Question about Shuttle 200W Internal Power Supply for Barebones (RP/PS-200E) (PSSHUTTLEPS200E) Power Supply
Computer won't turn on
My Shuttle has been working perfectly for years, but after being shut down for to month it refuses to turn on. I can turn the power supply on by shorting the green and black wires, but it won't turn on from the front of the case. The cable from the front panel switch to the motherboard is testing OK.
Any suggestions would be very much appreciated.
Many Thanks Ted
  • tnielsen Jun 29, 2008
    I have tested the battery and even tried a new one, but with no effect.
    Thanks anyway
If you dont want to buy a new PS just put a little on/off switch on the back side of the pc and turn it on when the power fails.That way you can start it an use it.
Posted on Apr 27, 2009
  • 36 Answers
Tnielsen
u did not said ur mother board vander name and chipset. because some mother board can not star if CMOS battery expire. remove CMOS battery check it voltage bellow 3V or not if it's voltage bellow 3V then replace it. and try to trun on ur shuttle.
Posted on Jun 29, 2008
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
IMac G5 17" won't shut down
I have minor shutdown problem with mail, won't close or shut down. My ans top left APPLE drop down, force closure, turn of each programme listed. For me works a treat.
Jan 19, 2013 | Apple Computers & Internet
I HAVE A 92 DODGE DAKOTA IT DOT TO WHERE IT WOULDNT START,IT WILL TURN OVER BUT NOT CRANK,IT HAS FIR TO PLUGS,AND TO THE COIL,AFTER IT SET A FEW DAYS IT STARTED TO CRANK,NOW WHEN DRIVING IT WILL SHUT DOWN...
The engine turning over & the engine cranking is the same thing,
are you not aware of that
You have a no start condition,failed fuel pump I would think
I owned a 92 for 18.5 years
Oct 05, 2012 | 1992 Dodge Dakota
My Shuttle Barebone K48 will not even power on.
Try to run it with only one stick of memory in at a time. If the memory doesn't work the computer won't even go into the POST. It only takes one failed stick to stop a computer.
Mar 07, 2012 | Shuttle KPC K48 Barebone
Hp laptop has blinking red square above touch pad, comp. won't allow for reboot or restoring to factory conditions
If you do an illegal shut down which is power off by holding down the power switch for 8 seconds. The HP computer will then boot with the scandisk program, which will restore your hdd to perfection. Windows XP or later now use 'system restore' to rearrange registry from a previous calender date that the computer used to work perfectly.
Feb 09, 2012 | HP Pavilion dv2911us PC Notebook
Shuttle fault
If the printer detects the shuttle moving at the incorrect frequency, it shuts down the shuttle and attempts to restart it.
If the shuttle still operates incorrectly after three consecutive attempts, the Printer goes Offline, and the Shuttle Fault message is displayed.
Press the Clear button, then put the printer back Online. If this doesn’t work, turn the power switch off, then back on again.
If the error is still seen after performing the above actions, check there are no paper jams , labels etc or ribbon jams that may prevent the shuttle moving correctly. Also check the Patten gap to make sure it is not closed too much.
Then you may need to change shuttle components
Dec 04, 2009 | TallyGenicom 6306 Matrix Printer
Shuttle shut down problem
go to BioS set up..
see to it if the CD Rom Drive has been detected..
if Not,,, try to connect again
...back to BIOS SET up
if it detect..save it...
then boot the computer until it pop up the windows environment..
double click "my computer " icon
if CD ROM has there..
your computer normally shut down..
Oct 19, 2009 | Shuttle XPC PC Desktop
Toshiba Satellite M-200 laptop refuses to start
I am sorry. This problem is best solved by doing a complete system restore of you laptop.
Do you have the restore disk that came with it?
Aug 10, 2009 | Toshiba Portege M200 Notebook
Shuttle 200W Internal Power Supply for Barebones (RP/PS-200E) (PSSHUTTLEPS200E) Power Supply Logo
357 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
