PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Screen Goes Blank on Gateway Laptop
By mikedilworth on Jun 29, 2008
I have a problem with my Gateway M-1625 Notebook which uses Windows Vista Home Basic. The problem is that screen sometimes goes blank right when I'm in the middle of doing something. I can't get it to turn back on. The computer won't go into sleep mode. I've tried leaving the computer alone, and nothing happens. The only thing I've been able to do is to turn off the computer by holding down the power button.
This has happened both when I'm running on battery and when I'm using A/C power. I think everytime this has happened was while I was connected to the internet. I originally was using AOL dial-up internet connection and recently switched to People PC (this issue has occurred both before and after I switched ISP).
Same Problem
Feb 23, 2009
-   It is most definitely an overheating problem. For me it only happens when the power options control panel is set to high performance. It never happens on the power saver setting. But that also means all my applications run slower.-   Guest
Jan 28, 2009
-   Gateway laptop after post i get black screen with white blinking curser , I can get into bios just fine.-   hobertlangle
Dec 11, 2008
-   I have almost the same issue on my gateway. Im told it needs a new display card, as this ones failing. But it never fully dies... -   GnGklinger
Dec 08, 2008
-   Have a gateway M - 1625 and the screen goes blank and have to press power button to restart the computer. Seems to be hapening more frequently.
WTF?-   Guest
Dec 06, 2008
-   mine just shuts off randomely. seems to be a common problem. i was worried it was a srious virus but now i dont think thats the case. i think these laptops have crappy fans in them and just overheat. ive noticed sometimes my fan sounding like it turns on then off repeatedly never really kicking on fully.-   minsmeat3
Solution #1
posted on Jul 02, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Same issue here, I'd report to gateway and try to get some free stuff ;).
Solution #2
posted on Jun 30, 2008
Not Rated)
bryanbahr
Rank: Apprentice
Rating: 0%, 0 votes
I have the same computer and experience the same thing. I have noticed it happens more often when I am laying down with the comp on my chest, which leads me to believe its an overheating thing. Sometimes it completely shuts down, but mostly the display just goes blank.
Whats been working for me is shutting it for a moment, (it doesnt sleep) opening it back up and pushing the power button a few times, varying the timing on how long I hold it down.
If you hold it too long it will shut the comp down.
Just fiddle with it.
Just worked for me 5 mins ago.
Bllsht that it happens tho.
Was this helpful?
Yes
No
Solution #3
Not Rated)
freetek
Rank: Wiz
Rating: 85%, 1770 votes
I would suggest connecting your laptop to an external monitor via the VGA port to see if the system is causing the problem or the display section.
It sounds like the latter.
If it is, then it could be a premature failure of the backlight lamp or the circuit that drives it, either will be less costly than a processor or main board repair.
BTW, I am desperately looking for an affordable replacement (we are very rural) for People PC; it is the lousiest ISP I have ever had and am really tired of their buggy software which never seems to improve and complaints are either ignored completely or given lip service by suggesting ineffective, stupid, fixes.
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
cannot open CD room and cannot start computor to get into operationg system can get into BIOS area... (More)
Answer
what is the problem of my HP laptop is going to blink2x his display in screen?
Answer
I have bought a new Acer Aspire 5810TZ with a DVD Super Multi double layer drive. I'm probably being... (More)
Answer
i want to increase the contrast on my aspire 5610 lap top
6 Other Users Have The Same Problem - Continued
Comment by annette0465, posted on Jul 05, 2008
i have the exact same thing happen and since i had powered off so many times while it was actually still running and it did not shut down properly it corrupted some files and was unable to run chkdsk so i had to do a system recovery and lost my data files.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Laptops:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
