Question about ASUS GeForce 6800 GT 256MB DDR3 AGP 8X Video Card with TV-Out, DVI, VGA, DirectX 9.0: V9999GT/TD (Re... Graphic Card
Picture messed up
When the tower starts to boot up the picture is fuzzy with squares and lines and wont fully boot the pc restarts its fine with a 64mb card i have a 500w psu please help
    President:
  • 2,351 Answers
Try removing the video card & clean the copper contacts with a couple drops of house hold alcohol on a cotton swab. Use canned air to blow out the AGP slot. Blow out the video card's fan as well.
Re-insert the video card & make sure it is firmly seated in the AGP slot. If you're still having the same trouble when you start up, try another AGP 8x card. You're 6800 may be going bad. My bet is the video card is dusty & not seated 100%.
If you are thinking it might be the power supply, don't! When that goes, nothing will work. System restarts by its self can mean the CPU fan is dirty with lots of dust. You can blow this out as well. If it looks real dusty use a clean paint brush to help clean the fan. Don't be too rough with the brush. You don't want to break a fan blade.
Luck!
If the issue continues post back here or click the Ask Me button.
Mike
Posted on Jun 30, 2008
PC boot problem
Hi Jimmy,
Does the PC load windows fully before restarting?
If it does load and then restart,then it may be a problem on the part of your hard drive.
Run a full scan of the PC with an updated anti-virus to rid off any viral attacks.Make sure the anti-virus is always updated for better performance.
If it does not load windows,try this:-
  • Restart the PC.
  • Before it loads the first page,press Ctrl,Alt and Del.This is a soft boot sequence.
  • The booting leads you to the Bios setup page.
  • Under file save changes and exit[though no changes made].
  • If problem not solved repeat the procedure again.
If the problem persists,you may have to reinstall the operating system again.
Hope this helps.Thanks!
Nov 05, 2011 | HP 2133-1 Mini-Note PC
After moving PC it won't fully boot
There is a possibility that something has shook loose during the trip to your new home.
You will have to take the side panel of the tower and check the CPU fan and heat sink to make sure it hasn't become loose or fallen off. Also check all the connections regarding the hard drive cables.
It is most likely the CPU fan and heat sink as when the processor reaches critical temperature it will shut down in a very short space of time.
Also give the unit a little time to settle down first.Leave it to settle for a couple of hours.
Regards.
Feb 25, 2010 | Computers & Internet
The tv powers up and displays a picture with a fuzzy square on the left hand side but the picture is fine behind it. It stay on for about 10 seconds then restarts and carrys on doing this all the time.
needs a simple reset
NO RESPOSIBILITY ACCEPTED
do this exactly
tv in stand by
press the following buttons in order
info
menu
mute
stand by
when tv comes back on
select reset
this puts tv back to factory mode
tune in etc as if a new tv
Jun 24, 2009 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Toshiba 32" tv wont give sharp picture (other tv does)
try to replace filter capacitor from power supply and in horizontal section.
Jan 26, 2009 | Toshiba 36A50 36" TV
Probs with boot up on a Dell inspiron 530s
When booting enter the BIOS setup svreen and press the following combination
1. Alt + E
2. Alt + F
3. Alt B
this combination will rebuild the IDE configuration and clear the NVRAM. Alt + b will save the configuration.
Alternatively
1. Shut down PC and unplug Power cable from Back of Tower.
2. press the power button and Keep holding for 10 seconds. this will remove static charge from PC
3. Plug in cable and restart.
Jan 13, 2009 | Dell InspironTM 1501 Notebook
Fuzzy picture
You can't make SD look like HD thats why HD came out, the best you can do is adjust the picture controls to get the optium picture
Apr 11, 2008 | Sony KP-57WS500 57" Rear Projection...
Fuzzy Blue...?
these set are bad about the blue tube messing up.. what happens is the convergence board witch generates alot of heat cooks the blue glycol.... basically growing algea in the blue tube... it is possible to remove the tube.. and remove glycol and clean the tube then replace and adjust..i have done a few here at the shop
Mar 14, 2008 | Akai PT4298HD Rear Projection Television
I was adjusting picture on monitor and now picture completely messed up
  • Signal out of Range.
  • Out Of Scan Range
  • Horizontal frequency is out of range.
  • Cannot Display This Video Mode Out of Sync
This issue may occur if the signal from the video adapter exceeds the scan range of the monitor. The video adapter setting for updating the screen (the refresh rate) is incompatible with the monitor.
you should reinstall your video drivers in safe mode.
To restart in safe mode repeatedly press the F8 key during the computer startup. This will bring a menu where you'll be able to choose safe mode.
LCD monitor 60 - 75 Hz
Jan 25, 2008 | IBM E74 17" CRT Monitor
Computers & Internet Logo
44 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
