Question about PfaFF Tiptronic 2030
The shuttlecock on my Pfaff 2014 does not stay stationary like it used to. Can you help me with this problem?
  • Paris Lovespeople
    Paris Lovespeople Mar 30, 2012
    what are you referring to as a "shuttlecock"? The rotary hook? Feed-dogs? or bobbin mechanism? there is nothing on a 2014 i remember called a "Shuttlecock", i looked on the Pfaff parts sights and can not find a part called that either?
    Scholar:
  • 41 Answers
Let me see if I'm understanding what's happening.
Do you mean that the housing around the bobbincase/bobbin area is turning round and round, then something has definitely come loose and should be taken care of by an authorized Pfaff technician. Unfortunately if this housing has come loose, the whole machine timing may now be off and attempting to sew could damage your machine further.
Hope this helps - please don't hesitate to respond back if you have further questions. We're always happy to help.
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Posted on Dec 03, 2008
I have a pfaff 213 sewing machine and want to know what category to look under to get a couple of different feet. Machine is old but works well.
The following link should be helpful--your machine model is listed at the bottom of the page:
Pfaff Presser Feet
Your machine:
"The following Pfaff models use low shank and snap on Generic presser feet, you will need to purchase the Generic Pfaff snap on shank to use the Generic snap on feet."
Your machine uses the same low-shank presser feet as the Model 211:
http://www.sewingpartsonline.com/pfaff-211-sewing-machine-parts.aspx#filter:ptype_gmcfeed_1:$2520Presser$2520Feet
Jan 13, 2017 | PfaFF Sewing Machines
The presser foot on my Pfaff Tipmatic 6122 will not stay down, so the fabric will not feed.
It sounds like the pressed bar is sticking and will not push down completely and is difficult to lift. I have come across them many times on the older pfaffs. Unfortunately that is not sometime that can be fixed at home. It is caused by the lube going bad inside the pressed bar that lubbricates the spring that is inside the pressed bar. Find a pfaff dealer that knows about older pfaffs and they should be able to help.
Nov 15, 2016 | PfaFF Sewing Machines
How does the pfaff4.5 compare to Viking ruby?
check with consumers report we have no idea here
Aug 06, 2015 | Sewing Machines
How do I engage the bobbin winding gear for Pfaff 7570?
To disengage the needle while winding a bobbin do the following: the handwheel on the right end of the machine has an inner knob. hold the outer rim of the handwheel stationary as you rotate the inner knob counterclockwise. Also make sure the bobbin winding peg is pushed over to the right and the bobbin is seated on the peg.
Jul 27, 2014 | PfaFF Creative 7570
Hi I have a pfaff industrial zig zag 428, the bobbin has stopped all rotation
bobbin case should be stationary, bobbin itself is rotated as thread unwound, check hook timing. Simply turn hand wheel towards you and watch needle go down, when it reaches lowest point turn it slowly until needle rises 3/16" or so. Hook should be behind needle and slightly above eye.
Feb 12, 2014 | PfaFF Sewing Machines
Pfaff 2014 bobbin casing has thread - needs to be removed - how?
I had this problem with my 7570. I kept trying to wiggle the hand wheel. Took everything apart I could to get at it. Finally after many try's it moved and I was able to use a tweezers to get the tread out. A friend suggested applying a drop of oil to the bobbin case and letting it sit. She said it would desolve the thread some so you could move it.
Apr 03, 2013 | PfaFF Sewing Machines
Bottom thread from theh bobbin is in big loops.
Problem with Brother CS-8150 Computerized Sewing Machine
bottom thread from theh bobbin is in big loops.
I have a CS-8150 as well -it was fine until I decided to clean the shuttlecock and I thought I had put it back correctly. However, it was after replacing the shuttlecock in place that my bobbin thread was making big loops and no matter what tension it kept doing it. So I removed everything out of the bobbin area. Cleaned and made sure that the shuttlecock was exactly in place as per the manual. Guess what it does not make big loops any more.
Just a suggestion.
Sep 09, 2011 | Brother CS-8150 Computerized Sewing...
I have a pfaff 1473 the display blinks on and then off. The display stay stays off
Mine is doing that too. According to the manual, you need to replace the fuse. I'm having trouble locating where the fuse is though.
Dec 26, 2009 | PfaFF Sewing Machines
Pfaff 7550 synchronizer
Hi Britt,
Pfaff repair parts are only available to authorized Pfaff service technicians. You can locate your local dealer using Pfaff's Dealer Locator.
Hope you are able to get ***********'s machine up and running soon - not fun to be without!
Happy stitching,
Kim & Linnette
Nov 22, 2008 | PfaFF Creative 7570
Sewing Machines Logo
143 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
