Question about Canon PowerShot SX100 IS Digital Camera
Lens Error I keep gettin lens error restart camera on my canon powershot sx100 and the lens wont retract. I have turned it on and off several times now. Is there anything i can do to get it working again?
    Novelist:
  • 164 Answers
Unfortunately this Canon SX100 (and the SX110 too) has a very fragile lens assembly. Once you have this lens error problem, there are only four solutions: 1) If it's under warranty, contact Canon to make it valid; 2) If not, then have a repair center to replace the lens assembly (either the internal lens motor or the gears are damaged) or, 3) Sell it for parts or 4) send it to the trash can.
Posted on Jul 13, 2009
My Canon Power Shot SX100 IS says lens error. restart camera. Help
Aug 24, 2009 | Canon PowerShot SX100 IS Digital Camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 21, 2009 | Canon PowerShot SX100 IS Digital Camera
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Apr 26, 2009 | Canon PowerShot SX100 IS Digital Camera
"Lens error - restart camera" message, but won't restart
I just had the same issue when one of my children drop the camera. I'm not wanting to break anyone's camera but I was able to open the lens cover and pull the lens out and then turning it on it retracted and worked just like it should.
Apr 19, 2009 | Canon PowerShot SX100 IS Digital Camera
Canon PowerShot SX100 IS Lens Stuck
If the lens does not extend/retract when the camera is powered on, then lens assembly is damaged.
Unfortunately, such Canon SX100 (and the SX110 too) has a very fragile lens assembly, and it's damaged very easily. Most of the times the internal gears, the plastic post guides and the motor are damaged at the same time, so the only solution is to replace the whole lens assembly.
The lens replacement requires a qualified camera repair technician, unless you want to try in repair it yourself, which requires tools (scredrivers, soldering iron, desoldering tool, magnifier glass with light, etc).
Best regards,
Oct 14, 2008 | Canon PowerShot SX100 IS Digital Camera
Lens error restart camera but it just switches off i keep getting a lens error restart camers error i turn it off and on but get the same error
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Aug 28, 2008 | Canon PowerShot SX100 IS Digital Camera
Lens error
sir,problum is ur lens unit,some mechanical or dislocations,gears this is repairable u try ur local service center
Apr 11, 2008 | Canon PowerShot SX100 IS Digital Camera
Canon PowerShot SX100 IS Digital Camera Logo
204 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
