Question about Maytag Washing Machines
Agitator will not agitate. Also water trickles in instead of flowing in like a tap turned on. Also water leaking under from pipe that goes into plastic component - looking from back of machine bottom left. Model: LAT9400 AGW Serial no. A4401753 Purchased August 21st 1992. Machine sometimes starts to agitate then sounds like its agitating but no movement from agitator. Can fill and spin and pump out water okay.
  • 1 more comment
  • petfarm Aug 23, 2008
    Re Maytag Washing Machine - Thank you for your message. The gause water filters were blocked up and one hadit. The hoseclips had rusted, replaced with stainless. The agitator screw was ok. The belts at bottom/under washer have been replaced. One spring was added to motor support to give more stability. (maybe motor should be wired down when moving as springs were stretched) Without putting another spring had same problem. The tension put on motor drives the belts. Washer going again thank you for your help. ... regards Doemum
  • johnny ray 6 Dec 05, 2008
    i have same problem. Any help?
  • Anonymous Mar 20, 2014
    the agitator cover comes right off its base when the machine fills with water
  • 481 Answers
  • the agitator has a set screw in the side of it about half way down. this may have rusted out or fallen out.
  • the transmissions may be failing (unlikely)
  • the water inlet valves (where you connect the hoses to the washer) have screens in them, they might be clogged causing the water to slowly drip in.
  • the water leak is most likely caused by a rusted clamp loosing its pressure on the hose.
  • the plastic component is the water pump
  • it might be time for a new washer
Posted on Jun 29, 2008
The agitator is only working in one direction so the washing is getting tangled
The top portion of the wash tub agitator is designed to rotate in the clockwise direction. It should be intermittent. Turn stop turn stop its normal operation.
There is a set of plastic cams that allow for this function. Below the top agitator the lower agitator goes back and forth. With a short load the water just reaches the upper agitator. Try short load. Other possibility the tub is under filled try increasing the water level.
26221857-hkbf5riehselkv40qtw2in2z-5-2.jpg Two piece agitator
26221857-hkbf5riehselkv40qtw2in2z-5-5.jpg Two piece agitator.
Hope this helps?
Jun 20, 2016 | Washing Machines
Noise from Whirlpool/Kenmore washing machines / agitator not turning
Many toploading Whirlpool (and Kenmore -- they're made by Whirlpool) washing machines have a ratcheting agitator. The agitator moves only one direction instead of back and forth. There are small pieces (called agitator dogs) that allow this to happen. However, since they are mad out of rather soft plastic, they tend to wear out. The result is a ratcheting or growling noise during agitation (wash cycle) Luckily, they are reasonably cheap (usually under $20) and relatively easy to fix. Try to turn the agitator by hand. It should turn freely one direction and not the other. If it goes both ways freely or clicks and slips one way, you need new agitator dogs. Pull the cap off of the top of the agitator (there are usually two tabs on the side that must be depressed to do this) Remove the bolt in the center of the agitator. Pull out the plastic plate that is on top of the dogs (again, you may have to move two tabs to pull this out.) You should see dogs that look just like the new ones except with no teeth on them. Pull the old ones out and put the new ones in the same way. Reassembly is the same as disassembly except in reverse. It should be quieter and wash better now, as the agitator was barely turning before, if at all.
on Dec 02, 2009 | Washing Machines
Hoover 2300L 6.okg boss. Squeaking when agitating back& forth, not when spinning. Is this a bearing problem? & is it replacable. If so, from where in south australia? Or wherever.?
Washing machines don't usually run silently, but in most cases, a squeaking noise that occurs while the washer is agitating the clothing is not normal and signifies a problem. If the noise only happens when the washing is agitating, the problem is likely connected to the motor or your water pressure. Depending on the specific cause, you may feel comfortable fixing it yourself. Otherwise, call a professional.
Other People Are Reading
The Agitator
  • Agitators are located in the center of the drum, or basket, of top-load washing machines. Front loading washing machines do not use agitators -- instead, gravity moves the clothes from the top of the drum to the bottom. Agitators usually consist of a tall cone fitted with arms at the base. The purpose of the agitator is to rotate the clothes and soapy water around the tub to clean the clothes. The agitator itself is not usually the cause of the squeaking noise. It is powered by the drive mechanism, which consists of a motor, clutch and gears.
