I want to reset my ports. - Computers & Internet
  • brixtonman Nov 26, 2008
    i do not know my macbook password
    Problem Solver:
  • 21 Answers
What kind of operating system.
Posted on Jun 29, 2008
How do i restore the settings on my nextbook7
Reset Port is provided on the back lower-right-hand corner of the Nextbook.
This Reset Port is a helpful tool because it can provide an immediate refresh of your Nextbook.
This reset and refresh can be opportune when:
  • There are many applications running at the same time or
  • When an application encounters a screen resolution variation, or a pause in wifi connection.
This Reset Port can be depressed in by a thin metal object such as a small paperclip.
This provides an immediate refresh of your device.
After depressing the reset port, simply power the Nextbook on and you are ready to go.
Sep 04, 2014 | Tablets & eReaders
I can't remember my password
A Reset Port is provided on the back lower-right-hand corner of the Nextbook.
Mar 21, 2014 | Nextbook Tablets & eReaders
Reset my ethernet switch 16 port
There is nothing to reset. Just plug and play. Besides a defective port or cable, the problem must lie elsewhere.
http://ebookbrowse.com/enh916p-nwy-usenv4-user-manual-pdf-d182075502
Dec 09, 2012 | Encore 16-Ports 10/100 Fast Ethernet...
I want to reset using RS323 port , i forgot its ip adress
Hi
You can reset the device through RS232 port then please follow the below steps.
You need a laptop with Console port and a console cable for EOC-8610 EXT, You really dont need the IP address if you want to do it via console (RS232) interface.
1. Connect the console cable one end to EOC-8610 EXT RS232 port and other end to Laptop serial port.
2. Open Hyper terminal and select com-port option and then provide the username and password for the device management.
3. Go inside the system menu and select Reset Factory default.
Remember if u set to load the factory default settings, the device will loose its config and will boot up with factory default configuration.
Nov 03, 2010 | EnGenius / EOC-8610 EXT / 54Mbps /...
When using hdmi outlet,,,the picture comes in for 1 second then screen turns all green
That HDMI port hub it properly shorted,tries used another HMI ports hub?Tries to reset the tv back to factory setting,by unplug,replug it an hour later,go to the tv menu go to PICTURE,go down to reset.So the Tuner board reset itself back to the factory setting,all the HDMI ports hubs,should work now or that HDMI port hub is shorted,or the Tuner board it dead.
Jun 11, 2010 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Router does not work need to try to reset before i go and get a new router how do i reset router / dynex 5 port 10/100m router
very small button near ports mine is small square buttong SOME are inset hole you push a paper clip into hole for reset
eh?
Jun 11, 2010 | Dynex 5 Port 10/100 Ethernet Switch...
USB Port has failed; 4E00:032B
Electrical surge on hub port. Either a device attached to the port, or the port itself, has drawn more current than allowed, and the hub turned off the port. The port will not function correctly until you reset it. If the device is the cause, it must be detached before resetting the port. To reset the port, disconnect the device, and then click Reset in the dialog box. If the port is the cause, close the dialog box, and do the following to re-enable the port:
Disconnect the hub.
Re-attach the hub.
If it is the root hub, unplug all attached USB devices from the computer, and (if they have power supplies) unplug them from the electric supply. After a few moments, reconnect the devices. The computer can be restarted at any time.-->
Dec 22, 2008 | Dell Inspiron B130 Notebook
Wont turn on reset button?
Sounds like damage to the USB port. Did the phone ever charge?
Look into the USB port and check for bent connectors - you may be able to straighten them. To reset - unplug AC and battery and press and hold the power button for 6 secs.
Dec 09, 2008 | ASUS Eee 4G Notebook
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
