New Samsung SH-S203 DVD writer with SATA has a plug-in in the back that doesn't seem to match the plug on my SATA cable which goes from my ABIT AW9D-MAX motherboard to my Pioneer burner which also has a separate power plug. The Samsung doesn't seem to have a power plugin either.
  • 46 Answers
The power connector is really similar to SATA connector. It's not like IDE/EIDE. It should be a flat connector.
Take acloser look, most of the times both connectors are very close.
Posted on Jun 28, 2008
What cable do I need to hook up a Samsung dvd writer sh-s182 to my Akai dps16 with scsi?
I suppose you would need a SCSI cable with the correct number of pins that match your scsi ports. Some have 50 pins some have 80 pins and some have less than 50 pins. Count your pins and go from there. Have you ever done this procedure before? Did it work?
Mar 18, 2014 | Samsung SH-S182 DVD±RW Dual Layer Burner
Download driver for SH-224bb
try this link
http://www.solvusoft.com/en/update/drivers/dvd-writer/samsung/sh-224bb/sub-models/
Jan 28, 2013 | Samsung DVD Burner SATA Model SH-224BB -...
Can my CD-RW/DVD Rom Drive, model # GCC4320B be replaced with a hp 24x Multiformat DVD/CD Writer, dvd 1270i . I bought this unit today, but the connections don't match up? I truely appreciate your time and...
This model DVD/CD writer is a SATA drive and unless your motherboard has a SATA connector then you have a slight problem. You will need to purchase a SATA controller and install it into your PCI expansion slot, then connect your new DVD/CD drive to this SATA controller. You will also need a SATA adapter power cable converter which plugs into the 4 pin power connector.
Feb 08, 2011 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
I have a dell computer and installing a samsung dvd-writer model sh-222 and it is not seeing it. How do the cable get installed on the slave or master?
if your using sata connect then it really does not matter the mother board will detect it as it wants though it should be plugged into master 1 and hdd into master 0 if your using the older type ribbon then you must make sure that the dvd player has its jumping pin plugged into slave at the back of the dvd writer. there is a small cluster of 6 pins with a small plastic jumper that needs to be put on were it says slave
best of luck need more help feel free to email
merry christmas
Dec 07, 2010 | Samsung Computers & Internet
I am replacing my cd player/burner with a DVD writer model sh-s223 the attachments don't match what do I need to purchase
The sh-s223 is a SATA interface, you must have the older IDE/PATA type drive interface, this needs the wider IDE ribbon cable for data and a 4 pin MOLEX power plug.
You have bought the wrong DVD burner
You have 2 options
Return the drive and buy an IDE model... OR
Buy a sata expansion card, these can be bought for under £10
http://www.amazon.co.uk/Port-Expansion-VIA-VT6421a-chipset/dp/B000S87GG0
Jul 31, 2010 | Computers & Internet
Samsung dvd writer sh-s203 need firmware
sounds like you have not adjusted the jumper setting for the drive
Dec 02, 2008 | Computers & Internet
Samsung SH-s203 dvd writer is compatable with this motherboard
put the sata cable to sata terminal and also connet the sata power cable to drive.
Oct 28, 2008 | Intel D845GVSR Motherboard
DVD writer not reading disks
change ide cable 1st ok get back with me thx nick
Feb 03, 2008 | Computers & Internet
Samsung dvd writer
Most common problem is the "jumper" setting is wrong. You can do several things. Some you may already have done, but check it any way. 1. make sure the SATA cables are completely plugged in correctly. Power is plugged in. 2. Check the "jumper" on the back of the burner. Should be in "Slave" position even though the manual doesn't say it, it says "Master/Slave". 3. Go into "control panel", then to "system" then to "Hardware". Check to see if you have a "yellow !" for CD devices. If you do click on it and remove it. Close all windows and "restart". That should fix it. If it doesn't, check the "compatability" of the Motherboard per Samsungs website. Some mother boards are just not compatible. Might not hurt to check that first before you do anything else.
Jul 20, 2007 | Samsung Super-WriteMaster SH-S183L Burner
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
