Question about Microwave Ovens
Trying to resiter audiobobx and do i need to activate it
  • Microwave Ovens Master
  • 9,098 Answers
I would try Audiovox's Web site: www.audiovox.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 04, 2008
Having touch-pad problems with my KitchenAid KHMS2056SSS-0 range hood microwave. It's an intermittent problem where the touchpad activates itself and activates menu items.. and beeps each time. Resetting...
Usually the top vent front panel is held in by two screws and or clips, Get those off and the bottom of this peace should un hook, unless there are screws there also. if you can get this far, the rest will be obvious.
Oct 20, 2013 | KitchenAid Microwave Ovens
Hi,i have a lofra max maxima oven and my stove,which i control by touch isnt responsing to me.please is there any solution?
Here is something to try:
This is from Lofra manuals
It's possible to lock the selected functions by keeping the "Key" button pressed . An acoustic
and flashing warning will activate whenever any changes to programmed function are tried to be
made. By activating this function it's possible to switch the Electronic Module off while the
function controls remain active. To deactivate the lock keep the "Key" button pressed a second
time.
If you still have your owners manual look up child lock. If you do not have a manual and the oven door is unlocked I really need a model number.
Thanks,
Kelly
Jun 20, 2011 | Microwave Ovens
The fan will not turn off
Hi, this means that one of your 3 door switches is faulty and isn't detecting that your door is shut. You'll need to remove the control panel and try to determine which switch is either not being activated when the door is shut or which switch isn't working correctly and then you'll need to replace the switch.
Apr 17, 2011 | Microwave Ovens
I have a built in Whirlpool oven (RS696PXGB7). The door almost closes but does not have a secure seal and the light doesn't go off. It seems as if the hidges are too weak to close it all the way. Is...
HI U WILL HAVE A CLIP ON EACH HINGE .... PULL CLIP FULLY OPEN ...SLOWLY CLOSE THE DOOR ..IT WILL COME OFF THE INNER HINGE ... RESIT BACK IN AND DO DLIPS BACK UP.. TRY DOOR SLOWLY INCASE YOU HAVE NOT SAT THE HINGE BACK ON RIGHT ,,, THIS WILL CORRECT THE PROBLEM. CROSS FINGERS ... JUST KEEP TRYING U WILL DO IT.
Feb 27, 2011 | Microwave Ovens
Kenwood Microwave oven CJ/AL28 The turntable is not rotating. Have tried moving the piece underneath glass and it is locked in position. How can I resolve this issue? Many thanks S. Heal
Hi and welcome to FixYa, I am Kelly.
POWER OFF / UN-plugged
To gain acces to the motor the outer chassis must be removed. 4 side scews and 6 rear screas.. then life the rear of the outer cabinet 10 degrees and slide it aft to unlock the front tabs. Then remove the cover. Before you do anything; take a good screwdriver held by the handle and ground the HV capacitor 3 times across the 2 terminals to prevent a horrible shock.
The turntable motor will accept input (0utlet) power when disconnected and a test cord connected to the turntable motor PN TYJ5807A. Some of these are 24 Volt motors... make sure you look on the motor to determine the voltage. You can test the motor for resitance on R x 1,000 scale. I should read resistance to the 2 terminals only and NOT to the case. If it reads from either terminal to the case the motor has failed. The windings in these motors are MUCH thinner than human hair. http://www.buyspares.co.uk/search.pl?query=TYJ508A7
or
http://www.4kenwood.co.uk/cgi-bin/product.pl?PID=944115
Take a good look at the motor drive post and make sure it matches yours. I could not find an exact parts break down for the CJ/AL28 but most turn table motors are common in a brand.
Thanks for choosing FixYa.
Kelly
Nov 28, 2010 | Emerson Microwave Ovens
Range controlpad is no working, is showing SA6& each burnershows 56 orS6
Hi and
SA (burners off) is a door lock switch A problem. The switch has to be checked for 0 resistance across the terminals. If it has resistance then there is another resitance check to look ofr 2350 Ohms between pin 5 in plug P4 and terminal N. If the meter reads zero or infinity the lock motor or the wiring to the lock motor is defective. If the meter reads 2350 Ohms replace the electronic oven control.
This is per page 97 of the service manual: (C/P)
http://frigidaireservicetips.com/pdfs/477_5.pdf
Remove power from the range and go to the back of
the control and disconnect the P3 plug. Measure
the resistance between pins 3 and 4. If the meter
reads infinity check the oven door switch and the
wiring to the door switch. If the meter reads zero go
to step 2.
2. Measure the resistance between pins 1 and 3 of
plug P3. If the meter reads infinity switch A of the
lock motor assembly or the wiring to switch A is
defective. If the meter reads zero go to step 3.
3. Measure the resistance between pin 5 in plug P4
Thanks for choosing FixYa,
Kelly
Nov 24, 2010 | Kenmore Microwave Ovens
Hello I am not havingany problem.I need to activate ,my danby microwave warranty.
Go to this link:
https://www.danby.com/registration.php?ln=CE& (copy and paste)
If you have purchased an extended warranty you will need to go to this page to activate the extended warranty.
https://www.danby.com/warranty.php?ln=CE&tip=EXT
Kelly
Sep 20, 2010 | Microwave Ovens
GE xl1800 active vent bulb replacement
I think the key is pulling the vent to the left.
From page 36 of the online version of the owner's manual, which also mentions the active grille's presence on some models:
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your
GE supplier.
To replace the oven light, first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
Jan 10, 2009 | GE JVM1870 Microwave Oven
R-A795 microwave
just how old is that unit
replace that microwave
power source popped
DIY repair may result in a fire
Apr 28, 2017 | Sharp R-7A95 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
