Question about Dryers
My dryer wont run
It was running fine, a few days ago it started to squeak a little. Then it would not stay on. Now I cannot get it to tstart. The last time it started I had to hold the start button a little longer and it sounded "slow" starting
  • bug87 Jun 29, 2008
    please help
  • 481 Answers
Sounds like something is jamming it up, maybe a drum roller or something fell inside the lint filter compartment. could also be a failing belt. more info would help
Posted on Jun 29, 2008
Dryer drum has an intermittent squeak when running
there is a belt tension'er it might need to be replacing or temp fix greasing or drum bearing replacing or temp fix greasing to do this you will have to remove the drum
May 28, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Dryer was squeaking and now it just clicks when you push the start button
if motor will not run. check it out! it may be seized or in need of oil on end bearings. ( each end of motor ) just get access to the motor.
Feb 01, 2012 | GE Dryers
Maytag mod. #med5700tq0 elec. dryer runs, inconsistent heat, high heat two days ago, little heat a few hours ago, some heat an hour ago, no heat now. Where is the best place to start?
It sounds clogged up to me. Take the exhaust hose off the wall and try it first. Another thing that happens with Maytags is that the motor shaft will **** out the center of the plastic blower and even though the motor is turning, little or no air is moving through the machine, so the high limit thermo turns the heat off
Oct 18, 2011 | Maytag MED5700TQ Electric Dryer
I have a gas dryer Maytag Dependable Care Model 6 cycle about 11 yrs old...Has a steady squeak as it runs , seems to be getting louder . Everything on the dryer seems to work fine other than this...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 14, 2011 | Dryers
GE dryer is not working. a few weeks ago the spinning slowed and it sounded like the drum(?) was too heavy and grinding and then it just stopped spinning -my husband said that the three bath mats were...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 17, 2011 | GE DCVH515EFWW Electric Dryer
Dryer won't stay running, shuts off after a few minutes.
Maybe the timer or wires not hooked up right or motor if u hear like a buzzing sound when u push start it's the motor
Oct 30, 2009 | General Electric DWXR463EGWW Dryer
My dryer wont start at all...
Did you check the door switch. If it is open (not making contact) the machine will not run. Could be the motor start/run switch which could be stuck with lint (clean it) or worn out ( replace the motor).
Sep 18, 2009 | GE DSXH47GGWW Dryer
Dryers Logo
75 people viewed this question
Top Dryers Experts
