Question about Linksys WRT54G3G Wireless Router (WRT54G3G-ST)
WRT54g3 wont connect toAT&T network
I've gone through the setup five different ways and at the end I get the same error message, "check network card and call network". The card is a Sierria Wireless AirCard 860 Cingular and works fine in my laptop. Is this card not compatible or am I missing something?
  • 148 Answers
Unfortunately no this router is designed for wifi products in the g class and n class. When you use your aircard you are actually using it in a modem format that works only with att. You will notice you need a sim card for this it has you ein code embedded in th chip. Take care... Be mucho blessed.. Mark
Posted on Jun 29, 2008
Internet crashes my htc Smart... Help?
The first time you use your device, the Connection Setup displays a notification message to inform you that it will automatically configure your device's data connections, such as 3G/GPRS/EDGE, WAP, and MMS.
  1. On the notification message, select Yes.
  2. If your SIM card supports multiple network operator profiles, the next message displays all network profile choices. Select the profile you want to use, then select OK. The Connection Setup configures your device's data connection settings.
  3. After the Connection Setup completes configuration, tap Restart. Tip: To choose the network operator manually, select Start > Settings > Connections tab > Connection Setup The GPRS/3G settings are preconfigured on your device when you applied for this service with your wireless network provider. If you need to add another GPRS/3G connection:
  4. Tap Start > Settings > Connections tab> Connections
  5. Under My ISP, tap Add a new modem connection
  6. On the Make New Connection screen, enter a name for the connection, select Cellular Line (GPRS, 3G) on the Select a modem list, then tap Next
  7. Enter the Access point name, then tap Next. You may obtain the access point name from your wireless service provider.
  8. When prompted, enter the user name and password. (Check with your wireless service provider if a user name and password are required to connect.)
  9. Tap Finish
Feb 09, 2012 | HTC Cell Phones
I cannot connect to the WIFI at work, but I can connect to my WIFI network at home, and other public networks. The wireless network at work is pushed by a D-Link 8200AP with a WAP security, just like it is...
Your laptop cannot connect to your work's wireless network because the security settings (ir WAP) in the D-Link is different to the security setting in your Netgear.
The wireless card in your laptop will need the settings changed to suit the D-Link's wireless settings ie the SSID and WAP.
You will need to change the wireless card settings in your laptop back to the Netgear's wireless settings to connect to your wireless network at home.
Some wireless cards allow you to set up different profiles for different wireless networks which allow you to switch wireless networks easily by just selecting the profile for the network you want to connect to.
Jun 25, 2011 | Apple iBook G3 Mac Notebook
My phone looses connection very often. it brings up a message saying your answering modem has been disconnected to please check your settings
Try the following, (may work)
To manually select the network operator to use for data connections
You can also manually select your network operator from Connection Setup's
settings screen. Connection Setup will then reconfigure your device's data
connections settings based on the operator that you selected.
1. On the Home screen, slide to the Settings tab and then tap All Settings.
2. On the Connections tab, tap Connection Setup.
3. Select the network Country and Operator you want to use, then tap OK.
Note If you choose a Country and/or Operator that is different from the installed SIM
card network operator, you may not be able to access network services.
4. When prompted to confirm whether you want to configure the data
connection settings based on the selected network, tap Yes.
Connection Setup configures the data connection settings.
5. After the Connection Setup completes the configuration, tap Restart.
May 03, 2011 | HTC HD2 Smartphone
Had 3 d-link routers that keep giving off the error message that the "network cable is unplugged" all different models at different locations connected to differnt computers any ideas?
Hi, either there is a broken cable or faulty connector some where or the Lan card in your pc is faulty.
1/ Check all cables
2/ start with one router and connect that up by its self, without any other router.Connection should be made as close to the pc. You know the usual setup, modem,router,pc.
We are trying to narrow it down.
If pc still says network cable unplugged then make sure the lan card, in your pc is seated properly.Are you using a seperate lan card or the the motherboard connection.
I have just found that this product was discontinued in 2003,you are probably better of buying a new one.
But any how let me know how you get on.
Regards - Anthony
Jan 07, 2010 | D-Link (DI-711) Router
I cannot connect to the internet with my linksys wrtu54g hotspot. It was working until 2 weeks ago. I get error message that says - a network card is incorrectly configured. The card should be able to...
The network card should be configured to obtain a IP address automatically,
Open Control Panel - click on Network Connections - right click on the network/wireless card - select Internet Protocol (TCP/IP) and click on Properties and then enable Obtain an IP address automatically and enable Obtain DNS server address automatically.then click OK and click OK again.
Dec 21, 2009 | Linksys Wireless-G WRT54G Router
Ethernet not work
Check in the Device manager to see if all the devices are enable and working.
The one with a yellow ? against that device requires a driver installation.
Is the LAN device OK?
How do you intend to setup your LAN, is it for Internet access or a home network?
I need more information on your problem, together with error messages.
Jun 24, 2009 | HP Pavilion dv6000z Notebook
I have lost my wireless from my belkin how do i set it back up?
if the woreless connection has itself gone down, check your router, reset if nned be, then try and conect your PC manually, if it doesnt see a network or fails to connect, check encapsulation methods are correct and 802.11x security is not enabled, or check your wireles card in your PC
Jul 17, 2008 | Belkin Computers & Internet
Downloading mms
error in saving mms or error in downloading mms?
May 01, 2008 | Siemens AX75
Daisy-Chaining a HomeLink Phoneline Network
With a HomeLink card installed in your PC, connect your PC to a phone jack using a standard phone cable. Using another standard phone cable, connect the card's other phone cable port to connect to your second PC. Continue to connect up to twenty-five PCs in this way on one chain. If you want to use your telephone, modem, or fax machine, add a two-way splitter to your wall?s phone jack or connect the device to the empty phone jack in the last card at the end of your daisy chain. Daisy-chaining your HomeLink PCs and peripherals can create a simple network that acts in the same way an Ethernet network acts on your PC's desktop. In a HomeLink network, data passes into one side of a port, and continues out from the port?s other side. You can string up to 25 PCs on a single HomeLink network, provided that the entire length of cable does not exceed 150 meters (500 feet). HomeLink networks can send data through existing telephone lines without disrupting your telephone service. If you have PCs on two different floors of your house, plug one of the downstairs PCs into the phone jack in the wall, and you're able to network your PCs upstairs without running excessive amounts of extra cable.
Feb 16, 2006 | Linksys HomeLink Phoneline (HPRO200)...
Open Questions:
Linksys WRT54G3G Wireless Router (WRT54G3G-ST) Logo
115 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
