Question about HP Compaq Presario V2000 Notebook
Computer monitor diplay uneven
The monitor displays two different levels of contrast on the same page. The words fade into the lighter section of the page
I need driver vga, sound
Posted on Jun 29, 2008
Fine tuning the contrast & darkness
Right click the display go to properties and on the advance tab try reducing or advancing the refresh rate to see if there is a difference. If negative restore the rate to the original setting. Good Luck. Ed Pinero
May 29, 2014 | Envision Peripherals 19" envision g917w1...
Computer starts but no diplay shuts down immediate,
Is the power LED on the monitor ON, if not check the power cable connection at the monitor and at the mains.
Check the video cable connection at the PC.
Try a different working monitor on your PC and see if the monitor works on a different PC (the monitor maybe faulty).
Nov 17, 2012 | E-Machines T Computers & Internet
SAMSUNG Syncmaster 920nw monitor display problem
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
You might need to upgrade your graphics card drivers
you might have to remove your graphics card to make sure the socket is clean
restart your computer the reinstall it this should activate found new hardware wizard
if your computer came with a mother board disk the drivers could be on it
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps you
Mar 02, 2012 | Samsung SyncMaster 920NW Monitor
How to increase contrast 190B
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
hope this helps you
Oct 25, 2011 | Philips 190B4CG (Gray) 19" LCD Monitor
Screen went blank, all else works
post your problem clearly to solve. no display at all or it comes and fade of., check your monitor by unplugging VGA cable from your CPU and it displays nothing to diplay, colour codes any one of this
Mar 12, 2011 | Westinghouse Electric SK32H640G 32"...
Hello. This computer will recognize a good
This is the problem with the display capacitor on your motherboard. Try replacing the display capacitor by good technician. If it doesnt solve your problem you need to change the motherboard. But mostly this will solve your problem.
Oct 15, 2009 | HP (D9820-60007) Motherboard
Dell 1908s LCD monitor (new)
return the LCD to seller and ask for replacement. LCD colors should be even from top to bottom. test it with plain color as a background such as blue so you can easily see the faded portion.
Sep 04, 2009 | Computers & Internet
X1150: Uneven print with some words lighter second page on
I had bought a re-inked black cartridge from Staples; although my computer said that the cartridge was full, it wasn't working; I removed and put in a regula 16 black from Staples brand and now everything is fine. Thank you
Nov 24, 2008 | Lexmark X1150 All-In-One InkJet Printer
SDM-P234/B Won't turn on
Follow this procedure to troubleshoot the monitor. NOTE: Since each of these steps represents a possible solution to this issue, check the display function after completing each step. 1. Download and install the latest video drivers for the video card. 2. Disconnect the computer and monitor from any surge protector or power strip and plug it directly into a known working wall outlet. NOTE: If the display returns after completing this step, the problem is isolated to the surge protector or power strip. 3. Ensure the monitor cables are connected correctly. 4. Perform a monitor self-test. 5. Adjust the monitor brightness and contrast levels. NOTE: Refer to the monitor manual or user guide for specific instructions on how to adjust the monitor brightness and contrast levels. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site. 6. If possible, connect and use the monitor with a different computer. NOTE: If the monitor functions properly, then the problem is isolated to the computer to which the monitor was originally connected. 7. Ensure that the keyboard and mouse are connected correctly. 8. Troubleshoot the computer display configurations in Safe Mode. 9. Remove any hardware that has been added to the computer. This includes any added memory, internal or external drives, and any type of adapter card (network, sound, video, USB, etc.) . Let me know what happens. Good Luck, Tim
Feb 16, 2007 | Sony SDM-P234/B 23" LCD Monitor
HP Compaq Presario V2000 Notebook Logo
55 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
