Question about Magellan eXplorist 210 GPS Receiver
No base map message
I don't have map.
  • tboyla21963 Jun 29, 2008
    need base map instructions and any communication must be in english,the only language i know
    Master:
  • 497 Answers
Where r u from?
Posted on Jun 29, 2008
  • 13,433 Answers
Heres the basemap
http://rhamphorinkx.newmail.ru/maps/na_lb112%20(ex_400-500-600_na).rar
Copy attached "BASEMAP.MGI" to eXplorist, in "Background maps" folder.
These downloads are in rar compressed format if you need a free decompressor one can be downloaded from www.rarlabs.com
  • Ekse Jun 29, 2008
    if the link is confusing you can get the file from
    So drop me a comment if this doesn't work, and I will look more into it.
    Thanks
    Ekse
  • Ekse Jun 29, 2008
    was the basemap in russia?
2 Suggested Answers
  • 13433 Answers
SOURCE: magellen 210 base map
The maps are missing from the device, do you have the original maps that came with the gps? attempt to reinstall the maps into the gps.
Posted on Jun 27, 2008
No data base found on device
Hi it's look like your GPS is wiped. Connect your GPS to pc and go to your manufacture website, download software for it and purchase map to make it working.
Apr 08, 2014 | GPS
Magellen 210 base map
Jun 27, 2008 | Magellan eXplorist 210 GPS Receiver
I don't find maps
It seems your map data(base) may have been corrupted. Have you tried restoring the data from your backup ?
or you can try running a (fix) disk utility against your (internal or external) storage disk for the GPS ?
For instance, connect the GPS to your PC (Windows), and select (highlight) the (internal) "disk" on the GPS device. Under File - Properties, go to the Tools (tab) and run the "Error-Checking" option.
Running this utility may fix your map data error.
If not, you'll want to get a new map ...
May 01, 2013 | Tomtom GO 720 GPS Receiver
We have a DECT 6 system with a base unit and five satellites. Suddenly the satellite phones don't work, but they are alive (with no dial tone and don't ring) and show a message "out of...
Hello.
From FixYa Support:
- unplug base unit for 15 seconds
- press "PROGRAM" button on handset
- from menu, select "HANDSET SETUP"
- from menu, select "REGISTRATION"
- handset display will prompt you to press and hold PAGE button on base unit for 5 seconds, then press "PROGRAM" button on handset
Perform steps for each handset. You may need to plug base unit and unplug for each handset.
Hope this helps.
Jul 27, 2011 | Uniden Cell Phones
Will not show transferd maps will show routes that have been sent to it base map showing
Go to the SETTINGS menu and select the MAP INFO menu. Make sure that the check box by the uploaded map that you want to use is checked. If the map is not checked, then only the base map will appear. This allows different maps to be installed simultaneously.
Jul 29, 2010 | Garmin Quest GPS Receiver
Can't upload updated maps. Kept getting error
Try this link here not sure what i does since i use other methods to update maps and i don`t use garmin, but maybe this will get you pointed in the right direction
https://my.garmin.com/maps/chooseDeviceType.htm?
Hope this helps
Apr 26, 2010 | Garmin StreetPilot c340 GPS Receiver
I have a Magellan Maestro 4040 I just put firmware version 2.62 on. I purchased a 2008/2009 map update today. When I try to load this new map update I get this message, ''The product identifier of the...
The software update version corresponds to your map database version:
  • If you have map database version 27, your software will be updated to v2.62.
  • If you have map database version 31, your software will be updated to v3.61.
http://www.magellangps.com/support/notes.asp?supportID=754
Jul 13, 2009 | Magellan Maestro 4040 GPS Receiver
Explorist 210 no base map
I solved this problem by gonig to the secret menu by holding the nav + power. I entered the value # 95 in the menu. This will let you format the memory area in the unit then I down loaded the latest firmware update from magellan.com and installed it on the
unit.I had already made a copy of the files on the unit in my hard drive so i copied the files back to my unit so that i did not loose anything important like poi's and geocaches etc...
PS when I did the firmware up date the base map must have been restored.
Route calculation error
I was having the same problem and contacted Garmin support.
What I had done was turned off the Basemap that came with the unit. I only had the mapsource map street map on which I had purchased separately.
The technician basically said the unit needed the basemap to "locate itself". Somehow the basemap supports any maps you purchase separately. That seemed odd but once I turned the Basemap back on it calculated the routes and the error message went away.
If you have the Basemap off, try turning it on from the Map Setup - Information window.
Hope this helped.
Oct 01, 2007 | Garmin GPSMAP 60CSx GPS Receiver
Explorist 300
since the unit doesn't have a base map it needs to be loaded with the base map so send it for a service so that the base map could be added.
Jan 04, 2007 | Magellan eXplorist 300 GPS Receiver
Magellan eXplorist 210 GPS Receiver Logo
319 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Mike Cairns
Mike Cairns
Are you a Magellan GPS Expert? Answer questions, earn points and help others
