Question about Kenmore 73892 / 73894 Top Freezer Refrigerator
Coils icing up?
How do I get at the coils to melt the ice?
  • 481 Answers
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jun 29, 2008
The ice maker makes ice and fills the ice bin but every few days the ice melts and creates a frozen ice scicle path to the lower tray and all the ice has melted and frozen again below the ice maker.
The problem with the ice melting points toward a cooling problem in the freezer. This could be caused by several different problems. Dirty condenser coils below the refrigerator could be contributing to this problem. I recommend checking and cleaning these coils if necessary.
Check the door seal on your freezer. A leak through the freezer door seal may be allowing warm air to enter the freezer and melt the ice.
Make sure that your temperature control is set properly.
If these tips do not help resolve the problem, it is likely that you have a component failure or a sealed system problem. The thermostat could be bad. You could have a condenser or evaporator fan problem. You could also have a defrost system failure that is causing your cooling problem. A weak compressor would also cause this symptom.
Jan 17, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Ice buildup, not cooling well
The ice build up on the cooling coils prevents you fridge from cooling properly. You need to unplug it and allow the ice to melt. When the coils are free of ice, the fridge should work better. Hope this helps you.
Dec 17, 2010 | Sanyo SR-4910M Compact Refrigerator
My kenmore refrigerator is icing at the enterance of the evap coil and does not cool. The suction side of the coil is warm
Check to be sure the coils underneath are clean and the the fan motor (if your model has one) is running when the compressor is on. If vacuum the coils, turn the unit off until all ice had melted then restart.
Your defrost timer or heating coil for auto defrost may be out. To determine, turn off until all ice melts, restart. It will take about a month for ice to reform.
Oct 23, 2010 | Refrigerators
Freezer won't freez and the bottom nearly cools
I think you need to repost or clarify. You are asking why the freezer on your maytag gas dryer wont freeze. Assuming you have a split frig/freezer.... and assuming the compressor is working.... most common problem is either the fan motor is bad or possibly seized up with ice. Also the coils may be completely iced over. You can take two approaches here... Either turn the unit off and let it completely defrost, and let all the ice melt. Also best to tilt it to drain pooled up water after it melts. Or... you can remove some panels (sometimes difficult to do), and access the fan blower and coils. Once you get to the fan blower and coils check and make sure fan is blowing. let all the ice melt. A blow dryer works good for this, or just let it sit, and again make sure you tilt it and drain any pooling water. Also you should clean all the dirt, fuzz, and scum from under the unit around all the coils, and fans behind and below the unit.
Sep 18, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Cooling fins surrounding coils are freezing and
mcdevito75 here, Possibly, the filter needs cleaning / replacement, unit set to too cold. Shut A/C off, let the ice melt on it"s own DO NOT REMOVE ICE YOURSELF, those coils have the fren gas in them, when the ice is all melted restart unit, set temp. not so cold, around 60--65 degrees, and have exhaust to out. This shpoul;d help, you can always check with your local A/C repair shop, they come to the house.
Jun 25, 2010 | LG Electronic Window Air Conditioner
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Ice cubs ar melting GE double door frig what can be the problem?
If the ice cubes are the only thing melting it could be the heater in the ice maker which thaws the ice a little to release it from the mold.
If other things start melting it could be auto deforst failure indicated by iceing of the evaporator coils behind the rear cover in the freezer.
Aug 29, 2009 | Ovens
My Model ED5HHAXVQO2 REFRIGERATOR IS NOT COOLING. THE FREEZER IS NOT FREEZING BUT IT SEEMS TO BE BUILDING UP FROST.
Sounds like your auto defrost is not running long enough to melt the ice that develops on the coils. You can easily fix this problem by using a hair dryer and removing the back panel in the freezing unit to reveal the coils. Once this panel is out use the hair dryer to melt the ice. Once the ice is cleared this should restore air flow across the coils. Hope this helps. Good luck.
Aug 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Coils inside freezer keep icing up.
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model of fridge)
Aug 08, 2009 | Refrigerators
Kenmore 73892 / 73894 Top Freezer Refrigerator Logo
50 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
