Question about Refrigerators
My Whirlpool refrigerator model ED20DB/DF the freezer portion seems to have stopped freezing, but the refridgerator side sems ok??
  • 481 Answers
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Posted on Jun 29, 2008
Refridgerator Stopped working , Freezer Ok
It is your defrost heater, you can get them from marcone.com with just your model number. Also at that web site you will get a exploded view of your unit. thiswill allow you to see the location of the heaters so you can just replace where the frost develops.
May 02, 2012 | Whirlpool Refrigerators
We have a refridgerator, about 2-3 years old, Model #ED5JHEXTB00. Side by side freezer, refridgerator that is not cooling as much as it should in the refer part. I'm not sure of the temp, but milk goes...
if your noticing frost on the back wall you have a defrost problem and need to address it immediatley before u get warm in freezer and refrigerator sides remeber that a refrigerator is just a cold air duct from the freezer.... defrost heater bimetal defrost thermostat ot timer defrost control is bad ...
Feb 01, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool model # ED25DQXDW04 - Everything freezes in the back of the refrigerator and it stopped making ice cubes - no water comes into the freezer side to make ice cubes. We're throwing away a lot of...
This may not be the problem now but by the sound of the malfunctioning ice maker, it could be in the future. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 07, 2010 | Whirlpool ED5FHEXMQ Side by Side...
Too cold
If the unit seems to be running non stop, you may have a bad cold temp control. If you have ice cream in freezer, it will likely be rock hard, that you need a chisel to scoop. if your ice cream is ok, its likely not the temp control. On your GE, in the fresh food section, do you have a canopy on the ceiling of fridge, and likely covers the whole top back portion of your fridge? If you do, there is a damper door inside, that breaks off its hinge, and stays wide open, allowing cold air from freezer to constantly be pulled into fridge, freezing food. If you do have this canopy, it will need to be replaced, as you cannot reattach the damper to its hinge.
Feb 15, 2010 | GE Profile PSW26P Stainless Steel Side by...
Whirlpool Side by Side: Freezer freezes refrig doesn't cool.
check for a blockage. There is only one cooling section, divided by airflow for freezer / fridge.
Perhaps something sticky is in the vents, or the freezer section has poor airflow, resulting in ice formation.
Unplug the unit for several hours, clean out vents, and make sure freezer section has good airflow from the vents.
Aug 30, 2009 | Whirlpool GS6NBEXR Side by Side...
Fridge is freezing
there is a way to adjust it but its very difficult..best to just replace it. the thermostat that is.
Jun 09, 2009 | Whirlpool ED2FHGX Side by Side...
Grinding, Howling Sound Coming from Freezer
You almost certainly have a defrost fault building up ice around the fan
Mar 15, 2017 | Whirlpool ED5FTGX Side by Side...
Maytag Refridgerator and not cooling or freezing
sounds as if perhaps the overload replay has burnt up on the compressor, you can see it by removing the back cover, unplug unit and remove the starter from the side of compressor. if burnt up or melted youll need to replace it.. before you do i would call the manufacture with model and serial theyve experienced issue with some of these depending on model and serail they may cover repair
Mar 10, 2009 | Maytag MSD2651 HE Side by Side...
Whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
the first one sounds like it is slowly leaking freon.
  •  the second Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
Jun 28, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
229 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
