Master
- Posted on Dec 09, 2010
Re: My Bosch AquaStar 240 NG tankless began throwing an...
- Check for flue gas leakage around the top and
bottom seals of heat exchanger as well as the viewing window. Look for
any noticeable burn marks or warping of the gaskets. If a leak is
detected, seals will need replacing.
- Verify that venting
meets specifications outlined in chapter 3.6 of the installation manual.
Long vent lengths, incorrect venting material, venting with more than
three elbows, blocked vent or combination venting may cause this
failure. Verify backdraft flapper inside flue gas collector is not stuck
shut.
- Check flue gas limiter wire connectors for tightness. Clean with pencil eraser if any corrosion is evident.
- Trace wires from flue gas limiter to black connector. Verify the connection is tight.
- If
limiter is tripped due to overheating, it must cool down before error
will clear on the control board.
If your connections are good and the CO2 level has not been an issue in
the past you can start getting into replacing parts. Bosch technical
help water line may help a little but they will want all of the make,
model, serial number business as well as owner name before helping, at
all. If your unit can be repaired a good technician is the answer.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
