Question about Frigidaire Refrigerators
We just purchased a new upright freezer. It has been plugged in and running for six hours now and it remains hot inside. What is the problem?
    Genius:
  • 1,036 Answers
If it is a frost-free model, it may have started it's defrost cycle. Ths is only for about an half an hour or less.
It should be cold within 12 hours when set to the required temperature.
If not, please contact here again before rating - as I can suggest other options. Thanks
Posted on Jun 28, 2008
Danby upright freezer plugged in a few hours ago, but coils on back are hot
If you are talking about the black condenser coli on the back of the fridge it is hot because the refrigerant is pulling all of the heat out of the fridge and trying to deposit it outside of the box. This is called hot box pull down. When the temperature inside the fridge comes down and you have product in it the coil on the back will become much cooler during operation. So if you are wondering it is nothing to be worried about, perfectly normal.
Aug 29, 2014 | Danby 10.4 cu. ft. / 294 liter Upright...
Just bought a Woods Upright freezer, not sure when it was last used, but when I got it home, i turned the knob to the cooldest setting (7) and it kiced on. how long should it take to start freezing. I have...
Freezer should not take more than 2 hours to.be at minus 10celcius. If only cold and not seeing any ice on the inside wall this could mean that there is missing refrigerant in the lines. Other way to check is to feel the pipes on the back if hot to the touch. There is many signs to see if your refrigerator is working or not.
If the compressor is running non stop and is very hot it will tell you that there is missing gas in the system.
If compressor is mot warm and is cycling on and off this could be only thermostat issue.
Good luck
Dec 29, 2017 | Woods Upright Freezer V1613RW3
Upright freezer trips circuit after moving across room
If compressor is hot, it could be an issue with the starting components. Let it cool down for about an hour an it is room temperature to the touch. If the breaker trips when the compressor attempts to start, I would look at the start components. It may be just a case of unusual timing that they went bad at this time. Make sure there is nothing else on the circuit you have it plugged into. Could be an overloading issue of the circuit.
Aug 04, 2017 | Refrigerators
OLDER G&e UPRIGHT FREEZER PLUGGED IN RUNNING BUT
replace the ptc overload/relay on the compressor and it will cool again
Sep 11, 2011 | GE Freezers
I have 16.7 upright Frigidaire Ultrafreeze freezer, Model AFFU1766DW3 & SERIAL #WB51720061, manufactured 04/05 that I purchased new 11/05. Water was on the floor next the the freezer but the light on...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 24, 2009 | Frigidaire Freezer 16.7 Upright Freezer,...
Hot exerior walls in a brand new Kenmore 28042 upright freezer
There should not be a fire hazard but you should be concerned that the freezer could break down if it is not allowed to vent the heat it produces. The freezer is not intended nor designed to be enclosed The manual must indicate specifications for minimum clearances for rear, top and sides, and may even be indicated on the big yellow sticker on the inside of the door. The clearances must be respected or again, the unit will fail, and the warranty may be voided in such cases.
Jun 27, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
HI I HAVE AN OLD 13 CU. FT KENMORE UPRIGHT FREEZER. AFTER I DEFROSTED IT YESTERDAY AND AFTER IT HAD BEEN PLUGGED IN FOR ABOUT 6 HRS I NOTICED THAT THE SIDES OF THE FREEZER FELT VERY HOT . IS THIS NORMAL ?...
It had to run longer than normal to cool down the freezer again. The heat from the compressor running is what you feel.
I would not worry about it unless it is still hot after 24 hours. Then there is another problem.
May 03, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
New chest freezer not getting cold
I am having the same problem. How long did it take?
I bought mine second hand and think it may be broken. I plugged it in 8 hours ago. I can hear it running but it's not cold yet.
Jul 13, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
New freezer not freezing
If it is a new freezer and it is plugged in and the control is turned on the power light should also be lit. After six hour of operation it should be cooled down. Call the place you purchased it from and tell them the problem. It is possible that you got a defective unit.
May 16, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Refrigerators Logo
63 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
