Question about Haier hwr10xc6 Air Conditioner
No cold air on a/c
A/c has no cold air coming out. just sum cool air. temp stops at 77 - 80. bought this a/c last summer. only used it for about 2 months.
    Sergeant:
    Champion:
  • 330 Answers
1. check the fan
2. maybe some place leak
3. Do you still have the warranty?
My central AC had the same problem, lost the freon R-22
Posted on Jul 03, 2008
I have a LWHD1500ER. It runs fine, the fan works pretty well, it runs through it's cycles( on then turns cooler off then back after awhile.) but it isn't cooling, the air coming out is not very...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 28, 2011 | Heating & Cooling
I have lost my manual for my bio tech plus air con. my air doesnt seem to be cold at all, not sure if i have right setting, on the remote there is a sun, snowflake auto and i think a raindrop, which should...
Dear friend, find below symbols for mode setting. For cool keep minimum 3 degree less than room temp and heat keep minimum 3 degree higher than room temp. Dry mode will help you only in wintertime. Thanks.
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.Helpful?
Feb 01, 2011 | Heating & Cooling
Unit comes on and shut off correctly but dosen't heat and cool home equally. Blows cold air in winter and doesn't cool home properly in summer.
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks. To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 09, 2011 | Intertherm Heating & Cooling
Cool air comes out when the heat turns on. When I switch to Em heat, warm air comes out. Over the summer the air worker great, however when I switched to heat on the thermostat, cool air came out. Why?
Check the following. 1. Your setting temp must be higher +3 than room temp. 2. Check heating sensor.3. And also heater element.(If it's reversal valve, checke RV is working)
Dec 12, 2010 | Weather King 10AJA3601AH Air Conditioner
A/c stops blowing cool air after 90 minutes to 2 hours driving
sounds like it has a slow leak in it i would put dye in it and drive with it on for about 3 days and take a light see if u see dye comeing out anywhere
Jul 19, 2009 | 2004 Dodge Intrepid
My Whirlpool window a/c is not cooling as well as it did last sum
I know it has been at least a year since your post. I am answering the post to terminate FixYa site activity on the post.
Remove the front cover. Check the routing of the temp sensor wire. It should go from the bottom of the control panel to the plastic clip in the evaporator coils. If it is touching the eavporator coils it will sense the refrigerant temp and cycle off early. If the unit is freezing up there is a restriction in the coolant lines and usually will require the coolant system be purged of foreign internal debris.
Thanks for choosing FixYa.
Kelly
Jun 25, 2009 | Whirlpool ACC108PS Air Conditioner
MY HAIER A/C IS NOT GETTING COLD
I have a fairly new Haier Air Condition that I bought last year, it has been working good up until last night. I keep this one in my bedroom and put it on every night since the summer. Last night I woke up very warm, the temp reading was 75 the AC did nothing but blow out just air. I threw away the booklet on it because I've had no problem up until now. Does anyone know how I can make it cold again. HELP!!!!
Jun 22, 2008 | Heating & Cooling
Haier hwr10xc6 Air Conditioner Logo
117 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
