Question about RCA OPAL M4001 MP3 Player
My rca m4002a
The headphone plugin part has ben streatched, or so I think. And the thing won't come on now
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jun 30, 2008
When I plugin my headphones The sound dosn't go to the headphones.
First, try plugging in different headphones. If those work, then your headphones are broken and you need to replace them.
If those don't work, then please check to make sure you're not plugging them into the microphone jack - you'll see two identical plugs, usually the headphone one is marked with a pair of headphones.
If you're plugging known working headphones into the correct port, then your computer must logically be the broken thing.
Dec 20, 2013 | Motorola Mobility S9 Headphones
Sylvania wireless headphones
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more :
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
Read more :
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
Where is the plug for headphones?
Thoat model does not have headphone plugin. But if you have a stereo or surround sound receiver with head phone plugin on it, then you can plug your stereo to it via RCA.
Apr 29, 2011 | Toshiba 32A41 32" TV
My M4002A RCA MP3 Player won't turn on. How can I fix it?
I got a sewing needle and put it in the reset hole on the back of the mp3
Jun 23, 2009 | RCA opal MP3 Player
I have the same problem
om the only thing i can think of is to rember where you want or buy a new one
Mar 31, 2009 | RCA OPAL M4001 MP3 Player
What song service supports rca opal m4002a mp3 player. napster doesn't work?
Not iTunes. Not Napster.
You could try Rhapsody's MP3 ONLY service - new!
Limewire works, but make sure you anti-virus program is up-to-date.
The key is to use Mp3 format only, and most music services have switched to WMA format.
Jul 05, 2008 | RCA OPAL M4001 MP3 Player
RCA Opal M4002A Need screen
I have an Opal 2GB mp3 player just like yours and I accidentaly busted the screen on it, so I e-mailed the RCA company, they e-mailed me back telling me that I voided the warranty, and I would have to send it back and pay 55 dollars to get a new one, because they don't sell the individual screens.
I hope this helps.
Apr 02, 2008 | RCA OPAL M4001 MP3 Player
Rca M4002a wont let me delete songs
Just click this link to download the firmware, and follow the directions after install. You should be able to add/delete songs again. It just worked for my player. Hope this was helpful.
Jan 01, 2008 | RCA OPAL M4001 MP3 Player
Rca opal m4002a
trouble - this player is not MAC compatible - you will always get that error
everyone else -
The Opal has a reset hole on the back of the unit in which a toothpick (non metallic) can be inserted to reboot the player.
If this does not work, I suggest that you reformat the player by using the WindowsTM format command on the unit. To reformat the memory
  1. Right click on the device within the Explorer or My Computer window
  2. Select the format command (full format) to reformat the internal memory of the device.
  3. Reinstall the firmware from
Sep 19, 2007 | RCA OPAL M4001 MP3 Player
RCA OPAL M4001 MP3 Player Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
