Question about Samsung HCN4727W 47" Rear Projection Television
Samsung HCN4727W 47 in.
I'm sorry , I don't understand the solution?
All I'm getting is a flashing red light, 10 times, then shut down.
No picture, no sound
  • 2,071 Answers
I mean that your unit is need of resolder or reheating of the solder joint of the parts.Supply section,horizontal section,vertical section and microprocessor IC.Improper distribution of current flow ,due to a loose contact or crack solder, that's your tv automatically signalling by flashing,that is the main cause of flashing . Find a tv technician to do works for you,,in order to avoid high voltage shock....
Posted on Jun 29, 2008
  • LORETO LACARON
    LORETO LACARON Jul 04, 2008
    cold solder issues - each component is soldered into small holes on
    the printed circuit board which in turn connects said component to the
    other components. Due to time, heat, use, some solder joints would be
    cracked or loose. It is possible that the cold solder is still
    minimally connected (hanging by a thread). When the TV turns on heat
    would be generated which would be sufficient to further loosen up the
    solder joint to the point it no longer provides electrical contact.
    Jarring the unit creates movement inside enough to re establish the
    contact, sometime good enough sometimes not enough.
    Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection,
    solder joints are "connections" except that molten soldering lead is
    used to attach/connect the component to the board, "loose connection"
    in this sense is equal to "cold solder".
    Again on the assumption
    of no defective parts, then seeking a more experienced buddy for the
    soldering might be to your advantage. This is of course in addition to
    the possible electrical hazards when repairing the inside of a TV unit
    for any lay/unexperienced repair person.
  • LORETO LACARON
    LORETO LACARON Jul 10, 2008
My samsung hcn4727w blinks red when i turn it on
either the lamp, ballast or power supply need to be replaced.
Nov 11, 2009 | Samsung HCN4727W 47" Rear Projection...
My tv when i turn it on i get a flashing red light
Their is no more you can do.
You need a professional.
Stop using the TV until it is repaired.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Samsung HCN4727W 47" Rear Projection...
Samsung HCN4727W
Convergence board shot. Cheap to fix yourself, board has two STK chips on it and is easy to get to.
May 16, 2008 | Samsung HCN4727W 47" Rear Projection...
No Picture
see if STK392-110 or similar are good. 2 big chip with cooler
Jan 11, 2008 | Samsung HCN4727W 47" Rear Projection...
Samsung HCN4727W 47" Rear Projection Television Logo
75 people viewed this question
Henry  Thomas
Henry Thomas
