Question about Radio Communications
Galaxy 939 cb radio
My galazy 939cb has standard wave meter,goes backward on low channels, when u key it up, is about 2 on upper channels when u key it up. i have a 12 foot coax cable that cannot be cut off anymore. What should i do.
  • eddie41839 Jul 02, 2008
    when you key the mic up while the meter is in swr mode the hand moves it has negative swr on the lower channels
    EDACS May 11, 2010
    I dont exactly understand what you're saying, if you can clarify your question, I may be able to help you.
  • 66 Answers
Oh, that's nothing, just a faulty meter, take it to a radio repair store and have them rewire it, happened with my Galaxy DX 2517, just don't try to do it yourself ok. Another thing, you do realize the lower your SWR, the better your radio's perforomance?
Posted on Jul 02, 2008
Needle swing backwards
you played with the radio didn't you. When you tried to peak and tune it you tuned it to the wrong side of peak.
Feb 03, 2014 | Galaxy Radios DX-959 40-Channels Base CB...
Blown fuses on galaxy dx 939 after holding mike switch for less than ten seconds
try to key it down without the mic attached and see what could be in the ic or even the final so be prepared to replace them
Nov 19, 2013 | Galaxy Radios DX 939
What is Dead Key on a CB Radio?
Deadkey is slang it is CW or Carrier wave which is RF power produced before modulation/audio is mixed in which stimulates PEP wattage slang being SWING WATTS. A Watt Meter is used to measure it which is often a combination device Wattage/SWR/Modulation meter.
May 08, 2013 | Galaxy Radios DX-949 CB Mob ssb Swr...
Is it best to use in am mode in normal trasmitions on a cb radio dx 959 galaxy?
  • This Galaxy was built as a CB to run on AM (11 Meter). The majority of people on the CB run AM stations. Sideband (upper and lower) is where the carrier is removed and the wave being transmitted on is cut in half. You can do this just fine but mainly if you want to talk to someone and you both know your going to be on Sideband for a little privacy. 38 LSB is a great channel to catch some DX side band on world wide. But yea, AM is the best to find people to chat with.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 01, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
How to use ssb usb am cb radio
  • Well, AM is Amplitude Modulation and Sideband suppresses the carrier and uses only the top half (upper sideband) or lower half (lower sideband) of the wave.
  • Whether using AM, USB or LSB you are on the same frequency although if someone is on USB and you are on LSB you will not be able to understand what the other person is saying because you are using different parts of the wave. So 27.185 (channel 19) on AM, USB or LSB is still 27.185.
  • If you have further questions please let me know.
How to set swr galaxy dx 949
you do not "set" cannot set it on the radio. the radio can tell you what yourswr is. it can take an swr measurement. swr has to do with the antenna system. in order for the radio waves to radiate from the antenna properly, the physical length of the antenna must match the length of the radio waves. if the antenna is too long or too short you will have a higher swr ratio. the higher the ratio the less energy will leave the antenna. but that energy needs to go somewhere, so it goes back into the radio which causes damage and can ruin a radio.
first turn the channel to 20. then switch the meter switch to CAL. then key the radio. while keyed, turn the CAL knob up until the needle in the meter gets right to the CAL Mark. next flip the meter switch and key the radio. where ever he needle is, is what your swr is.if it is more the 1.5 that's getting high. if its over 2 you are in the danger zone. if its over 3 you are damaging your radio. you must repeat the calibration proceedure for every figure out weather your antenna is too long or short, you compare the swr readings from channel 1 and ch 40. if the swr is higher in 1 then on 40 the entenna is too short. if its higher on 40 then 1 its to long.
Aug 05, 2011 | Galaxy Radios DX-949 40-Channels Base CB...
Tunning the antenna on radio shack cb trc-447
After installing the antenna, follow these steps to adjust the
standing wave ratio(SWR).
1. Turn on the CB.
2. Set S/RF/SWR/CAL to CAL.
3. Key the Mic and rotate SWR CAL so the meter points
to CAL.
4. Unkey Mic.
5. Set S/RF/SWR/CAL to SWR.
6. Key Mic again and note the actual measurement on
the SWR scale. Refer to the following table to interpret
the reading.
1:1 - 1.5 Great
1.5 - 2:1 OK
2:1 - 3:1 Not So Good
Higher than 3.1:1 Terrible
The ideal standing wave ratio (SWR) is 1:1, or a meter
reading of 1 on the SWR meter's top scale. A SWR ratio
of 1.5:1 to 2:1 is excellent for most mobile CB antenna
Check the SWR on Channel 1 and Channel 40
If the SWR is higher on 1, make the antenna longer
If the SWR is higher on 40, make the antenna shorter
Most antenna's are adjustable. Make small adjustments at a time.
Oct 10, 2009 | Radio Shack TRC-447 CB Radio
Switching radio bands
what radio do you have? does it even have sideband channels? some radios don't come with them, of fm or upper or lower side bands and short wave
Dec 08, 2007 | Connex 3300 240-Channels Base CB Radio
Lost channels in a galaxy 66v cb radio
as far as the transmit frequency changing while you have the mic keyed this is normal, the transmit frequency is a little different than the receive, as far as the lost channels go you need to check the galaxy website and check to see if thier is any fixes listed. if none is listed then you can send the tech's a e-mail and tell them your problem and they will advise you on what to do.
Aug 15, 2007 | Galaxy Radios DX-66V Base CB Radio
Radio Communications Logo
104 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
