Question about RCA HD52W59 HDTV Projection Television
Cant find the code to set to my tv
The remote is grey with some yellow buttons it says on back i need a 4 digt code ? do u know what it is I need a code for the remote (oneforall big easy URC-4330B03) to set my satellite box it is a RCA Direct Tv receiver
  • 22 Answers
Here's a link to the manual in pdf format: http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=oneforall&dv=universalremote&md=urc43304devicebigeasy&kw=&st=&ar=&dt=&so=&pg=2&file=others/one_for_all/urc4330-manual.zip
Posted on Aug 19, 2009
NEED CODES 4 TWO COMCAST REMOTES 4 EMERSON COMBO DVD TV MODEL LD195EMX
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Oct 30, 2015 | RCA Televison & Video
Captions are on ther tv and i cant get into the menu. A message keeps popping up saying blog. fpa escend and i dont know what to do please help
Hello
Just reset your RCA tv by the following method. After reset you have to enter a new parential code and proceed.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the [0] button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Feb 23, 2011 | RCA TruFlat 27F520T 27" TV
Its a rca tv model # 20v500t serial # f075e5e61 i accidently set the fra lock or something like that in the menu screen and cant turn the tv back on and dont have the remote
Hello
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  4. Hold down EJECT button on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Jan 09, 2011 | RCA Televison & Video
I have a grundig Universal remote and need the code for a sanyo tv has to be a 4 digt code
Sanyo 0 1 5 4 ,0 1 5 9 ,0146
One of these shoild work for you
Please rate my help++++Thanks for using FIXYA
Jul 31, 2010 | Grundig Televison & Video
Haier HL26R COMCAST REMOTE CODE
what kind of comcast remote do you have please describe, black and silver, dta, and especially important what color is the OK/select button grey or red. If the Ok/select button is red the codes are 11034, 10768, if the ok select button is grey there are no codes, however you can use the search option listed below
step 1 press the tv button located at the top of the remote
step 2 press and hold the setup button located on the upper right of the remote until the tv button blinks red 2 times.
step 3 enter code 991 the tv button will blink 2 times again
step 4 alternate pressing the grey Power button then the tv button located at the top of the remote ( the tv will turn off when it finds the correct code)
step 5 press the Setup button when the tv turns off and the tv button will blink 2 times confirming the code is locked in
FYI this process can take quite some time but there is no direct code listing for the non dvr remotes.
Good Luck
Jun 20, 2009 | Haier HTF20R21 20" TV
Remote missing on old dominator garage door opener
This is the most complicated way I know of coding a remote and I am a tech. who does this all the time.
Turn power off. Wait 3 sec's & turn back on. Quickly press program button on back of box twice. Lights will flash, bottom light will stay on. Press program button twice, & No. 3 light will start flashing. Press and hold your remote button until light stops flashing. Code will be accepted.
Apr 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Universal remote code
I just bought one of those remotes to use on a Magnavox VCR because the buttons on the original remote are difficult to read (grey numbers on grey buttons).
The TV codes for Panasonic are: 0171, 0148, 0054, 0170, 0062, 0374, 0381, 0437, 0950, 0003, 0070. Good luck.
I had no luck with any of the codes given, so I tried the "Programming with Code Search" method and it worked.
1. Turn ON the device manually.
2. Press and hold the "P" button until the red light stays on.
3. Press and release the desired mode button (TV, VCR, etc.) The red light blinks, then stays lit.
4. Press Channel Up button repeatedly (up to 300 times) until the channel changes. (If you accidentally overshoot, press Channel Down to backtrack.)
5. Press and release the Enter button to set the code. (Mine doesn't have an "Enter" button, only an "ENT" button the left of the "0" and that didn't work, but I found the "M" button in the middle worked.)
Nov 09, 2008 | Televison & Video
Walthe universal remote control
i have the same remote....no instructions..please help
thanks
Oct 30, 2008 | Televison & Video
How to reset parental controls
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it’s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
Apr 29, 2008 | RCA 27V530T 27" TV
RCA HD52W59 HDTV Projection Television Logo
234 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
