Beta 87 a picks up the entire stage sound (including drums) and my mix sounds muddy.
I have four beta 87a mikes. The problem is that when I solo each mike at the mixer, I hear the entire stage, drums, bass,.....everything. I installed a presonus acp 88 (which I have no experience using) but I still can't seem to get rid of the bleeding.
  • 1,512 Answers
They are condensor mics and will get alot more of the background bleed
Posted on Jun 30, 2008
  • Graeme Ross
    Graeme Ross Jun 30, 2008
    you may need to reduce the gain somewhat to help reduce this problem. Are you using the microphones for vocal work. They should have great performance used as a handheld vocal mic. You need to go through each performer, and set levels for for peak input. Adjust the channel gain down to a point when the mic is loudly spoken into, until you have no overload light up on that channel. very occasional flash is ok. If you set each channel in this manner with just one vocalist at a time(a sound check) you should have no problems with levels.As for the bleed from the rest of the band, there will always be some there, and is not so much of an issue. If you wish for less, a dynamic type ,it will pull in less bleed, but not offer the excellent performance of the beta 87a
Like to find out what's worng with my mic.
It's a condenser mic, so I suspect you aren't getting power to it. Make sure the phantom power is turned on on the mixer.
May 18, 2016 | Shure Beta 87A Professional Microphone
It's missing the male XLR insert at the base which plugs into the 3 sockets. Is this available as a spare part?
yes, most electronic part stores or web, remember that this mike is low impedance, made for cable runs over 20 feet, if you use a shorter cable it will work but the sound will be not right
Feb 08, 2016 | Shure Beta 87A Professional Microphone
What type of pickup is in the mike
EC2/58, which includes the world-famous Shure SM58 cardioid
dynamic microphone.
• EC2/87, which includes Shure's SM87 supercardioid condenser
microphone.
• EC2/Beta 58, which features Shure's premium supercardioid dynamic
Beta 58 vocal microphone.
• EC2/Beta 87, which features Shure's premium supercardioid
condenser Beta 87 vocal microphone.
You can look you do a search. Just put in the mic model in the search bar.
You can Y
Jun 11, 2014 | Shure Audio Players & Recorders
My main relay makes a buzzing sound with the ignition switch in the off position
on a replay there are 2 particular connections that cause that. When you look for numbers on that relay you will find the numbers 30, 85, 86, 87 and 87a. The problem is their is power going to 85 or 86 (they are the 2 control terminals that control the relay). that should not be. basically 87a allows power to go through the relay when the system is shut OFF, Terminal 87 is the path of power that turns on whatever is connected to it. Now... 85 and 86... one of them is ground... the other power. Typically 85 is ground and 86 power. Now to better explain what is going wrong. you have a connection that feeds power to 87a. that power is powering 87 which powers 86. when power is turned on at 87... it turns on 86... that causes the relay to pick up an break the connection of power to 87a while at a fraction of a second later making the contact to 87. So... the path of power is turning the relay on and off all by itself, LOL. I know this is confusing, sorry. But I hope it helps
Mar 19, 2014 | 2002 Kia Sportage
How do you unmute the Beta 87A wireless microphone
Look at the manual, the Beta 87A can be mounted on several shure microphone series. The shure web site has manuals for free.
Jan 06, 2014 | Shure Audio Players & Recorders
Shure beta 57A ..low recording volume from acoustic piano ...Directly to laptop no mixer used
are you using an interface?
Your level will be always be lower if you are going straight in.
Your interface and mixer will help you get the correct level in to your system before recording and also shaping the sound after the recording.You just need to get more gain up in there
Feb 04, 2013 | Shure Beta 57A Professional Microphone
Horn keep goin off when i hook up battery
unhook the horn, hook it back up when you get the correct info to fix it
Jul 31, 2011 | 1998 Buick LeSabre
Trying to use shure beta 87A with AT8801...getting no output. All connections tested and operational. Input to computer sound card or amp doesn't matter
Measure the voltage comming of pin2 and pin1, or between pin2 and pin3. If you donot get 48 volts the 8801 is bad. check your cable to make sure that pin2 and pin3 are not shorted. If you still have problems you can call Pro Line Music we ae a shure and at dealer. 215-736-8055
Dec 26, 2009 | Shure Beta 87A Professional Microphone
Shure 87a no sound
Send the mic to Shure for repairs. www.shure.com/service
Sep 12, 2009 | Shure Beta 87A Professional Microphone
121 people viewed this question
 Grubhead
Grubhead
