Question about Canon PIXMA MP780 All-In-One InkJet Printer
00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 i get error#5100 while trying to install printer on dell computer530s printer wont install
    Problem Solver:
  • 10 Answers
Did you make sure you installed it off of a cd or have all the latest drivers if none of those works just reinstall if you can and see if that works
Posted on Sep 03, 2009
  • 103 Answers
Possible wrong drivers that are not compatible with your operating system... rarely does a printer not work on a fresh install unless you are not using the right software.
Posted on Aug 15, 2009
  • patrick
    patrick Aug 15, 2009
    possible wrong drivers that are not compatible with your operating system... rarely does a printer not work on a fresh install unless you are not using the right software.
  • 3 Answers
Chek the product registration code online ,check the network port and IP addresss and try to add IP address of printer manually ,if this also not works , try to restart printer than do the same process
Anil
Posted on May 10, 2009
Dell 725 printer wont print after windows 7 install
You need the correct drivers for the printer. Go to Dell's support page and download and install the Windows 7 driver.
May 27, 2010 | Dell 725 InkJet Printer
Dell Laser 5100
Means the Yellow Toner Cartridge is not communicating with the printer. If you've installed a third party yellow toner cartridge, go to the Dell Printer Configuration Web Tool to set the toner to non-Dell toner. If it is a Dell cartridge, the procedure is to turn the printer off, wait 10 seconds, and turn the printer back on.
Feb 24, 2010 | Dell 5100cn Laser Printer
Error code 010-397 dell printer 5100. Have change fuser and restart printer keeps coming up as error message
) The fuser gets very Hot!! Let cool for 10 minutes after turning off the power and unplugging the copier!
2) Pull the two blue locking tabs forward and remove the fuser unit. Reinsert and push back on the tabs to lock back into place. Sometimes just reinserting the fuser will allow the catch on the locking tab to function correctly and push the trigger on the sensing unit. Turn the copier back on and pray the error code doesn't reappear..
3) Mine reappeared. Evidently the catch on the fuser unit was still not pushing the trigger forward, causing the copier to surmise that no fuser unit was installed.
CBR Tech Solutions or http://www.cbrtechsolutions.com
Oct 14, 2009 | Dell 5100cn Laser Printer
Has 5100 error, wont print
5100 is carriage jam error. Open the cover and check the carriage road.
May 23, 2009 | Canon i80 InkJet Printer
Dell 5100 printer error code 009-380
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Mar 03, 2009 | Epson Printer
ERROR CODE 010-387 RESEAT FUSER
I had the same exact issue with my 5110cn printer. It turned out that the 5100 fuser is wrong for this printer and will not work. The 5110 has a circuit board on the inside and the 5100 fuser does not. Dell item number KX491 with a BCN # of 652423 works perfectly.
Hope this helps!
Jan 08, 2009 | Dell 5110cn Laser Printer
Prnter driver for Del 5100 cn - Need be Mac OS X compatible
download Gassan-Mac-9-MR2RC2.sit from dell site (printer site, drivers, mac os) and unpack it with stuffit expander.
it contains drivers for mac os 9 and mac os x.
then just install it and select driver from the list when adding modifying printer
Sep 03, 2008 | Dell 5100cn Laser Printer
Service error 5100
may be the driver are not installed correctly ... just try reinstalling the drivers ... and make a check that you have inserted the ink cartilage or not ...
if not insert it and then give try ... it may work ..
if problem persists then call the service rep ...
Feb 07, 2008 | Office Equipment & Supplies
Canon PIXMA MP780 All-In-One InkJet Printer Logo
187 people viewed this question
old marine
old marine
