Question about Behringer F-CONTROL AUDIO FCA202 External Sound System
System freeze i click to install the driver it asks ti okug the device in and it freezes straight away. It should work with the adapter chord because my friend with the same set up uses a chord to change it to mini usb and it works fine. hope to hear from you
Hey Alex, it will be driving you nuts I expect. I have had a similarly annoying situation with thi set-up and Skype. I used it to record interviews, and using the mic channel allowed me to take the sound from the pc right into the conversation giving me a very good recording that could go right into the programme with the effects etc. A couple of days ago, after a skype update, it was gone. I am working on this as I write to you and if I can get the device to start I will let you know. I think it is something to do with what they call the 'null driver' which is really already there with windows. These things fiddle right at the kidney, or perhaps the large bowel of windows. Good luck, and please let me know if you get anywhere.
Posted on Jun 28, 2008
Ok heres my problem when my computer comes on it says it wasn't shut down correctly and when i have it to start normally nothings happens it just freezes and when i have it start from last known working...
Most likely the driver that ha gone bad is the video driver. Let's troubleshoot the problem first by finding out if this happens on Safe Mode. Perform the following steps. Make sure the computer is off.
1. Turn on computer
2. Start tapping F8 key right away (once per second)
3. You should be looking at your screen with the Windows Advanced Boot Option menu similar to the picture shown below.
4. Use your keyboard's UP arrow key to highlight Safe Mode with Networking.
5. Press Enter key twice.
6. Log on to your account if prompted.
7. Click on Yes button to continue loading the Safe Mode.
8. Close any window that may come up on your screen.
In some cases, you may notice that everything seems to be in bigger size. This is normal on Safe Mode because it is using the native drivers for your computer.
If the computer freezes in Safe Mode, chances are, you might have a hardware problem. It may be the hard drive or video card. If the video card is integrated or built in to the motherboard, then it might be the motherboard.
If the computer does not freeze in Safe Mode, let us continue and hopefully resolve this issue. Perform the next steps.
1. Click on Start.
2. Right Click on Computer.
3. Click on Manage.
You should find yourself looking at the Computer Managment window.
4. Click Device Manager to highlight.
5. Click the plus sign of the Display adapters, similar to the picture below.
6. Whatever listed under it, delete it. Press the Delete button on your keyboard, then,
follow the instructions.
7. Restart Computer to Normal Mode.
While your computer is restarting to Normal Mode, Windows should be installing its Native Driver for your computer's video card/adapter. Eventually, you will need to re-install the video driver for your computer. Should you find yourself asking how to re-install the video driver of your computer, kindly response with your computer's brand/model for further assistance.
I hope this works for you. Good Luck!
Thanks for using Fixya!
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
(for Windows only)
Mar 25, 2011 | Computers & Internet
I don't have the disk and i can not find the TI Educational Handheld Device driver anywhere for download also my calc freezes when connected. the pc also has the usb not reconized pop-up every 5 seconds as...
Here is the link to the connectivity software for your calculator. Select the Computer Operating system and download to your computer.
To install the calculator drivers (depending on the cable used) read the following.
Install the drivers first then connect the calculator to the computer with one of the two cables (SilverLink USB, or miniA to standard USB)
The procedure is described in the following, Please read it till the end then try it. If you have any problem, post a comment to this thread.
If you have a USB SilverLink cable, use it to connect the calculator though the I/O (round) port.
If you do not have a USB SilverLink cable, you can use the mini USB to USB Direct cable but you will have to install the correct driver for it.
I do not know what computer operating system you are running and I use Windows XP so I will describe the installation procedure for Window XP SP3.
Install TI connect 1.6 for Windows; if your system is Vista you must install a patch available on the TI website, at the same page where you find TI Connect.
After you install TI Connect, connect your calculator to the computer with the mini USB standard USB Direct cable. Windows will detect the calculator and will try to install the drivers. You will have something that is similar to what is on the three screen captures I am inserting in the post. On the last screen, choose the TI Educational Handheld device and click next.
When Windows asks to stop installation, click continue anyway
After the installation, click finish.
