Question about iLO DVDR05 DVD Recorder
No picture I have hooked up this dvdr several diferent ways and i cannot get a picture. i do get sound.
  • chasf Sep 14, 2008
    I just bought this-su[pposed new but apparently not.
    There is no video output to my tv and I have tried set up to reset to defauklt but since I cannot see the prompts I am having problems.
    Can someone help me to rest to factory defaults?
Hook the antenna to the ILO then use the outs to the tv. You may also try the Svideo from the ilo to the tv. Sounds like your audio is hooked up correctly but the video is on the wrong set of outputs.
Posted on Aug 18, 2008
I have my television outputs connected to the inputs on the ILO. I then select that set of inputs with the SOURCE button rather then using the built in tuner. Make sure you connect the Video closest to the audio inputs(or... least confusing, try the three front inputs) Hook antenna to tv
Posted on Jul 01, 2008
Connect dvdr to tv aerial no picture on tv
If you go to DVDR with the cable, then you need a cable coming out of it to tv.
Dec 02, 2014 | Socket Home Security
No sound from dvd player(picture is fine).works on another tv
Try another way of hooking the Player up to the TV, you have several options here to do that on modern TV's
Dec 29, 2011 | LG Televison & Video
I have a Plasma TV LG model # 42PC1DA. We have perfect sound, but no picture. Tried the contrast, tried unplugging for 30 min. What could be the problem and how much might it cost to fix it?
Did you tried diferent sources from where you get the image? For example you could try to connect a video camera, laptop, dvd or any other thing you could hook it up in your TV and check if there is still no picture.
If the screen is burned it costs the same or a bit less than a new one
Good luck
May 06, 2011 | LG 42PC1DA 42 in. Plasma HDTV
Have a DVDR 3460 / 97 model of Philips . Have yet to commission same . Am unable to record from audio cassettes to the DVDR disc although the local Philips service agency assured me that same was possible...
There are a number of different RW DVDs out there and your problem could be one of the following:-
That you are not following the instructions
That the discs you arer using are not the correct ones(usually they have a leter or a number on the disc that marks the diference between diferent discs from different manufacturers) I would suggest buying the Phillips discs then that cancels that problem.
That the leads you are using are incorrect or faulty.
OR lastly
A fault on the machine.
The last option is that you physically go to either where you bought it or the philipps centre and ask them to show you how to do it. You paid for it so you deserve the service.
Feb 12, 2010 | Philips Televison & Video
No DVD sound LiteOn LH-20A1L
The audio lines from the DVD player should be hooked up to the sound card.  If the two audio wires are not connected, no audio will happen.
Sep 21, 2008 | Lite On Lite-On LH-20A1L-06 SuperAllwrite...
Zv420mw8 dvdr with vhs player/recorder
vacrel please give me some more information;
1 tv model and maker
2 what type of cables did you use to hook to the tv (colors)
3 did you hook the output of the dvd to the input of the tv?
4 the hum is the wrong cable hooked to the audio a yellow video cable connected to a white audio will produce a hum and no picture.
Please advise i you are color blind in any way. thank you
May 27, 2008 | Televison & Video
Connecting up CRT TV, VCR, DVDR and digital box
I think the better task is (A)
You can try switch scart's!! Then try to record on DVDR or leave as it is and look out for picture on your VCR!!! If you do (B) you will lose a picture quality!
good luck
Jan 31, 2008 | Televison & Video
TV, Sky, DVDR, VCR + Wii connection
i cant see any problem with the connections. have you tried to connect the dvdr along with sky to another tv set? and did the same problem occured? if not, try connecting it the same way with another tv. and see if thesame problem would occur. if the same problem appears check if the connections from sky to dvdr scart if it is loose or not. try to clean the solid wire of the cable. if proble still persists dvdr is faulty. if not, defenitely there is a problem with the tv. and i suggest for you to have it checked.
Oct 06, 2007 | Televison & Video
Television Problem
First off can you answer this:Is it possible to hook up my Mitsubishi 60" Gold rear projection tv (with Picture in a Picture capabilities) to my "Direct TV DVR", Phillips AV receiver and Phillips DVD player so I can receive picture in pictures of diferent channels i want to view of my "Direct TV" satellite provider. If so I would be glad to pay you for the easy to follow directions and drawings of the possible solution to my problem.
Sep 20, 2007 | Mitsubishi VS-5047 50" Rear Projection...
Sound but no picture
Apparently your TV doesn't support the progressive mode (480p). You should be able to turn it off by pressing the pause button on the recorder for about 5 seconds, untill it turns off I guess. Hope it works
Jun 13, 2006 | Sony RDR-GX315 DVD Recorder
iLO DVDR05 DVD Recorder Logo
96 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
