Question about SanDisk Sansa View 8GB MP3 Player - Black
Only get 20 seconds of play
I just purchased a 16gb sansa view. I recoded from fm radio. When I drop and drag files in media player It onlt plays 20 seconds of the file.then gives errror message that it is not a recognizable format
I downloaded the new the updated firmware which corrected the problem.
Posted on Jun 30, 2008
Its not playing videos
First step --
Download a PDF copy of the Sansa View manual. Here's a link:
http://www.google.com/search?client=ubuntu&channel=fs&q=sansa+view+manual&ie=utf-8&oe=utf-8
There are two likely reasons for the video not to work;
1) The software that runs your Sansa View, known as 'firmware', is outdated;
2) Your video requires conversion before you download it.
1) Firmware update?
Download a copy of the Sansa Firmware Updater from here:
http://kb.sandisk.com/app/answers/detail/a_id/4431
Start it on your computer, and follow the directions to update your Sansa View's firmware, if needed.
2) Download and install the Sansa Media Converter (SMC) from the same link above.
--Plug in your Sansa View to the computer, and run the SMC.
--Follow the directions to select your video. SMC processes one video at a time for upload into your Sansa player.
Another possibility - Try loading video from Windows Media Player 11;
From the manual, page 17--
"Your Sansa View player supports MPEG-4 Simple Profile up to VGA, H.264 Baseline Profile up to VGA, and WMV up to QVGA video formats.
That means you can simply drag and drop these files into the Video folder if you are using Windows Media Player 11."
Hopefully, that will help you get your videos in!
Nov 03, 2011 | SanDisk Sansa View 8GB MP3 Player - Black
HOW DO I PUT MOVIES ON MY MP3 PLAYER
Hi mary_harbaug
Please everyone that comes across my info take a few seconds of your time to rate my solution which you can select at the bottom of my answer Was this solution helpful? YES or NO :)... As i have taken time to answer your question the best i can Thank You......
Coby is an electronics manufacturer. It offers a wide range of portable devices including portable MP3 players and portable video players. These devices are small and can play audio files, video files, FM radio and display photos. All media can be added to the device easily using a simple drag and drop method on your computer. You can also use that method to delete files from your device. Supported video formats include WMV, FLV, and AVI.
Instructions
  1. Connect the Coby MP3 player to your computer using the supplied USB cable.
  2. Click "My Computer." Select "Removable Disk."
  3. Select the "Videos" folder.
  4. Drag and drop the video files you want on the device into the Videos folder associated with the MP3 player's disk.
Jan 24, 2011 | Coby MP-705 Digital Media Player
How do i get music on to my sansa clip+?
Loading Music
You can transfer music from your computer to the Sansa® MP3 player using the drag-and-drop method or using music management software like Windows Media Player.
Drag and Drop (Windows)
Follow these steps to drag-and-drop music to your Sansa® Clip+ MP3 player:
1.
Connect your Sansa® Clip+ player to your PC.
2.
Select Open device to view files using Windows Explorer on initial connection or by going to My Computer.
3.
Double-click on the Sansa Clip+ MP3 player.
4.
Double-click on Internal Memory.
5.
Double-click on the Music folder.
6.
Drag and drop music files from your computer to the Sansa® MP3 player’s Music folder.
You can also drag and drop files to a microSD™ card inside your player by going to My Computer > Sansa Clip+ > External uSD Card.
Feb 07, 2010 | SanDisk Sansa Clip MP3 Player
Downloaded books from the library won't play
I was having the same problem when I used Overdrive Media Console to transfer my audiobook files to my Sansa. I updated the license and retransferred and even tried changing the USB settings on the mp2 player. What finally worked? Using Windows Media Player to sync the files instead. When I hooked up my Sansa I chose "use WMP to sync files" and then I dragged/dropped the audiobook files to the mediaplayer window. The audiobook now plays without any problems since WMP made sure the files have the latest subscription update code.
Jun 01, 2009 | SanDisk Sansa e260 MP3 Player
Screen Frozen
HJust hold the off button for 10 seconds. or whenver it turns off. u will be fine
Dec 28, 2008 | SanDisk Sansa Fuze MP3 Player
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
Loading My ITunes library into new Sansa Clip
Hey guyi,
According to information provided by the manufacturer (Sandisk), the Sansa Clip MP3 player can use two different methods to upload songs: a simple drag-and-drop interface, or syncronizing the player with Windows Media Player.
With the traditional drag-and-drop interface, you would need to connect the player to your computer and select the "Open device to view files using Windows Explorer" option when it is presented. Once you have done this, you should be able to double-click on the "Sansa" player and then the "Music" folder. After this folder has been opened, you should be able to drag and drop (or copy/paste) the files into this folder to upload them to the player.
For more information or instructions on how to add files to your Sansa music library using Windows Media Player however, you may wish to refer to your owner's manual or the following link on the manufacturer's website:
http://www.sandisk.com/assets/File/Downloads/user-guides/clip-usermanual.pdf
Unfortunately Windows Media Player does not currently appear to support the ability to directly import iPod playlists, but if you keep most of your music files in the same folder/directory on your computer, both programs should be able to share the same music library. Please keep in mind that this may only apply to music that you loaded onto the computer yourself and other unprotected file formats that both programs recongize (like .MP3 files), and may not necessarily apply to copy-protected songs downloaded from iTunes or other online music services.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
May 06, 2008 | Audio Players & Recorders
Fm radio
Open My Computer. Double click Sansa player. Open the Internal Memory icon. Open the Record folder. Transfer recordings to your computer using a drag-and-drop method. Use your cd recording software to burn to CD.
Dec 27, 2007 | SanDisk Sansa E280 MP3 Player
Sansa e250 using micro sd card
Go to the knowledge base on the Sansa site and find this (chances are you have an SDHC card in an incompatible unit):
Sansa e200
 - verify the version of the player.  To check, go to SETTINGS > INFO
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
NOTE: Firmware is not interchangeable.
Sansa e200R - up to 2GB microSD cards
Sansa e100 - supports SD cards up to 2GB
Nov 12, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa View 8GB MP3 Player - Black Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
