Question about Sewing Machines
Serger Machine My serger machine is running with a kind of hammering noise. I am suspecting that its timing is out. How can I fix that? The feed dogs on my serger will stick at varying levels and the hand wheel is extremely difficult to turn. Do you have suggestions for at home repair? Claudia
  • Anonymous Mar 28, 2014
    give me more
    Genius:
  • 3,422 Answers
HI,
If the timing is "out", you will not be able to form the chain stitch.......do a sample to see that you have all 4 or 3 threads involved in forming a complete stitch.........if you do, then it is not timing.
Posted on Jul 08, 2008
  • Priya darshan Jul 08, 2008
    While slowly moving the handwheel manually, rocking back and forth
    and/or full rotation.....remove all threads for this..., carefully
    observe:
    the two loopers should almost touch as they pass each other
    lower looper should almost touch the needle/s as it passes
    is lower looper needle guard colliding with either needle/s or upper looper
    are feed dogs colliding with needleplate
    are knife blades burred, check for smooth surface/s
    are loopers burred (gently run finger along looper up to &
    over the point, on all 4 surfaces they should be smooth & free of
    "lumps")
    there may also be a load of lint inside the base.......if you open
    this, be ready with vacuum and do it over newspaper with machine on its
    back.......use a small brush to assist.
    also,
    are your needles new and sharp
    if you have sewn through pins, things can go out of balance, or get jammed inside.
    Does the handwheel feel free all the way around, or is there a "tight"
    spot......where is everything (relative position of loopers, needle/s)
    when this happens, is anything obviously holding back the movement, or
    clicking as it passes....is it in the same place at each rotation ?
    Once you have a better idea of the specific area/s of concern, post
    back with lots of detail and maybe a photo, and we shall have another
    go at specific resolution........at this stage, there are too many
    variables to say straight off what it is causing the noise.(source:fixya's Bargainbox)
    Hope this helps..
    Please don't forget to rate the solution.
    President:
  • 2,712 Answers
Looks like you have a problem with either the wheel or the gears. I would recommend getting a professional to take a look, as we cant do any thing more in this forum..We can only offer you guidance..
Posted on Jun 28, 2008
Thread nesting below plate with material pulled down inside also.
you might check your upper and lower knives. If they have a chip out of them or are dull some material just will not feed
Apr 06, 2014 | Brother 1034D Serger Sewing Machine
Have an Toyota 6600 model Serger. The knives won't cut, won't stitch and tread keeps breaking from the right hand needle...
you might want to replace the knives
you might have the serger checked for a timing problem
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
10. If all of the above suggestions don't help then the serger needs to be checked for a timing problem at a sewing machine repair shop.
Nov 05, 2013 | Sewing Machines
I need to know how to oil a simplicity serger-easy lock-with differential feed
I have a Simplicity serger SL880 that was my mothers. She past away about 8 years ago. I was trying to use it but appears the motor may be locked up that moves the feed dogs. Is there a place to oil it? If so where? Thank you.
Apr 18, 2011 | Simplicity Serge Pro SW432 Mechanical...
Babylock Serger loosing power
Your problem is probably the stitch length adjustment cam (located on the left side of the machine) To fix this problem you will need to remove the small plastic cap (with red arrow) covering the screw securing the cam. It is usually also necessary to remove the connecting rod/sleeve that the cam rides in. Once both of these parts have been removed, you will need to carefully separate them and resurface the inside of the sleeve. This can be done with a very fine (500grit or higher) emery paper. Once the cam fits inside the sleeve without binding, reassemble using sewing machine oil or lithium grease and adjust feed dog timing.
Jul 13, 2009 | Baby Lock Eclipse Serger
Feed dog on Serger Babylock 5260D
Make sure that the presser foot dial (the silver "knob") on top of the machine is not too loose. You can adjust this w/ a nickel; tighten it all the way down & then loosen about 4 full rotations for cotton fabrics. Also make sure the Differentail feed lever is on "N". You can order a book from your local Baby Lock dealership for all models. Good Luck.
Mar 19, 2009 | Singer Quantum XL-5000 Computerized Sewing...
Feed dogs on serger don't advance
I use my BLSE200 all the time and ran into the same problem just last week. After pulling out my hair in frustration, I finally realized it had to do with the stitch length. Something wasn't connecting after I adjusted the stitch length, so when I re-set the stitch length, it popped things back into alignment and the feed dogs started working again. *whew* Hope that helps!
Jan 18, 2009 | Baby Lock Eclipse Serger
Serger Machine
I suspect there is a likely collision of parts, there are several possible contenders, tolerances for most are very small, 0 - 0.2mm, so a very good light and magnifying glass are useful, as is good hearing for when the click or clunk happens....
While slowly moving the handwheel manually, rocking back and forth and/or full rotation.....remove all threads for this..., carefully observe:
> are loopers burred (gently run finger along looper up to & over the point, on all 4 surfaces they should be smooth & free of "lumps")
there may also be a load of lint inside the base.......if you open this, be ready with vacuum and do it over newspaper with machine on its back.......use a small brush to assist.
also,
Does the handwheel feel free all the way around, or is there a "tight" spot......where is everything (relative position of loopers, needle/s) when this happens, is anything obviously holding back the movement, or clicking as it passes....is it in the same place at each rotation ?
Once you have a better idea of the specific area/s of concern, post back with lots of detail and maybe a photo, and we shall have another go at specific resolution........at this stage, there are too many variables to say straight off what it is causing the noise.
Happy hunting......
Feb 29, 2008 | Sewing Machines
Sewing Machines Logo
229 people viewed this question
Top Sewing Machines Experts
Irene Tulloch
Are you a Sewing Machine Expert? Answer questions, earn points and help others
