Question about Kenmore Dryers
Kenmore dryer not heating
My dryer is not heating. The elemnt and limits are good. The thermister ohms out at 12ohms. Is the main control board bad?
  • 481 Answers
  • before you go any further check the outlet and make sure you are getting a full 220v
  • sometimes one side of the circuit breaker will trip causing the unit to run but with no heat.
Posted on Jun 29, 2008
I have a Kenmore/whirlpool dryer without heat. I checked the thermal cut of and high limit thermo and they are good. The instructions say to test the thermistor i need to check the resistance on the...
did you check the heating elements, check to see if you have continuity through the elements. If you do they are good. unplug the wires to the elment because you may get feedback through the wires. I hope this helps
Jul 19, 2014 | Kenmore Dryers
I have duet dryer GEW 9250PW0 with no heat. I have changed Thermister, Thermal cut off, high limit thermostat, heating element, and main board. I've check pwer cord and oulet and they check fine
You didn't mention checking the "cycling thermostat".
The two large terminals will be closed, and the two small ones should ohm out around 250 ohms. You also need to check and make sure you have 240 volts coming to the dryer. You could have one of the two breakers thrown. Here is the cycling thermostat in case you find it bad.
Keep me posted on your findings.
Oct 22, 2012 | Whirlpool GEW9250 Electric Dryer
I have a whirlpool cabrio dryer model WED6600VWD. What does the F1 error code mean?
The F1 error code means that the thermister (cycling thermostat) has a open circuit and should be replaced.
To check the thermister you would need to DISCONNECT POWER TO THE DRYER remove the lower small front panel below the main one where the door is at and using a digital meter set to measure ya would remove the wires from the thermister and check for appx. 5,000- 7,500 ohms at room temperature.
If the ohms at within 5 thousand to 7thousand 5 hundred at room temp. the thermister is good and the control board is what the problem is....if the ohms is way lower or higher that 5-7,500 ohms the thermister is going to be what would need to be replaced.
Here is what the thermister looks like
I hope i have been able to help you fix your dryer,
GENE
Oct 31, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Electric dryer spins no heat, replaced heater element and high limit thermostat, tested thermal fuse and it does have 0 ohms, thermistor reads ~50 ohms.
in addation to checking the high limit t-stat have you checked the thermal cut off (the small t-stat) on the heater housing where the element fits into, the high limit t-stat and the thermal cut off BOTH shoud have 0 ohms (the thermal fuse is in the blower housing) the cut off is on the heater box, if you have checked those to be good, check that the heat relay on the control board is closing and sending power to the element, if not replace the control, if all above are good then the motor switch is bad and not sending power to the element(thats a built in safety feature so the dry would never heat when the motor isnt running)the element of course heats only when 240 volts ac is to the element ,120vac from the relay on control through the high limit t-stat then through the thermal cut off finally to the element and 120vac from the motor switch for a comined 240 vac
Jul 20, 2011 | Kenmore Dryers
Dryer not heating mod # 110.64652400
you may have several problems, first, check the thermal cut-off with a meter(continuity) at the side top or the heating element. if not beep or mesure "0" on the display then is bad, change it as a kit#279816 part# at Sears. if is good(it beeps) then check the heating element for ohm about 10 to 12ohms. if it reads "0" then is bad, part#279838. if is good then check continuity on the thermal fuse at the blower housing(a white 2prong part) if it not beep then change ir part#3392519. all parts at Sears Website or Sears Service Center. good luck to you.
Feb 06, 2011 | Kenmore Dryers
I have a kenmore he4 no. 110.85871400. i have no heat replaced thermal fuse high limit thermostat anf thermal cutoff switch. still ni heat. elements are good. cleaned all lint. do i need to get a...
Check thermistor with ohm meter, make sure you unplug unit first, make sure wires are removed from thermistor or you will read ohms thru the wiring. If thermistor checks ok, the you have a relay board problem. replace power board.
Sep 29, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Dryer not heating
thermal fuse kit.it is blowing due to improper ventilation.their is a clog somewhere from dryer to where dryer vents outside.thermal fuse is located at top of your elemnt cage.you will replace the thermal fuse and your high limit fuse at the bottom of the elemnt cage.but have your venting checked or swept out.
Mar 09, 2009 | Dryers
Kenmore 84152 /94152
probably the heater
Jan 15, 2009 | Kenmore 63942 Dryer
Hello My Kenmore 84152 dryer stopped making heat. I have varified the 2 thermo units each read 0 ohms the lower thermister on the blower houseing read 89.4k ohms and I can't for the life of me get to the...
AS LONG AS YOU GET READING THE IS GOOD ,NO READING AND THE PART IS BAD,TRY TO GET ONE OF THE TERMINAL OFF THE HEATER COIL AND YOU STILL CAN TEST IT THAT WAY,MORE THEN LIKEY IT IS THE HEAT ELEMENT BECAUSE EVERTHING TEST GOOD RIGHT?HOPR THIS HELPS,THANKS-MIKE
May 30, 2008 | Kenmore Dryers
Dryers Logo
35 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
