My linksys router keeps disconnecting - Computers & Internet
    Problem Solver:
  • 21 Answers
Sounds like configuration problem, Start from scratch and follow the instructions from manual.
Posted on Jun 29, 2008
Linksys E2000 keeps disconnecting
Disconnect the power from the linksys for about 30 seconds then plug it back and see if it stops dropping. Most times the dropping occurs if you turn the modem and router off at night then when you turn them back on the router boots up faster than the modem and that will cause it to drop. Power outages also will cause the problem if the router boots up before the modem.
If unplugging the router and waiting 30 seconds does not solve it then unplug both the modem and the router. Then plug the modem back in and let it boot up for a minute or two, then plug the router in and let it boot up.
Jun 05, 2012 | Cisco Linksys E2000 Advanced WirelessN...
Keeps disconnecting
A wireless router that keeps disconnecting can be caused by any number of things. Please click on this link and follow my instructions which may help solve your problem.
http://www.fixya.com/support/r3559120-wireless_router_disconnecting
Apr 19, 2011 | Linksys WRT120N Router
WRT120N---I keep having to disconnect my linksys, unplug all 3 wires on the back of the router, wait 30 sec...reconnect the router...try to get online...when it works then reconnect the linksys....what am...
Please disconnect and internet link and try to access the the Linsys WRT100 management page and see the logs why the router is loosing the connection. If you dont get anything then it might be some issue on the device. A reset may solve your issue.
Please be aware the if u reset the wireless Router you will loose all your configuration and you have to reconfigure the wireless Router.
Please press the tiny black button at the back/beneath of the wireless Router and keep pressing for 2 minutes. The sys light will start blinking slowly and then rapidly. then release the button and wait for 2 minutes for the device to boot up with factory default settings.
Once you are done you can connect to 192.168.1.1 ip address and it will open the your Linksys Router management web page where you can reconfigure your wireless router again.
Hope this will fix the issue.
Best Regards
Jan 01, 2011 | Linksys RangePlus WRT100 Wireless Router
Im having this kind of disconnection problems, before i was using a linksys router i dont have any disconnection problems but because my power adaptor for my linksys router burn out i already stop using it...
Hello
For the Linksys Adapter you can contact any of Linksys support center nearest you or get a compatible adopter from any electronic shop.
and for improvement of your router's signal strength, you may see my tip here http://www.fixya.com/support/r7245572-improve_signal_strength_wireless_network
Good luck, and do rate the solution if got help
Dec 15, 2010 | Edimax BR-6104 Broadband Router. One...
WRT54G keeps disconnecting itself, requires disconnecting/reconnecting power and running setup disk again to reconnect. System info: 12 mb/s cable broadband ISP, Motorola SB5105 cable modem, WRT54G...
Go to Administrative Page on your router at section Setup - Basic and activate: Keep Alive : Redial Period 30 seconds.
After that restart your router
Mar 04, 2010 | Linksys Wireless-G WRT54G Router
Why does the linksys wireless router ''WirelessG: keep going off/
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware. For instructions, click here
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Apr 05, 2009 | Computers & Internet
Linksys routers, several models keep disconnecting from the inter
My Linksys WRT160N keeps disconnecting also, it just started a few weeks ago and I do not have an answer yet, but I will try to keep this site posted.
Mar 06, 2009 | Linksys Wireless-G WRT54G Router
Unlucky
Hi Disconnected,
Go to the Linksys website, here,
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&pagename=Linksys%2FCommon%2FVisitorWrapper&cid=1166859837401&displaypage=download
Find your version, it shows you how, and download and update your linksys. That should resolve the problem with disconnecting,
Jan 05, 2008 | Linksys Wireless-G WRT54G Router
Linksys BEFW11S4 wireless router disconnects
upgrade the latest firmware to this router that will fix your problem..log in to linksys.com/downloads..and download the latest firmware version
Nov 18, 2007 | Linksys BEFW11S4 Wireless-B Broadband...
My router keeps disconnecting the internet
a blinking power light suggest that the device is already broken. Go to the command prompt and ping the roouter. If you can still ping it then i suggest to upgrade the firmware of your router.
Oct 27, 2007 | Linksys WRT54GX2 Wireless-G Broadband...
Computers & Internet Logo
161 people viewed this question
David Payne
David Payne
