Question about Motorola Mobility RAZR V3
Razr V3 keypad problems
Help! My razorv3's keypad is not working b/c ea time i try pressing these buttons there is no response to anything i want to do, ie, call a number, search for options, etc. it only responds to starting and turning off the phone, at times when i press a key the options start jumping around on the screen. the only way to stop this erratic behavior is to flip close the cover. several days ago i got caught in the rain but the phone was inside my pant's pocket, so it didn't get as drenched as my head and chest. i left it in the pants overnight but in the AM the pants weren't wet--hanged them out to dry overnight. also sometime in the past, i did have to take out the battery a couple of time b/c it wasn't turning on, then it did, and also i have dropped it several times before the rain incident.
is there any way i can do to fix this, but to spend $75 to possibly have it repaired (as told by Motorola and by a so-called rep store from Motorola), . also the inconvenience of not having it for a time and having to mail it far away in the state. they only have a few stores in NJ.
rosa
I had the same problem tonight and found the solution here.
http://forums.mobiledia.com/topic62027.html
I'll save you the trouble and copy the text.
"""I had the same problem with a razor: only the on/off key worked. The solution that worked for me was a simple cleaning, I didnt have to buy a membrane. To do this, you have to take the top apart (the part that has the camera), and clean a connector with alcohol. Its a bit challenging, so I'll explain. First you will need to take the 4 front tiny rubbers out of their spots (near the big LCD screen), one in each corner then you will need a special STAR screw driver, ( I used a tiny flat-head screwdriver and was careful not to strip the screw head). Next you will have to pry the back open with a small flat screw driver. There are two connectors visible, one connects to the camera the other goes back into the hinge of the phone. You'll need to clean the connecter that goes back into the phones hinge. Gently pry the silver top of the connector until it seperates and clean it with a q-tip and alcohol, let it dry, reconnect it, then try the phone out. I had to clean it 2 or 3 times so i wouldnt screw the phone back up until you try it, but eventually it worked good as new. """
I actually cleaned it about 4 times and it didn't work until
I screwed everything back together.
Posted on Jun 29, 2008
Motorola RAZR V3 - keypad non responsive
sir it may be because accidentally the phone would have made contact with water... my advice is give the set to local service station and change the keypads... hope i have helped you.. thank you sir...
May 03, 2008 | Motorola Mobility RAZR V3
Motorola razr v3 keypad....!!!
This is usually caused by one button being stuck down, and the volume control buttons on the left of the main display, and the voice button on the right of the main display are the usual culprits. Try squeezing them and making sure they move normally. Then power down the phone, pop out the battery, and give it another shot.
Dec 15, 2007 | Motorola Mobility RAZR V3
Motorola razr v3 keypad problem!!
Press all of the buttons and keys on the phone one by one with it powered off and the battery out. Make sure they all feel normal to the touch and when pressed. Check the buttons on either side of the main display carefully, as these tend to get stuck more than others.
Keypad troubleshooting
when I open my phone it seems to be stuck on the right arrow button so it goes to "IM account". I was really confused this morning because even if I click exit, it goes back to the same thing on its own. when I get a chance to press menu, it just whirls around as if I'm pressing the arrow over to choose a category but I'm not.. its weird.. probably the weirdest phone I've ever had
Sep 23, 2007 | Motorola Mobility RAZR V3
Razr- turning on camera makes screen turn black but keypad stays lit
the easiest thing tpo do here is take it to a professional but if you want to try updating your software off the Motorola website. (this require a data cable or bluetooth in your computer) This fixes a lot of software problems with the razor. If this doesn't work then you will have to reflash your Firmware which is like the Windows Xp of the phone. This does require a professional as it can destroy the phone
Jul 05, 2007 | Motorola Mobility RAZR V3
Motorola Razr - Keypad Doesn't Work
My phone developed the same trouble............ Removed battery and SIM and blew dry air into anyhole I could find, put it back together and has worked ever since.
Thanks for the tip
Jun 25, 2007 | Motorola Mobility RAZR V3
I cant call anyone.
software problem, go to your service engineer and ask him to reformat your phone...
Mar 27, 2007 | Motorola Mobility RAZR V3
Keypad will not work
This happened to mine after I got the Razor wet - I pulled the battery and the sim card, blew it out with a can of compressed air and it worked for about 8 months. Then it got hot out in my car and started doing the same thing - blowing it out hasnt worked again-
Jan 22, 2007 | Motorola Mobility RAZR V3
Broken phone!!
Saw quite a few of these. Have you tried taking the battery and Sim out while the phone is still on? did you try to flash your firmware on your Razr? there is one firmware will mess up your keypad, but all you have to do is apply keypad flex and it will work again. A friend recently updated his firmware and had to re-apply flex, works fine now. Good luck!
Jun 09, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
581 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