Device manager will show you something like what is on next screen (TI Educational Handheld device)
Run TI Connect to verify that the calculator is recognized. Connect your computer to the Internet and click the Updates Button on the TI Connect tool bar.
Verify that the I/O port (the round one) does not contain any foreign material. Also, for transferring files batteries must be in excellent condition.
Dec 17, 2010 | Texas Instruments TI-84 Plus Calculator
Logitech QuickCam Pro for Notebook freeze on Win7 platform
Try using it in Compatibility Mode
Right click on the Logitech webcam desktop icon
Select Properties and Compatibility tab
Check the box for CM
Select the OS
Apply OK
May 18, 2010 | Logitech QuickCam Pro Webcam
Hi there... Iogear Bluetooth micro adapter 2.1 for USB port, software installed... After inserting the adapter, laptop freezes.
What is the operating system of your computer? Can you tell me the exact model number of your Bluetooth Adapter (it usually starts with GBU)?
Check the link below, and see the system requirements:
You need to check also the system type of your computer (32 or 64-bit OS). Some IOGEAR devices could only support 32-bit OS. If you are running 64-bit OS, that could cause the problem.
Try to uninstall the Bluetooth driver. Reboot the computer, then reload the installation disk that came with it. Once the hardware wizard ask you to plug the device it, just continue the installation, BUT DO NOT plug the device.
After the installation is done, reboot the computer again, the PLUG the device in WHILE the computer is shutting down. Once the computer comes back up, then it should install the other necessary driver. And that should work.
Apr 24, 2010 | IOGear (GBU211) Bluetooth Wireless Adapter
On install, when it gets to the creating an account step, it seems to freeze up. I have the two icons on my desktop but it seems the software has not been fully installed?
I have a similar problem on a Vista PC (but not on a Win XP PC)except it doesn't freeze, the page simply disappears. I've emailed Logitech and am waiting for reply.
Jan 29, 2010 | Logitech QuickCam Pro 9000 Web Cam
My Msi 865gm2 motherboard won't complete loading windows (any)
1.switch on your computer and press F8 to enter in safe mode of your XP
2. rightclick mycomputer,then properties,then hardware,then device manager, double click on the
display adapter
3. right click on the display adapter and uninstall it or disable it.
4. double click on sound & volume and controller, right click on the sound devices and uninstall it or
diable it.
5. restart your computer..
6. now your system will enter into Windows XP and it will detect your hardwares, if it ask for the drivers
just cancell it till your desktop screen appears...
7. uninstall the driver softwares which you have installed before for the display and sound devices...
download your required configuration drivers from the given link.
Jun 20, 2009 | MSI 865GM2 LS P4/FSB...
Installation problem of Ethernet Driver
So, you have a "bootleg" version of Windows, and now you are needing "support" ??? Get legal, and then call Microsoft for support for updates downloaded from Windows Update web-site.
Can you access "DEVICE MANAGER", and then "ROLLBACK" the driver for the network adapter?
May 17, 2009 | Intel Computers & Internet
Computer freezes
remove 1 your new ram and see if computer ok
check system/control panel/device driver check for any yellow marks on them if so right click/properties drivers and either uninstall them or up grade them
I think you have a driver conflict
Jul 27, 2008 | Microsoft LifeCam VX-3000 Web Camera
System freeze
Which driver are you using now that you have 'converted' firewire to USB? The USB driver or the Firewire driver. I suspect none would work, as the Firewire driver os looking on the FW bus/layer, and the USB there. The devices may not communicate at all in the same way to either interface.
May 02, 2008 | Behringer F-CONTROL AUDIO FCA202 External...
Keyboard freezes system
Control Panel -> system -> hardware -> device manager -> find keyboards click the + to open up keyboard device, right click -> uninstall driver reboot machine and it should re-install
Don't know if it will work, but thats how to do it.
Feb 18, 2008 | Panasonic Toughbook 48 Notebook
Behringer F-CONTROL AUDIO FCA202 External Sound System Logo
56 people viewed this question
Top Behringer Computers & Internet Experts
Brett Duxbury
Brett Duxbury
Are you a Behringer Computer and Internet Expert? Answer questions, earn points and help others
