motherboard and you will probably need to replace it.
[If your power is not working and/or it looks like you need a new motherboard, read this]
Be sure to contact HP first, they are doing a recall or as they call it a "service enhancement" to some of their malfunctioning laptops that are having motherboard issues. You might want to research what the service enhancement covers first. This will be important when dealing with the representative. Also make sure you try a lot of things with fixing it, even if it seems rediculous such as cleaning out the fan. The more it looks like you tried to fix it, the more likely they are to service your laptop under the 'service enhancement'.
Here is more info on the service enhancement. Be sure to read as much of it as possible. Sometimes the representative on the phone will try to say it isnt covered beucase it doesnt match the symptoms exactly. Try to show them as much as possible that it does fall under one of the defects listed and they will most likely fix it. This is a one time shot though, be sure you dont screw it up!
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&dlc=en&cc=us&product=3439691&lang=en
Aug 03, 2009 | HP Pavilion dv9005us Notebook
E Machine T6534 fails every 6 to 9 months
This could be caused by the processor or fan,But very unlikely to be the mother board.
May 28, 2009 | eMachines T6534 PC Desktop
Parts for a brother MFC-7420
you better double check that model number. i'm thinking you mean the mfc 9420.
razors
Feb 06, 2009 | Brother MFC 7420 All-In-One Laser Printer
Back screen with colored lines
Take it to another tech. If you get the same answer, then simply change your motherboard.
Sep 04, 2008 | HP Pavilion dv9005us Notebook
Power button light turns on and off continuously with no other signals appearing!
Just repaired one with the same problem. I finally installed new power button board, and motherboard. good luck and hope this will solve ur problem. By the way try the new power button board first it may save ya the cost of a new motherboard. Joe
Aug 19, 2008 | HP Compaq Presario C500t Notebook
Hp pavilion m7330n motherboard issue
The system in question requires motherboard model ms-7184 and can be found on ebay for less than $100.  If your repair guy used a different motherboard you will get the issues described and need to reinstall the OS.  It is impracticle to put any more than $200 in most desktop computers more than 2 years old, your repair guy should have advised you of this straight off.  Find a new person to take your equipment.
Jun 27, 2008 | HP Pavilion Media Center TV m7330n...
I need a new motherboard for dv9005us
hi can you click this site..........
http://search.ebay.com/search/search.dll?ht=1&from=R4&satitle=+dv9005us&sacat=58058%26catref%3DC6
Dec 13, 2007 | HP Pavilion dv9005us Notebook
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
