Question about Insta Blend CSE02F Work Top Blender
Cracked blade part
The bottom of my insta bland (the part with the blades) has cracked all the way through and leaks whenever I use it. Where could I find replacement parts?
  • BKrupp Aug 06, 2008
    I have the same problem. It appears the company that made insta blend is no longer in business. I have my original users manual and have tried to go to the website they have provided in the manual- no website can be found. I then tried to search for the business- Energie Corp.
    USA- still nothing. If you find anything please let me know. Mine is not leaking yet but is cracked! I am thinking to replace it with a Magic Bullet or the one JC Penneys makes- Cooks something or another. My sisters and parents have the one from Penneys and it works just as well. Lot less expensive than the insta blend- only 29.99
Bought a new one from JC Penneys!
Posted on Aug 12, 2008
Leaks at the bottom of the glass holder
I'm no expert but in my experience if it leaking at the bottom then either the jar /carafe has a few chips or cracks around the hole in the bottom that the blade fits through and in that case you need to replace the jar and your blade assembly may still be good and can be moved to a new jar/carafe. Or the blade assembly has come loose a little and need to be tightened or some the washers (usually the rubber ones) have worn out and need to be replaced. There's plenty of explanation here at amazon and else where on how to replace the assembly blade, move it to a new jar and tighten it down, etc. Hope this helps!
Sep 26, 2013 | Waring Blenders
Smoothie maker 600
Check to see if the jar has any cracks or if the blade assembly or collar have any cracks.
Is it possibly leaking from the tap valve?
If the blades or tap lever are cracked I would recommend replacing them, however if the jar is cracked i would just buy a new blender. These are great for smoothies but they are all discontinued and parts wont be available for much longer.
May 05, 2013 | Back to Basics 600 Smoothie Plus Work Top...
My glass jar leaks from the bottom
remove the screw on blade holder, and make sure the gasket is in place ,, check the seal on it,, if its defective replace it,, check along the threads to make sure that the canister isn't cracked
Aug 28, 2011 | Black & Decker BL1900 5-Speed Blender
I have the cuisinart SPB-7 Smart Power and it leaks. I put my milk in and it run on the counter top. What do I need to replace? Is it the washer?
The bottom part that screws on the jug with the blades, either the o-ring is bad,or the screw on piece is cracked and needs to be replaced.
Mar 17, 2011 | Cuisinart SPB-7 SmartPower Work Top...
The plastic base the blades are fitted in ,cracked need to order replacement
the part is Black and Decker Blender Base Collar Ring BL5000-11
However these are prone to cracking. I ordered a second after my first cracked, and the second one cracked after just a couple uses.
Jun 09, 2010 | Black & Decker BL1900R Blender
Leaking cuisinart smart power 7-speed electronic blender
There is probably a hairline fracture or tiny crack in the blade assembly itself - replace the blade assembly - it will automatically come with a gasket, so you will have an extra.
Apr 23, 2009 | Cuisinart SPB-7 SmartPower Work Top...
Leaking blender
It could be the gasket, could definitely be that crack in the collar, and even possibly the blade assembly - here is the official website to get all of those parts:
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=4154&linkon=subsection&linkid=112&secid=53
-Tha Mp3 Doctor
Mar 31, 2009 | Back to Basics 600 Smoothie Elite Work Top...
Insta Blend CSE02F Work Top Blender Logo
268 people viewed this question
Top Insta Blend Blenders Experts
eyecam
Are you an Insta Blend Blender Expert? Answer questions, earn points and help others
