Black Screen I have an Ipex notebook that displays a black screen. I have tried the following: Tried booting from CD no luck , it appears to be dead but all the other power lights are on. Cant get into BIOS or safe mode Tried to power from AC adapter still nothing No screen using an external monitor Taken the RAM, hardrive and battery for a few minutes still nothing (hardrive appears to be working). Even tried a new stick of RAM. Opened the notebook and all the adapters are in tack. Please help Regards John
  • 1 more comment
  • zdad Jun 30, 2008
    I have the same problem on an HP Pavillion N5350. Power light is on, CD spins when CD is present, but no LCD screen or external video signal. When I power it on I get three loud beeps (one long beep and two short beeps) then just the power light.
    This model has independent CD controls in front, which work fine and play the CD.
    Any help is appreciated. Thank You.
  • zdad Jun 30, 2008
    I have the same problem with an HP Pavillion N5350. When I power up I get three loud beeps (one long beep and two short beeps), the power light comes on, then nothing else. CD spins when present. This model has independent CD controls in front to use when Laptop is shut down. They work fine and play my music.
    Any help is greatly appreciated.
    Thank you.
  • zdad May 11, 2010
    I did try an external video display, it showed nothing as well.
  • 284 Answers
Try hooking up an external video source. Check to see if the computer is actually booting up. if the computer boots up, then the LCD invertor or Backlight of the screen is bad, need to be replaced.
If the computer does not boot up after hooking up an external video source, then most likely your motherboard is bad!
Posted on Jun 30, 2008
Acer aspire 5004 black screen after BIOS completes loading
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :-
Mar 16, 2012 | Acer Aspire 5004WLMi Notebook
My dell Latitude E6500 laptop will only turn on and load then will display a black screen. i tried to reboot it but all it does is go back to the black screen and has a "_" sign.
check to see if there is a disk in the cd/dvd drive also make sure you dont have any extras connected to it like usb connections.. have you tried entering setup or bios by pressing one of the command keys at initial boot? keys are usually one of the following ( esc f1 f2 f10 or f12) also have you tried to boot it in safe mode? (f8) also if you can enter the bios settings and check to make sure your hard drive is not disabled from boot order... usually the cause of this blinking white line is one of the above...i hope this solves your problem
Feb 08, 2011 | Dell Latitude D630 Notebook
My latop starts but I have a totally black screen and I tried to restart the computer and still have nothing but a black screen. My laptop is only 2 years old and was working perfectly fine yesterday. How...
Try this: Plug it out and remove the battery. Then insert the battery again, plug it in and try. If just black screen appears, your display may be dead and you need to replace it. If this helps, please rate. Thank you
Jan 15, 2011 | Toshiba Satellite L305-S5933 Notebook
No boot Device Selected error!Compaq!
Sorry, sounds like a dead hard drive. If you can gain access to the drive, you should check for loose connections. Also, listen closely to the notebook as soon as you start it up - can you hear the drive spinning? Can you hear any loud clicking or grinding noises? Any odd sounds can also mean a dead or dying hard drive.
Good luck, and please rate this answer if you feel it has helped you!!
May 11, 2009 | HP Compaq nc6000 Notebook
Acer aspire 5220 booting problem
Try connecting to an external monitor. If it displays on the external monitor then the LCD is probably dead. If it doesn't display on the external monitor, its a problem with the video card.
Feb 25, 2009 | Dell Inspiron 6000 Notebook
Blank screen appears on the startup with only cursor on it
The Acer Recovery CDs do not set the Boot flag on the hard drive. I had to manually set the boot flag to on using GPARTED Live. After restarting using the GPARTED CD, you can manage the flags under the partition drop down and click on the Boot flag. After exiting GPARTED, I rebooted the laptop and no more black screen....fixed!!
I hope this helps others.
Jan 27, 2009 | Acer Aspire 4720 Notebook
Black screen only.
1. Windows reinstall thru CD ( crashed graphic drivers )
2. screen itself faulty
Jun 07, 2008 | Toshiba Satellite P35-S611 Notebook
Blank screen
Dead or black pixels. Information about dead or black pixels on a lcd or computer display. ... Determining how many dead pixels are on the screen .
E-mail CHID: 5858 All it says is Error loading operating system on a black screen. Answer. This issue is often caused when the computers BIOS.
Read & Follow instructions/ Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Lenovo ThinkPad T61 Notebook
Gateway notebook problem
Black Screen of Death - BSoD Black Screen of Death or BSoD computer dictionary definition and information.
Dead or black pixels. Information about dead or black pixels on a lcd or computer display. ... Determining how many dead pixels are on the screen.
Dec 22, 2007 | Gateway 450ROG Notebook
Computers & Internet Logo
523 people viewed this question
David Payne
David Payne