Motor Problems
  • A repetitive squeaking noise during the agitation cycle may signify a problem with the motor. Specifically, the belt on the motor may be wearing out. Some motors use rubber couplers, which also wear out easily. The belt is necessary for the agitator to turn, but over time, it wears thin, just like the belts in your car's motor. An easy way to test for this problem -- if you're handy -- is to take the belt off the motor and then run it. If the squeaking noise stops, the problem is indeed your belt. Of course, this means your agitator won't move. Replacing the belt should fix the problem.
Water Pressure Issues
  • The tub, or drum, fills with water right before the agitator turns on, and water continues to circulate throughout the washing process. As the tub fills and water circulates, you may hear a squeaking or squealing noise if you have high water pressure. This sound is caused by the force of the water moving through the pipes. To adjust this, turn the knobs on the hot and cold valves on the pipes that go into your washing machine.
  • New washing machines may squeak at first as the parts "warm up," according to the GE Appliances website. The noise should disappear after five complete washing cycles have run on the machine. Unbalanced loads, overly heavy loads and loose items in the drum may also cause noise when the agitator comes on, but these things usually do not produce a squeaking sound.
Read more : My Washer Squeaks When Agitating eHow
Jun 14, 2015 | Hoover Washing Machines
Water just trickles out of the waterfall faucet
Look for the obvious-take off the screen. Then you may have to venture into the faucet itself. If you have galvanized pluming, every time you shut the water off, scale will fall int the center of the piping without pressure and then when you open the faucet it tries to flow through small orifices.
Dec 13, 2013 | Garden
Washer won't drain and go into spin
ok it sounds like your pump is blocked. heres what to do. 1st-- drain water out with a pot or small bucket. now you can remove the agitator by removing the center of the agitator and looking down the center of it and unscrewing the plastic wingnut,then lift the agitator out.this will make it easier to remove the water with a pot or bucket. once it is drained, pull the machine away from the wall and tip it back so you can see underneath. look to the right, do you see a red or black fan? if you do this, is your pump.try turning the fan clockwise then anticlockwise to see if it loose. now just another question, where is the water draining into?is it draining into the sink or on the s bend on the drain pipe?if the pump is tight and turning it loosens it then you might have fixed it. put the agitator back on and select a spin cycle and hit the start button. it should start draining. please reply if it does not. also if your drain hose is on the tub pipe, remove it and see if there is a blockage on the spout.please reply for further help if required.
Jun 02, 2010 | Fisher Paykel EcoSmart GWL15
Kenmore model 24054 washer that leaves dark streaks on clothes.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the following for how to access the console, pull the cabinet, agitator(s) and tub if necessary.
You don't have to pull the pump, motor, transmission and drive tube to pull the agitator and tub.
A number of the diagnostics and repair procedures for these washers require you to remove the agitator(s).
In order to get the agitators out, you need to remove the "Spanner Nut" and "Drive Block".
Many instructions call for a special spanner wrench to remove the nut. However,
You don't need a special spanner wrench. (About $20 retail)
I've used a short 10" pipe wrench (About $9 also good for cracking walnuts) hooked around one of the tabs on the spanner
nut and tapped the handle with a hammer to loosen it.
Also, don't directly hit the drive block with a hammer (it's soft metal). Put a short piece of wood under the drive block and tap it up with a hammer.
With the agitators and tub out, it's relatively easy to clean out the gunk that builds up over time.
Apr 25, 2010 | Kenmore 24052 Top Load Washer
Washer is leaking out of overflow tube
check the drainage pipe, the hose goes into and make sure its not clogged, once you know there are no obstructions reattach the drain hose. be sure it goes a couple of inches into the pipe but has a little space for air flow between hose and pipe. I this doesnt fix the problem the hose made need to be raised, it should enter the pipe several inches higher than the washer. Hope this helps
Nov 28, 2009 | General Electric WHDSR209DWW Top Load...
Grease leaking into drum under agitator cone
Remove the agitator cone. There will likely be a removable plastic piece with an O-ring. Oil could be leaking out of the O-ring into the washer, and water could be leaking into the bearings. If there is damage to the O-ring replace it, or if there is a bunch of schmag that is compromising the seal, clean it out, and re-install everything. This solved the problem in my washer; hopefully it works for you.
Sep 28, 2009 | GE Washing Machines
The agitator on my ingis liberator is no longer working
Try to do this
Good luck !!!!
Jul 08, 2009 | Washing Machines
No water is coming in the washer before the agitator starts
The above answer is copied from Washerhelp Please only use small quotes and link to the original source
Mar 29, 2009 | Whirlpool Washing Machines
Open Questions:
Washing Machines Logo
157 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
