Question about Amana Dryers
Amana Dryer Omits Kerosene like odor
Problem with Amana gas dryer... I recently refinished my wood floors and since then my Amana Gas Dryer omits a foul odor when it runs any setting that uses heat. In addition to makking the room foul any clothes that I put in the machine to dry smell as well. Will this problem go away with time or is there a solution that needs to be implemented?
  • 27 Answers
It sounds like the orifice is gone bad
Posted on Jun 29, 2008
Dryer makes a funny smell in the house and makes the cloths smell a lil funny as well???
I would need to smell the odor but a couple things will cause this. One being built up lint that is smoldering so I would definitely investigate inside for this. Also (more common with gas dryers) is when customers are painting or staining and varnishing in the house. This will give clothes a kerosene type odor. Try to think back to when it started and see if anything was changed in the household routine at that time. Good luck, Eric
Aug 17, 2010 | Amana NDE2330AY Electric Dryer
Smelled mild gas odor after moving dryer. Replaced gas line connection. Still smell gas. Tried to tighten gas line have strong gas odor after running dryer. Does not seem to be heating
The gas valve should not be opening unless the glow igniter glows and sends a signal to the gas valve. I suspect a small leak in either the gas pipe or at the gas valve. You will have to get to the gas valve to perform a leak test. While the dryer is open, replace the igniter.
Jan 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Amana NDG2335AWW Gas dryer LP or Natural?
If there are no stickers indicating so, you will need to open up the dryer and measure the gas orifice. A propane orifice should be either a #54 or #58.
Jan 13, 2010 | Amana NDG7800AW Gas Dryer
Kerosene odor from natural gas heater. gas co thinks grates break
The odor your referring to usually comes from you recently using an oil based product like paint or wood oil. Until the petroleum based product has fully dried, the open flame will seem to be the source of the odor but are really just intensifying it. If you have a gas range, see if those burners smell similar. Rags in a gas dryer also cause the odor. The gas co. will check for gas or carbon monoxide  only but this odor is neither. Good Luck and please rate my answer if it was helpful.
Dec 30, 2009 | Procom 10K BTU, Vent Free, 2 Plaque...
My dryer doesn't produce heat. the coil ignites
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. In your machine, it appears Amana doesn't sell the coils as a separate item and the whole valve needs to be replaced. The part number is Y504091.
Disconnect power and turn off gas before working on this dryer. Working on gas dryers is not recommended for people who are not professionals.
Service on gas appliances should be undertaken by professionals only due to the danger of gas leakage which can cause fires or death by asphyxiation.
At front, remove 2 screws near floor at the bottom of the lower front panel. Pull bottom of panel toward you and down. The gas valve should now be accessible on the left. Take care not to touch or hit the ignitor or you will be replacing it also. It is VERY brittle.
Reverse process to re-assemble.
Sep 17, 2009 | Amana ALG331RAW Gas Dryer
After drying, clothes have a soured smell. I really don't think its the washer because there is not a smell there. However, I have run just bleach several times through the washer and have tried candles...
Questions
Gas or Electric dryer?
Is the odor there even when not running?
Have you recently done any painting or stain/shellac in the house recently? Home perms?
Gas dryers will often give clothing a kerosene like odor if the above conditions have occurred. Any sprays or aerosols can have the same effect. Unfortunately only removal of the culprits and time will alleviate this.
Jun 08, 2009 | Whirlpool Dryers
Kerosene smell from the dryer
I have read other places that if you have recently painted, stained, varnished or used something in your house that has some sort of oil base it can make you dryer make your clothes smell like Kerosene. My dryer started doing the same thing and it was at the same time that a contractor was staining some trim in our basement. Good luck.
Mar 22, 2009 | Kenmore 73952 Gas Dryer
Dryer gives off a strong odor which make my clothes smell.
if you have been painting or staining recentley the chemicals in these products are mixing with the mercaptin in the gas to cause the odour. The problem will correct itself when the fumes are gone.
Nov 11, 2008 | Maytag MDG2706A Gas Dryer
Strong odor after staining floors
Is it possible that some finishing paint or what not have leaked onto the venting? And every time your dryer is turned on the venting heats up and evaporates the finishing stuff? If it is a considerable amount then it may take a while to completely eliminate the odour.
Aug 09, 2007 | GE DBXR463GB Gas Dryer
Dryers Logo
199 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
