Dryers Logo
Posted on Dec 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The dryer is plugged in, the receptacle has power. I set it to run and push the start button and nothing happens. Any suggestions?
Richard Roth
Level 3:
Top Expert:
  • Dryers Master 9,472 Answers
  • Posted on Dec 08, 2010
Richard Roth
Dryers Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2626624
Points
28464
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Here is a video to walk you thru the repair. If you will post your make and model number of your machine, I will be able to point you the part you need.
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Manchine is getting power light works on the inside but nothing happening, can't hear anything when pushing the power button it's a kenmore 80 series model 110.67832791 any suggestion on what could be...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
1helpful
The dryer will not start when you push the switch. Have checked the plug and power at the box. It sounds like the clock on the setting is working, but nothing happens when you push the button.
you may have a bad start button or a bad door switch these are the first thing to check out.if those check ok then you may have a bad motor.i hope this helps good luck
Jan 22, 2010 • Dryers
My whirlpool dryer wont start.
check the door switch and also the push to start button. Timers will advance even if the unit is not on
Mar 30, 2009 • Dryers
Dryer died
Hi! kiatt28
According to the manufacture (Whirlpool manufactures this model for Kenmore) PF is Power Failure, they do not recommended replacing the control. Have an electrician check the wall receptacle or breaker panel. I suspect you have a loose connection, sometimes it is just time to replace the receptacle.
InMrFixIt
Dryer won't start
Check your door switch and wires to see if they are damaged first.You may have a bad Start Switch.If it is a 2 wire switch you can tape them together and then plug in dryer ,if it starts,replace the Start switch. Please Rate this!
Dryer does not turn on
Sounds like the motor relay is not functioning. Sometimes the motor will work if the button is pushed but will stop when the button is released. This is caused by a loose wire at the motor or a bad motor relay.
Top Dryers Experts
john h
