Question about Panasonic Audio Players & Recorders
Sa-h91 center unit, se-b91 seperate amplifier they were both hooked u working fine and just shut off amp still turns on so does center unit but no sound will go through
  • iori003 Jun 29, 2008
    broken receiver or amp
marsrover
  • 682 Answers
SOURCE: hook up pioneer stereo amplifier model SA-1270
for audio system always you have left and right channels.
get the output (left&right) from tuner---go to equalizer input left&right.---from equalizer output go to amplifier inputs.and certainly from amplifier output to speaker.
Posted on Mar 11, 2008
merle840
  • 113 Answers
SOURCE: Alpine CDA-7873 (Same as CDA-7876 basically)
the blue line from the radio harness does not have power when the cd or aux are being used and the amp is not turning on-wire the remote line from the amp to the red line and your amp will stay on and you will get sound
Posted on Mar 27, 2008
marsrover
  • 682 Answers
SOURCE: My technics se hd 51
please bring a good contact cleaner from radio shack near you and apply the spray over the socket of the headphone(the place where you put your headphone jack)take headphone jack out and apply spray in and insert the jack in and out many times.-also check your system setup and confirm that all speaker are on- no mute button pressed-no cable is disconnected.
Posted on Jul 13, 2008
SOURCE: bose lifestyle model 5 music center
Bose lifestyle 5 series III does not play any CD or DVD, it keeps saying unsupported formated . Can anyone offer suggestions.
Posted on Aug 02, 2008
  • 4234 Answers
SOURCE: Hi there .......my sa gx303P
These units are designed to only run the fan when necessary. If the unit is overheating, there is a problem in the detection circuit. This is a relatively inexpensive repair. If you are getting overheating when running at a low volume, it suggests that the speakers are not matched to the amp. In other words, the amp is expecting an 8 ohm load and is being presented a lower ohm load. This makes the amp work harder and generates more heat. Check the speaker wires and make sure that they are not frayed or crossing in any manner. Also, verify that the rating of the speakers is correct.
Update this with what you find.
Thanks,
Dan
Posted on Dec 02, 2008
NHT sa-2 amplifier won't go into standby mode after 10 Minutes of no signal
Does the NHT sa-2 have it's own pre-amp? Because I'm wondering if the power off only works when it's own pre-amp is used? So when your receiver is connected it's shut off.
You could try something connected to it's own pre-amp (if it has one) and see if it goes off when there's no signal from that.
Jan 30, 2015 | Audio Players & Recorders
How do i hook up a amp to my 2000 ford taurus se
For you to connect an amplifier to your car stereo, try looking for the RCA pre-outs. It is very standard to all head units for you to use an external or seperate amplifier. Use RCA cables to connect the RCA pre-outs of your car stereo to the amplifier.
Jun 30, 2011 | Car Audio & Video
I have a GK Backline 600 bass amp with an intermittent pre amp problem. Sometimes it works fine then starts distorting. One odd thing i've noticed when I shut it down, about 7 seconds later the clip light...
This is not a problem with dirty components. There is a semiconductor inside that is sensitive to heat and is failing. This unit should be taken to a service shop before complete failure. It has the potential for frying the output section depending upon the part that fails.
Please seek professional assistance with this repair.
Dan
Apr 06, 2011 | Audio Players & Recorders
Not powering up
is the REM wire from the unit hooked up to the amp?
Aug 11, 2009 | Kenwood KAC-8402 Car Audio Amplifier
Amp shuts off when switched from radio to cd
your amps rem wire is hooked to the power antenna wire on your head unit and so when you turn off the radio you would nolonger need an antenna so it powers down and would lower the antenna.Depending on the head unit you should have one output for the power antenna and one for the amp rem......If your head unit doesn't have the rem output you can wire it to the switched wire that powers your head unit but keep in mind the amp will stay on while you have the key in acc or run position even if your head unit is off.
hope this helps!
Jan 16, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Technics SH-AC300 Connection to Power Amp & Pre-Amp
Hi!
The problem is, that your SH-AC300 needs an amp with 5.1 input (but no decoder). For this purpose technics delivered SA-AX710.
So if you'd like to use your current equipment it would be impossible.
The only option is for you to buy 2 more Power Amps (SE-A900S), so that each of 3 amps would take care for one part of music. (one for FL, FR; one for RL, RR; and one for sub and center).
Another option is for you to buy SA-AX710. Then all the problems would be solved with it.
Jan 15, 2008 | Technics SA-DX950 Receiver
Jl amp
the overload protector of your unit it so sinsitive try to cutof the overload relay and then observe 20 min. monitor the allominum heatsink the temp. normal
Aug 27, 2007 | Jl Audio 250/1 Car Audio Amplifier
145 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
