Question about Proscan PS27108 TV
No Picture; Has sound and OSD Menu
Power went out and came back on multiple times. Could not get to the set fast enough to unplug it. Now there is sound, OSD, but no picture. We have tried several inputs and channels with different video sources, but still the same.
Chassis # = CTC187BF2
Pulled the fuse and it 'looks' ok.
Thank you
    Scholar:
  • 133 Answers
Try a "hard restart", which simply means unplugging the power cord of the TV, and replugging it after 4 hours have passed. This technique reprograms the electronics to a certain extent.
You can also visit the manufacturer's website or call their tollfree number for problem solving info.
Hope these suggestions help you out.
Posted on Jun 30, 2008
How do I unlock the OSD lockout on a Samsung B2430H monitor. I've unplugged the power and computer connection cable. Tried holding the menu and auto keys nothing seems to work. There is just the...
OSD LOCKED/UNLOCKED
This function allows you to lock the current control settings, so that they cannot be inadvertently changed. Press and hold the MENU button for several seconds. The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear.
Sep 09, 2013 | Samsung SyncMaster 753S 17" CRT Monitor
Sony rear proj tv, no picture, menu appears, but in three seperated colors pin cushioned.
Best to first if you have not done so---UNPLUG the set for several minutes and plug back to power to see if that fixes it (it does a lot of the time especially if you had a power outage).
Nov 30, 2012 | Sony Televison & Video
OSD Locks Automatically
Power off your computer and then remove the monitor cable from the port on the back side of the computer case.
Reattach the cable and make sure the pins are correctly screwed in. Power the computer back on and check to see if the OSD lockout message is still being displayed.
Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lockout message.
Find the OSD lockout heading and read the method that your particular model uses to remove the lockout.
Attempt generic lockout removal procedures if you no longer have the manual that came with your monitor.
Press and hold the "Menu" button located at the bottom of your monitor for 15 seconds and wait to see if the OSD lockout message disappears.
Press the "Menu" button again if the lockout message remains on the screen.
Use the arrow buttons to navigate through the main menu options.
Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lockout.
hope this helps
Jun 07, 2012 | HP Computers & Internet
LG flatron L1715s screen is black osd locked??
Your video settings may actually be out of range of the monitor.
Try starting the computer in safe mode. This will provide basic video without anything fancy. Reset the settings to a lower resolution from the display option in the control panel (or simply right-click on the desktop).
If the display works then, restart the computer and then try different settings from Windows, not the monitor itself.
Nov 24, 2011 | LG Flatron L1715S 17" LCD Monitor
My HP 1730 monitor is showing "OSD Lock Out" message. How can I remove this msg?
The following site has step by step instructions on steps you can try: http://www.ehow.com/how_5008634_fix-lockout-display-computer-monitor.html
I'll paste them below: All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on screen display (OSD) lock out that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lock out setting, there are several different ways you can remove the lock out, depending on the make and model of your particular computer monitor.
1 Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
2 Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
3 Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
4 Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
5 Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out.
Mar 01, 2011 | HP 1730 LCD Monitor
After thunderstorm we have picture but no sound left unpluged overnight and had sound for minute then went back off
First and foremost if you don't already have a surge protector I suggest investing in one....Sounds to me from what you are stating the Caps blew on the PSB-power supply board or they have one leg in the door. THis is also the beginning signs that the set is going to go into fault protection mode soon. Pic but no sound, sound put no pic... Vice versa.... When it fully fails you be left with NO OSD-on screen display no sound and a blinking fault LED at startup.
Unplugging for a few hours resets the fault. I would also invest in a cap tester. Recaping is cheap and fairly easy to do.
Aug 06, 2010 | JVC HD-52G787 52" Projection Television
How do I reset my tv to factory settings. samsung 32 inch LA32R81WDx/xSA
On a different Samsung TV, there is a Picture Reset in the Picture Menu on the OSD. (It's at the bottom of the list.) Similarly the sound reset is in the Sound menu. There is no global reset. (If your Samsung TV's OSD menus are different try under the Support menu.)
I hope this helps.
Aug 05, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
TV's picture and sound goes off. Had to cycle Mitsu WS-55513
THERE IS, aside from having the set taken to a shop, One other thing you can try---
NOT THE RESET BUTTON ON THE FRONT OF THE SET!
If the original Mitsubishi remote works on the set---this set has a hidden menu---it also in that menu has a HARD RESET---puts set back to the condition is was when new in the box--will come back on on channel 3 in the air band and any labels you placed on any of the video inputs (ie--named a input DVD etc) will be gone.
If you have OSD but no video either you have some problem with a single voltage coming out of the power supply(shop repair) or if you had a power outage or the power cord was removed with the set on---the hard reset may fix it---nothing to lose--set is not usable now---
Let me know if you want to try the reset and I will tell you how----
REGARDS, SD TECH
Oct 26, 2009 | Mitsubishi WS-55513 55" Rear Projection...
About a month ago, our HP-R4272 stopped turning on. It would just click, intermittently, but no sound and no pix. I called Samsung and they asked, if I press the menu button on the set while it was doing...
It is possible that there is a loose connector inside of the set. BUT if you are not a trained tech have a trained Samsung tech troubleshoot the set because there are thousands of volts inside and will bite you, I know.
Jul 07, 2009 | Samsung HP-R4272 42 in. Plasma HDTV
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Mar 13, 2008 | TruTech PLV1615T 15 in. LCD Television
Televison & Video Logo
118 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
