Question about Frigidaire FLEB8200DS Top Load Stacked Washer / Dryer
Washer doesn't work, dryer does- HELP!
We recently moved. When my husband placed the washer/dryer where it goes, he briefly turned them both on for a moment and they started and both appeared to work. After he hooked them up, the dryer does still work, but the washer does not. The water is hooked up, the washer just will not start. We don't want an expensive repair call if it is not necessary, please help with any suggestions! Thanks in advance!!
  • 481 Answers
  • check your breaker, one side of the 220v circuit breaker may have tripped causing only one of the units to work.
  •  turn your breaker off then back on.
Posted on Jun 29, 2008
What kind of plastic is the "window" in a frigidaire front loading washer made of? Recently when my husband pulled on the semi circular plastic piece, which is part of the "window", it split, almost c
Hello Ann Calk -Unfortunately depending on which part it is exactly since there is any adhesive available to glue it back together you need to purchase the entire door panel. I would suggest contacting a professional to accurately diagnose and repair the window washer.
Sep 30, 2012 | Frigidaire FTF2140FS Front Load Washer /...
My washer sounds like a freight train, I have been finding pieces of plastic in with the closth
I dont know whether you have secured the dryer to stop it from moving if it shakes about you need to secure it and make sure it is level(eg the floor is level or the dryer is level and all the leg screws are down and even so it doesn't wobble about.
The more the dryer wobbles about the drum inside will wobble inside the casing and it will break the things that hold the drum in place ,sound like that has already happened.but secure it in place and see what happens.
Jun 27, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Washer does not spin but water goes out. Agitation does occur during wash cycle. Belt is in place and does move when pulled. When turning the agitator the tub moves. What would need replaced?
Motor will not turn the one way...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 19, 2010 | GE Spacemaker Washer and Dryer Electric...
I have a stackable washer and dryer. Both have worked fine except recently clothes started getting caught between the drum and the front frame of the dryer. My husband pulled it apart checked the screws...
You may have a felt seal in the front that needs replaced. A wire off the pin switch could be off, and you will see the pin switch when you open the door, and make sure it is clicking.
Jun 22, 2010 | Kenmore 63942 Dryer
My LG dryer is about a year old and suddenly smells musty and mildewy inside! The washer is just fine (that seems to be the majority of complaints) but the DRYER definately smells. I clean the lint tray...
yes I have the same problem and can't find help anywhere...it smells like mold but my husband says like a dead animal and it gets smellier by the day. I leave the door open on both the washer
Jan 02, 2010 | LG Dryers
Hotpoint WD 865- washes ok, dryer won't work makes loud popping
sounds like the dryer heater element has worked loose perhaps and shorted out against the metal dryer box which sits on top of the drum.
best to get an engineer out i'd say.
Jan 14, 2009 | Hotpoint Aquarius WD63 Front Load...
Washer is shaking violently when it is time for the spin cycle
Check to see if all shipping blocks and bolts were removed. Refer to installation and setup instructions for your model.
I once moved into an apartment furnished with washer and dryer. The washer had worn holes in the vinyl flooring and a neighbor said the previous tenant made her son sit on the washer to hold it down. I investigated and found the shipping bolts were still in place. The tub, which is supposed to be able to swing, was rigidly held in place, so the entire machine danced around the room!
Jan 10, 2009 | Frigidaire 14 Cycle Tumble Action Washer
Maytag Washer/Dryer stackable
well i am having about the same problem, but mine won't even fill, the dryer works but the washer won't fill or turn on at all. my husband had it all apart, too the control assembly to parts place and they said that hardly ever goes bad so it is still sitting unusable with no answer or money to spend on it in site.
Jan 15, 2008 | Maytag LSE7806A Top Load Stacked...
Wd63 does it have a filter to empty for the dryer!?!
Hi there sarah
The hotpoint washer dyrer does not have a filter for fluff
100%
Need any other help dont hesitate to ask
Jan 13, 2008 | Hotpoint Aquarius WD63 Front Load...
No rinse
Make sure that you have both, hot and cold water connected and turned on. Some models will not advance through rinse if one of the hot or cold is off. See if this solves the problem, Catriver.
Jul 21, 2006 | Kenmore 80754 Top Load Stacked Washer /...
Frigidaire FLEB8200DS Top Load Stacked Washer / Dryer Logo
154 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
