Question about Whirlpool Heating & Cooling
I own a whirlpool model ACM184XSO we have had it stored all winter,when we turned it on the fan would not turn however it does hum.
2 Suggested Answers
  • 4736 Answers
SOURCE: FIRST TIME IN WINDOW AFTER
Since you remove the window unit in the Winter and reinstall it in the Summer, as you should. Check the inside of the unit to make sure there's nothing blocking the fan blades. If you stored it in a basement or exterior shed or garage, a Field Mouse may have built a nest in it. Believe me, I've seen stranger things than that happen.
Posted on Jun 08, 2011
WHY DOES THE DRYER ONLY HUM WHEN I TURN IT ON?
If the hum sounds like the motor is running, you may have a broken belt. If it sounds like the motor is jammed you may have a locked up motor or something got through the lint screen area and has jammed the fan. Hope this helps.
Aug 05, 2014 | Whirlpool Dryers
Window a/c compressor runs. fan hums but does not run
Replace the fan. The bearing is worn and it may need a new capacitor.
Jul 14, 2012 | Whirlpool ACQ158XP Wall/Window Air...
Ac started chripping then fan quit
Sounds like fan bearing gone. New fan?
Jul 04, 2012 | Whirlpool ACQ189XM Air Conditioner
Pump hums but won't run
awwhhh it sounds as if you stored your pump dry all winter long ill bet, well ya just cant do that after it pumps salt water all summer , salt has crusted up inside pump and valves , try a hot water dose (not on motor) that might get it going again (repeat several times)
otherwise your gonna need to take it all apart clean in hot water and grease all up with foodgrade waterproof grease (see kitchen faucet parts section of hardware store)
on a salt water pool you have to store your filter and pump filled/capped with RV antifreeze (foodgrade) any good rv store sells it
salt wont crust up inside then
Mar 23, 2012 | Intex Salt Water Saltwater System Chlorine...
FIRST TIME IN WINDOW AFTER WINTER AND WHEN I TURN IT ON , I GET A HUM WITH AC BUT NO FAN. FAN MODE DOES NOT RUN AT ALL.
Jun 08, 2011 | Heating & Cooling
Where can i order a new motor for this model
Check this response from 2008 for same model fan.
By resorrowsr on Oct 26, 2008
Fan stopped Turning - Removed fan to check all the connections. All the connections were good. When you turn the fan on, you can hear a humming sound. If you take off the blades you can spin the motor and it will work, but will not turn on it's own.
    • resorrowsr
    • 2 years ago
    I called Home Depot customer service. I had my receipt, so they gave me store credit for the full purchase. Since I have two fans, they wanted to know if I wanted to replace both fans. I told them one was still working fine, so I only replaced one. My problem was the transformer. You could see where it had overheated and melted.
http://www.homedepot.com/webapp/wcs/stores/servlet/Search?keyword=Hampton+Bay+73554+Antigua+Ceiling+Fan&langId=-1&storeId=10051&catalogId=10053
Jan 30, 2011 | Hampton Bay 73554 Antigua Ceiling Fan
This oven has always had a loud fan noise when it was on or during cooling off. A couple of times lately I have turned it on and it has only had a quiet hum. I've turned it off and turned it back on a few...
Anonymous, we're sorry for the inconvenience. We would like to discuss this further with you. Please email us at Whirlpool_Reviews@Whirlpool.com at your earliest convenience with your name, address, a phone number and best time to reach you along with your model and serial number.
Oct 21, 2017 | Whirlpool GMC305PRS Stainless Steel...
Cooling fan hums and turns slow.
You will need to replace the cooling fan motor. Remove it and check the numbers on the fan and then do an online search for the motor. you can also contact a website called the repairclinic.
Oct 20, 2017 | Whirlpool MH1170XS Microwave Oven
Humming oven clock
You'll need a new clock motor or clock unit. Once these units begin to hum, they must be replaced. Parts are available on the web, through supply stores or Sears Parts.
May 26, 2008 | Whirlpool Ovens
Heating & Cooling Logo
63 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
